Nsight fails to open text editor with shader source
NSight Version 2019.1.1
NSight Build Number 2019.1.1.19056
Visual Studio Community 2019 Version 16.0.2
GPU Gefore GTX 1060 Driver Version 419.17
Windows 10 64-bit
I am trying to use the shader debugging feature. When I capture a frame and scrub to the event I am interested in, I can see the shader I am interested in with a hyperlink on the source in the API Inspector:
[url]https://lh3.googleusercontent.com/czOQdHRq7ARqJRtZ9oUS_zMnICfRIrNamd0s0Bxoz6ezX1puwx9j34dcUAaDlHA_usRK0hE6TrjfSIDlo_zZJTlOxwEovZUJHaVpaER22LnTuHtGnyuZH3_4J5rjREtB94UX50dhcebYOSNhRrprTTaQNDNH0CnYOvmSikzQ8F7dbOzRH8N2q1SKtObVhx5JPvbP05SPY2v5IvVrL_-YIKX8bfnio5cDZXaSaPo_B6-rS4tHLo6N4RvYynPymxtKaWniYSya0pDtTYUapA37x4apaj1ub_Qhb_a-NnCXy2S72y31iGj_e0dLryl7Ktd_PWVH5IY2zxvbnv2BRBZ_Xf9ET0coEtY347M4vlUNfziuC7H9f8YdThgaUO4hnD5RG2Ny4RpFZCUShB46hzeDVs4yvXeXHZqza-ICq9XxzY-M-5KUNB5WMLJPEFsiSr-T4QhlwL8-NEAVhwc4_aWZQvThWIxN15YvRSx5bkm1WGC3ry2kYQcA0N_r-XWfjZ6L-RdpV1xKJupL8y7Il08D_Ma9XT_ZOURtP36Jt4LZsmKX7tQ508AbIoFg6jMalqmJd7XVUrYnRF3_BPa2Fmrh2CtrRuZ2NGZM6Jg1LsszVid0R4h0CPBZzg8G4raZu9DBqqAT31_zigeoOTZ962EKHOXCIPlVSsFH=w1470-h828-no[/url]
But, when I click on the hyperlink, I am presented with an empty text editor panel:
[url]https://lh3.googleusercontent.com/cGAH3e9t8r1Ru2CpEuf0hs6p-3Et2T5OQ6hTSpe1xAMIf4KI--HxwGyXe3A9aIg_CHjqIn-ZGdS6CXVykKGXoUaxt0ATDDC2njnkoBbtTEL3Dx2EHSkw5W1cwZYFDeQnfAoAGtvYNPXM1FfnBQLnb-V2mg1k-7FV_9rl1l6vRHZ4fxwQXug5LsV5PHlpT64V8NBIFqbC4PntIKRvEdmKCbnHyVWlpOQojYmg8UabaHbdx8Zfdo2b8YUFEq-hgxdnb5Kz58X94yIowQVJSXY76c7-XehlIKifisEmDW9qwm5sZOLoKbyCnnD62cyKirt4aRgOPptX60ixGrIEGwVa-yjaTdBAy8WBws24u4URFRbjhS05Ax-ER6Ghfgg2bKOiQSj3EtBtFaml4ChNqLo-OxZbo_PNb9sPvcX2R4dlGkE9_sGOKeGLHQyZwCrG_Ap8fH9z97y8K7jP-0nO4ZPt9T0vfgLzQsv1eaEJ7R5HjR5u9Z-r6YgNRDpvyafPBviTeU0_kLsFdELyXDsJwR16m7rhajRCWAqtjK8oZYXMHQ_5VVsQqMpsN4ydXu-aBmaOx2YTTPHUABH3G_R_2QuX_ZNAG1Y5j39GTCgjxsR6kmoFCWRRropQM_-6w56g6VaipjJshzcUFOlde9INXAM9ptTCOPds0d4R=w1470-h828-no[/url]
If I right-click on the panel tab and click on “Open Containing Folder”, I can see that the file has contents:
[url]https://lh3.googleusercontent.com/ZV9u8BzpFjMbWF8QpobSLHmRxp3cNCqvyiV8ApazSeMlWZ8VxbIDHbFEmvot2TBWo901JrpjTzdWzOr3UAWre5737RnBMo98WHjQtIHHvT2cVzbEAdQlAim4OH1Z5sXpJpERaU6jwcV9zyVug7pVmMWTpReiuLnw4iOyHWpixlSAvueDLh1QiV9JVtU_JbEAQAh-LbBoaE90bqdu15qt4OT78F2CoYNxRAcw2ENtbBVP6RyOe6lQFhW9Fo2yPjIvkqrWhPfYWncUwAh_6ndC-5zGsredqeU9i4Ho2y0FaAZiWftpiXD4RzlKWfQBSdAZot2Xib2Xa-Ukj8DwU12S86Gayb27D7rGiWNW10T8NDO7tBn1U7mRd_2ClPC81c8oVCZnv1fHTeGeFVq1JxRO0V8QBehe4x8rSTuu9RWBEpqM_kYj4stlE4VLKvLTAfg89S4X_ihumkFm2pfDtNc_FpwXn5UQWF0sIBEFXqOlDTT4IDQ1mhAkXIyqZ0svQ1NczszP_5ep-EnSSBLgve1ninlivSfBCIjr5Ewo4sg-shL08v3JVhnaDAjGsxxgtOSEL1qtexpVg-MFgcAu408z68o4o1S4Hq_BxB2WBOEpiLRZ_SvZ2aCkPEj5yS8KDa1NXqyNhS_i7VO97g_9iJBLKsEOefaMsTJt=w1470-h828-no[/url]
I can also open this temp file in a normal text editor to see contents:
[url]https://lh3.googleusercontent.com/s0xpI9r_dyCCXCM7Ca0TJYx4vSspJS13p_83zhnOrvhI4bZOxL2H5FlVfZCI6z-kyyhh8f1g2HMI6-kPTTwTID4ZPWBzs_cKWj93462Q8vibDGOC9CqcrmtTtS6yi3aXk5L71lmOarC3lQZV9Kw1R0CBN3rj8aR45GAjmEFRyQA5jPo2GpfSpznKHuyX09JSpYwXpk2iJBIaWGwJn4I5eImzGZ2sLiTJbbWyvqLRhz66xSlx-kEivVa_1twm2M6INrYWHGtHZ6A0I2C_EXHnQ0UuqsX_zrxQ2sd1HU2tSK89uxgjPIoscGyMPVIGw4s-G-9v7r84Fs4CuGpQb0KBcJD2ZfEEabwDDSmjuTcOG7iP9y3sWUYeMhiEOBn-Us0AWL2xWaptd1YXnYziZMSnfsxBDiGL3tBxdU1Lp2omgZuUARc6ieqFLAbLTdeG1ybGW9NfvsBBRZV3Fy0laYKdcSTdbgSm3lPU_8TKuqSpwUQZmxALOyAKXrAuCoB8PRRLazQsT2tDpbLctkgHbRy-PtQ_z4CmIAmqMhGmnQQ1po-XIsXsD-LaPwnYTKC-ichR3PIfhk2dCkzr4ialq-2IO4SELuEEmCnZOLojug5eXYczuBfEaZcXcSg7n2Ng6uxuwhQQgUqgUvTk6d7zT4UHUIGo7inaUWHA=w1470-h828-no[/url]
but I can’t toggle breakpoints in the external editor.
I’m sorry to say that NsightVSE no longer support shader debugging.
See [url]https://developer.nvidia.com/nsight-visual-studio-edition-features[/url]
[5] Not shown: Note that shader debugging (previously only supported on Kepler GPUs and for D3D11 and Open GL (4.2-4.5)) has been removed as of version 2019.1.
Is there some alternative tool that you would like to recommend? Shader debugging seems just as important as viewing renderer states when tracking down bugs.
RenderDoc has some basic shader debugging. You could try that.
As a note, we will be supporting Shader Debugging again in the future! But for now, it is unfortunately deprecated.
