We have been trying to bind OpenCV and Boost libaries to our project, we have followed the following instruction https://devtalk.nvidia.com/default/topic/1019937/faq/opencv/
resp. added the directory which includes the libraries to (Build -> Settings -> NVCC Comiler & NVCC Linker) and to (to C/C++ General -> Path and symbols)
Nevertheless we constantly get this error message: fatal error: boost/lambda/lambda.hpp: No such file or directory
C++ Sample-Code
#include <string>
#include <boost/lambda/lambda.hpp>
#include <iostream>
#include <iterator>
#include <algorithm>
int main()
using namespace boost::lambda;
typedef std::istream_iterator<int> in;
std::for_each(
in(std::cin), in(), std::cout << (_1 * 3) << " " );
//printf("/usr/include/");
Error
sudo make -j all
[ 1%] Building CXX object 3rdparty/src/lodepng/CMakeFiles/lodepng-src.dir/src/lodepng.cpp.o
[ 2%] Dependencies for /usr/local/driveworks-1.2/samples-lane/build-target/src/stereo/stereo_common/CMakeFiles/dw_samples_stereo_common.dir//gen_utils.cu.o.depend.stamp
[ 3%] Dependencies for /usr/local/driveworks-1.2/samples-lane/build-target/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o.depend.stamp
[ 4%] Building C object 3rdparty/src/glfw/3.2-screen/src/CMakeFiles/glfw.dir/input.c.o
[ 5%] Building C object 3rdparty/src/glfw/3.2-screen/src/CMakeFiles/glfw.dir/window.c.o
[ 6%] Building C object 3rdparty/src/glfw/3.2-screen/src/CMakeFiles/glfw.dir/x11_init.c.o
[ 7%] Building C object 3rdparty/src/glfw/3.2-screen/src/CMakeFiles/glfw.dir/x11_window.c.o
[ 7%] Building C object 3rdparty/src/glfw/3.2-screen/src/CMakeFiles/glfw.dir/init.c.o
[ 8%] Building C object 3rdparty/src/glfw/3.2-screen/src/CMakeFiles/glfw.dir/monitor.c.o
[ 8%] Building C object 3rdparty/src/glfw/3.2-screen/src/CMakeFiles/glfw.dir/linux_joystick.c.o
[ 8%] Building C object 3rdparty/src/glfw/3.2-screen/src/CMakeFiles/glfw.dir/vulkan.c.o
[ 9%] Building C object 3rdparty/src/glfw/3.2-screen/src/CMakeFiles/glfw.dir/xkb_unicode.c.o
[ 10%] Building C object 3rdparty/src/glfw/3.2-screen/src/CMakeFiles/glfw.dir/context.c.o
[ 11%] Building C object 3rdparty/src/glfw/3.2-screen/src/CMakeFiles/glfw.dir/egl_context.c.o
[ 10%] Building C object 3rdparty/src/glfw/3.2-screen/src/CMakeFiles/glfw.dir/posix_tls.c.o
[ 12%] Building C object 3rdparty/src/glfw/3.2-screen/src/CMakeFiles/glfw.dir/glx_context.c.o
[ 13%] Building C object 3rdparty/src/glfw/3.2-screen/src/CMakeFiles/glfw.dir/posix_time.c.o
[ 13%] Building C object 3rdparty/src/glfw/3.2-screen/src/CMakeFiles/glfw.dir/x11_monitor.c.o
[ 13%] Linking C static library libglfw3.a
[ 13%] Built target glfw
[ 13%] Built target update_cuda_deps
[ 14%] Linking CXX static library liblodepng-src.a
[ 14%] Built target lodepng-src
[ 14%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/SampleFramework.cpp.o
[ 15%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/Window.cpp.o
[ 15%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/ProgramArguments.cpp.o
[ 16%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/DriveWorksSample.cpp.o
[ 17%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/Grid.cpp.o
[ 17%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/WindowGLFW.cpp.o
[ 18%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/MathUtils.cpp.o
[ 19%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/MouseView3D.cpp.o
[ 20%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/ProfilerCUDA.cpp.o
[ 20%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/SimpleRenderer.cpp.o
[ 21%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/SimpleCamera.cpp.o
[ 21%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/WindowLinuxEGL.cpp.o
[ 21%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/Log.cpp.o
[ 21%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/ScreenshotHelper.cpp.o
[ 22%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/RenderUtils.cpp.o
[ 23%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/WindowEGL.cpp.o
[ 24%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/SimpleRecordingPlayer.cpp.o
[ 25%] Linking CXX static library libdw_samples_framework.a
[ 25%] Built target dw_samples_framework
[ 26%] Building CXX object src/sensors/info/CMakeFiles/sample_sensors_info.dir/main.cpp.o
[ 28%] Building CXX object src/sensors/imu/CMakeFiles/sample_imu_logger.dir/main.cpp.o
[ 28%] Building NVCC (Device) object src/image/image_common/CMakeFiles/dw_samples_image_common.dir/gen_utils.cu.o
[ 28%] Building NVCC (Device) object src/stereo/stereo_common/CMakeFiles/dw_samples_stereo_common.dir/gen_utils.cu.o
[ 28%] Building CXX object src/sensors/canbus/interpreter/CMakeFiles/sample_canbus_interpreter.dir/interpreter.cpp.o
[ 29%] Building CXX object src/sensors/camera_gmsl_raw/CMakeFiles/sample_camera_gmsl_raw.dir/main.cpp.o
[ 30%] Building CXX object src/sensors/canbus/interpreter/CMakeFiles/sample_canbus_interpreter.dir/main.cpp.o
[ 30%] Building CXX object src/sensors/canbus/logger/CMakeFiles/sample_canbus_logger.dir/main.cpp.o
[ 31%] Building CXX object src/colorcorrection/CMakeFiles/sample_color_correction.dir/main.cpp.o
[ 32%] Building CXX object src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/main.cpp.o
[ 33%] Building CXX object src/hello_world/CMakeFiles/sample_hello_world.dir/main.cpp.o
[ 34%] Building CXX object src/rigconfiguration/CMakeFiles/sample_rig_configuration.dir/main.cpp.o
[ 35%] Building CXX object src/laneDetection/CMakeFiles/sample_lane_detection.dir/main.cpp.o
[ 35%] Building CXX object src/sensors/camera_gmsl/CMakeFiles/sample_camera_gmsl.dir/main.cpp.o
[ 35%] Building CXX object src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/main.cpp.o
[ 35%] Building CXX object src/drivenet/drivenet/CMakeFiles/sample_drivenet.dir/main.cpp.o
[ 35%] Building CXX object src/sensors/gps/CMakeFiles/sample_gps_logger.dir/main.cpp.o
[ 36%] Building CXX object src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/userInput.cpp.o
[ 37%] Building CXX object src/sensors/record/CMakeFiles/sample_record.dir/main.cpp.o
[ 37%] Building CXX object src/renderer/CMakeFiles/sample_renderer.dir/main.cpp.o
[ 37%] Building CXX object src/vehicleio/CMakeFiles/sample_vehicleio.dir/main.cpp.o
[ 38%] Building CXX object src/freespace/CMakeFiles/sample_freespace_detection.dir/main.cpp.o
[ 39%] Building CXX object src/egomotion/CMakeFiles/sample_egomotion.dir/main.cpp.o
[ 40%] Building CXX object src/icp/CMakeFiles/sample_icp.dir/main.cpp.o
[ 41%] Building CXX object src/ipc/CMakeFiles/sample_ipc_socketclientserver.dir/sample_ipc_socketclientserver.cpp.o
[ 41%] Building CXX object src/mapping/occupancy_grid/CMakeFiles/sample_occupancy_grid.dir/main.cpp.o
[ 42%] Building CXX object src/calibration/camera/CMakeFiles/sample_calibration_camera.dir/main.cpp.o
[ 43%] Building CXX object src/dnn/sample_object_tracker/CMakeFiles/sample_object_tracker.dir/main.cpp.o
[ 44%] Building CXX object src/sensors/camera_multiple_gmsl/CMakeFiles/sample_camera_multiple_gmsl.dir/main.cpp.o
[ 45%] Building CXX object src/dataspeedBridge/CMakeFiles/sample_dataspeedBridge.dir/main.cpp.o
[ 46%] Building CXX object src/features/camera_tracker/CMakeFiles/sample_camera_tracker.dir/main.cpp.o
[ 46%] Building CXX object src/sensors/camera_replay/CMakeFiles/sample_camera_replay.dir/main.cpp.o
[ 46%] Building CXX object src/sensors/camera_usb/CMakeFiles/sample_camera_usb.dir/main.cpp.o
[ 47%] Building CXX object src/lidar_accumulator/CMakeFiles/sample_lidar_accumulator.dir/main.cpp.o
[ 48%] Building CXX object src/sensors/camera_seek/CMakeFiles/sample_camera_seek.dir/main.cpp.o
[ 50%] Building CXX object src/drivenet/drivenet_ncameras/CMakeFiles/sample_drivenetNcameras.dir/main.cpp.o
[ 50%] Building CXX object src/rectifier/CMakeFiles/sample_video_rectifier.dir/main.cpp.o
[ 51%] Building CXX object src/render_engine/CMakeFiles/sample_render_engine.dir/main.cpp.o
[ 51%] Building CXX object src/sfm/CMakeFiles/sample_sfm.dir/main.cpp.o
[ 51%] Building CXX object src/maps/maptracker/CMakeFiles/sample_maptracker.dir/__/common/DrivePath.cpp.o
[ 52%] Building CXX object src/calibration/lidar/CMakeFiles/sample_calibration_lidar.dir/main.cpp.o
[ 53%] Building CXX object src/maps/maptracker/CMakeFiles/sample_maptracker.dir/MapTrackerApp.cpp.o
[ 54%] Building CXX object src/calibration/imu/CMakeFiles/sample_calibration_imu.dir/main.cpp.o
[ 55%] Building CXX object src/maps/maptracker/CMakeFiles/sample_maptracker.dir/__/common/MapsAppCommon.cpp.o
[ 55%] Building CXX object src/maps/maptracker/CMakeFiles/sample_maptracker.dir/main.cpp.o
[ 56%] Building CXX object src/maps/maptracker/CMakeFiles/sample_maptracker.dir/__/common/LanePlannerAppCommon.cpp.o
[ 57%] Building CXX object src/template/CMakeFiles/sample_template.dir/main.cpp.o
[ 58%] Building CXX object src/dnn/sample_object_detector/CMakeFiles/sample_object_detector.dir/main.cpp.o
[ 58%] Building CXX object src/cameraBlindness/CMakeFiles/sample_blindness_detection.dir/main.cpp.o
[ 58%] Building CXX object src/features/camera_scaling_tracker/CMakeFiles/sample_camera_scaling_tracker.dir/main.cpp.o
[ 59%] Building CXX object src/maps/mapaccess/CMakeFiles/sample_mapaccess.dir/__/common/MapsAppCommon.cpp.o
[ 60%] Building CXX object src/maps/mapaccess/CMakeFiles/sample_mapaccess.dir/MapsApp.cpp.o
[ 61%] Building CXX object src/maps/mapaccess/CMakeFiles/sample_mapaccess.dir/main.cpp.o
[ 62%] Building CXX object src/maps/laneplanner/CMakeFiles/sample_laneplanner.dir/__/common/LanePlannerAppCommon.cpp.o
[ 63%] Building CXX object src/maps/laneplanner/CMakeFiles/sample_laneplanner.dir/__/common/MapsAppCommon.cpp.o
[ 63%] Building CXX object src/maps/laneplanner/CMakeFiles/sample_laneplanner.dir/__/common/DrivePath.cpp.o
[ 63%] Building CXX object src/maps/mapaccess/CMakeFiles/sample_mapaccess.dir/__/common/DrivePath.cpp.o
[ 64%] Building CXX object src/maps/laneplanner/CMakeFiles/sample_laneplanner.dir/LanePlannerApp.cpp.o
[ 65%] Building CXX object src/maps/mapaccess/CMakeFiles/sample_mapaccess.dir/__/common/LanePlannerAppCommon.cpp.o
[ 66%] Building CXX object src/maps/laneplanner/CMakeFiles/sample_laneplanner.dir/main.cpp.o
/usr/local/driveworks-1.2/samples-lane/src/hello_world/main.cpp:52:35: fatal error: boost/lambda/lambda.hpp: No such file or directory
src/hello_world/CMakeFiles/sample_hello_world.dir/build.make:62: recipe for target 'src/hello_world/CMakeFiles/sample_hello_world.dir/main.cpp.o' failed
CMakeFiles/Makefile2:2071: recipe for target 'src/hello_world/CMakeFiles/sample_hello_world.dir/all' failed
compilation terminated.
make[2]: *** [src/hello_world/CMakeFiles/sample_hello_world.dir/main.cpp.o] Error 1
make[1]: *** [src/hello_world/CMakeFiles/sample_hello_world.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
/usr/local/driveworks-1.2/samples-lane/src/calibration/camera/main.cpp:60:35: fatal error: boost/lambda/lambda.hpp: No such file or directory
make[2]: *** [src/calibration/camera/CMakeFiles/sample_calibration_camera.dir/main.cpp.o] Error 1
make[1]: *** [src/calibration/camera/CMakeFiles/sample_calibration_camera.dir/all] Error 2
src/calibration/camera/CMakeFiles/sample_calibration_camera.dir/build.make:62: recipe for target 'src/calibration/camera/CMakeFiles/sample_calibration_camera.dir/main.cpp.o' failed
CMakeFiles/Makefile2:3283: recipe for target 'src/calibration/camera/CMakeFiles/sample_calibration_camera.dir/all' failed
[ 66%] Linking CXX executable sample_rig_configuration
[ 66%] Built target sample_rig_configuration
[ 67%] Linking CXX executable sample_renderer
[ 68%] Linking CXX executable sample_imu_logger
[ 69%] Linking CXX executable sample_sensors_info
[ 70%] Linking CXX executable sample_gps_logger
[ 71%] Linking CXX executable sample_vehicleio
[ 72%] Linking CXX executable sample_canbus_logger
[ 72%] Linking CXX executable sample_ipc_socketclientserver
[ 73%] Linking CXX executable sample_canbus_interpreter
[ 73%] Built target sample_renderer
[ 73%] Built target sample_imu_logger
[ 73%] Built target sample_sensors_info
[ 73%] Linking CXX executable sample_lidar_replay
[ 73%] Built target sample_vehicleio
[ 74%] Linking CXX executable sample_occupancy_grid
[ 74%] Built target sample_ipc_socketclientserver
[ 74%] Built target sample_canbus_logger
[ 74%] Built target sample_canbus_interpreter
[ 74%] Built target sample_gps_logger
[ 74%] Linking CXX executable sample_record
[ 74%] Built target sample_lidar_replay
[ 75%] Linking CXX executable sample_dataspeedBridge
[ 75%] Built target sample_occupancy_grid
[ 75%] Built target sample_record
[ 75%] Built target sample_dataspeedBridge
[ 76%] Linking CXX executable sample_template
[ 76%] Linking CXX static library libdw_samples_image_common.a
[ 76%] Linking CXX executable sample_camera_seek
[ 76%] Linking CXX executable sample_radar_replay
[ 76%] Built target dw_samples_image_common
[ 77%] Linking CXX executable sample_camera_replay
[ 78%] Linking CXX executable sample_camera_multiple_gmsl
[ 79%] Linking CXX executable sample_camera_usb
[ 79%] Linking CXX executable sample_video_rectifier
[ 79%] Linking CXX executable sample_camera_gmsl_raw
[ 79%] Linking CXX executable sample_color_correction
[ 79%] Built target sample_template
[ 79%] Built target sample_camera_seek
[ 80%] Building CXX object src/stereo/stereo_common/CMakeFiles/dw_samples_stereo_common.dir/stereoCommon.cpp.o
[ 81%] Linking CXX executable sample_maptracker
[ 81%] Built target sample_radar_replay
[ 82%] Linking CXX executable sample_camera_scaling_tracker
[ 82%] Built target sample_color_correction
[ 82%] Built target sample_camera_gmsl_raw
[ 82%] Built target sample_camera_multiple_gmsl
[ 83%] Linking CXX executable sample_icp
[ 83%] Built target sample_camera_replay
[ 83%] Built target sample_video_rectifier
[ 83%] Built target sample_camera_usb
[ 84%] Linking CXX executable sample_camera_gmsl
[ 85%] Linking CXX executable sample_freespace_detection
[ 85%] Linking CXX executable sample_object_detector
[ 86%] Linking CXX executable sample_render_engine
[ 86%] Linking CXX executable sample_laneplanner
[ 87%] Linking CXX executable sample_lidar_accumulator
[ 88%] Linking CXX executable sample_blindness_detection
[ 88%] Built target sample_camera_scaling_tracker
[ 88%] Built target sample_maptracker
[ 89%] Linking CXX executable sample_camera_tracker
[ 89%] Linking CXX executable sample_mapaccess
[ 89%] Linking CXX executable sample_calibration_imu
[ 89%] Linking CXX executable sample_lane_detection
[ 89%] Built target sample_camera_gmsl
[ 89%] Built target sample_icp
[ 90%] Linking CXX executable sample_drivenet
[ 90%] Built target sample_freespace_detection
[ 91%] Linking CXX executable sample_calibration_lidar
[ 91%] Built target sample_render_engine
[ 91%] Built target sample_object_detector
[ 91%] Built target sample_camera_tracker
[ 91%] Built target sample_blindness_detection
[ 91%] Built target sample_lidar_accumulator
[ 91%] Built target sample_laneplanner
[ 92%] Linking CXX executable sample_sfm
[ 93%] Linking CXX executable sample_object_tracker
[ 93%] Built target sample_mapaccess
[ 93%] Built target sample_calibration_imu
[ 93%] Linking CXX executable sample_egomotion
[ 93%] Built target sample_calibration_lidar
[ 93%] Built target sample_drivenet
[ 93%] Built target sample_lane_detection
[ 93%] Built target sample_sfm
[ 93%] Built target sample_object_tracker
[ 93%] Built target sample_egomotion
[ 93%] Linking CXX static library libdw_samples_stereo_common.a
[ 93%] Linking CXX executable sample_drivenetNcameras
[ 93%] Built target dw_samples_stereo_common
[ 93%] Built target sample_drivenetNcameras
make: *** [all] Error 2
Makefile:127: recipe for target 'all' failed
Do you know what could be the problem here?
Thank you
