I have installed the Cuda 8.0 toolkit on Fedora 25 running Oracle Java 8. When I start nsight, it hangs at the splash screen. It might be an issue with libgtk 2.0. I tried many eclipse-libgtk work arounds from previous eclipse problems posted on the internet but they did not work. Below is error log from the jvm.
A fatal error has been detected by the Java Runtime Environment:
SIGSEGV (0xb) at pc=0x00007f6c6fb55a18, pid=24317, tid=0x00007f6c9ee05700
JRE version: Java™ SE Runtime Environment (8.0_131-b11) (build 1.8.0_131-b11)
Java VM: Java HotSpot™ 64-Bit Server VM (25.131-b11 mixed mode linux-amd64 compressed oops)
Problematic frame:
C [libgtk-x11-2.0.so.0+0x1dba18]
Core dump written. Default location: /usr/local/cuda-8.0/libnsight/core or core.24317
If you would like to submit a bug report, please visit:
Crash Report
The crash happened outside the Java Virtual Machine in native code.
See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x00007f6c98008000): JavaThread “main” [_thread_in_native, id=24318, stack(0x00007f6c9ed05000,0x00007f6c9ee06000)]
siginfo: si_signo: 11 (SIGSEGV), si_code: 1 (SEGV_MAPERR), si_addr: 0x0000000000000024
Registers:
RAX=0x0000000000000024, RBX=0x00007f6c98a19280, RCX=0x0000000000000142, RDX=0x0000000000000014
RSP=0x00007f6c9ee03618, RBP=0x00007f6c98a19280, RSI=0x00007f6c9881d680, RDI=0x00007f6c98a192b8
R8 =0x00007f6c989a1070, R9 =0x0000000000000000, R10=0x0000000000000020, R11=0x0000000000000000
R12=0x00007f6c9881d680, R13=0x0000000000000000, R14=0x00007f6c9888ccd0, R15=0x0000000000000014
RIP=0x00007f6c6fb55a18, EFLAGS=0x0000000000010206, CSGSFS=0x002b000000000033, ERR=0x0000000000000004
TRAPNO=0x000000000000000e
Top of Stack: (sp=0x00007f6c9ee03618)
0x00007f6c9ee03618: 00007f6c6fb581a7 0000000000000000
0x00007f6c9ee03628: 00007f6c9888ccd0 0000000000000014
0x00007f6c9ee03638: 7d8f4d93cd0bc600 00007f6c98a19280
0x00007f6c9ee03648: 00007f6c9881d680 00007f6c9894e370
0x00007f6c9ee03658: 00007f6c6fb5a5cb 00007f6c9881d680
0x00007f6c9ee03668: 00007f6c9894e370 0000000000000014
0x00007f6c9ee03678: 00007f6c6fb75a62 000000289894ad70
0x00007f6c9ee03688: 000000009888ccd0 00007f6c9ee036e0
0x00007f6c9ee03698: 00007f6c9ee036e0 00007f6c9894ad70
0x00007f6c9ee036a8: 00007f6c983ce980 00007f6c983ce980
0x00007f6c9ee036b8: 00007f6c98910c20 0000000000000000
0x00007f6c9ee036c8: 00007f6c7d9ae8d0 00007f6bd8002fb0
0x00007f6c9ee036d8: 00007f6c6fb84fbb 00007f6c9894a890
0x00007f6c9ee036e8: 00007f6c9888ccd0 ffffffff00000000
0x00007f6c9ee036f8: ffffffffffffffff 060885338eb7c604
0x00007f6c9ee03708: 00007f6c9899c050 00007f6c9894ad70
0x00007f6c9ee03718: ffffffff00000000 00007f6c98910c20
0x00007f6c9ee03728: 00007f6c98945d40 00007f6c7dc79280
0x00007f6c9ee03738: 7d8f4d93cd0bc600 00007f6c983ce980
0x00007f6c9ee03748: 00007f6c98945d40 00007f6c98945d40
0x00007f6c9ee03758: 00007f6c7dc79280 00007f6c7d9ae8d0
0x00007f6c9ee03768: 00007f6c6fb873dd 0000000000000000
0x00007f6c9ee03778: 00007f6c6fb87419 00007f6c9ee037f0
0x00007f6c9ee03788: 00007f6c7eb3a717 000000000001acfd
0x00007f6c9ee03798: 00007f6c7eb3a6c0 00007f6bd8002fb0
0x00007f6c9ee037a8: 00007f6c7d9ae8e7 00007f6c9838a630
0x00007f6c9ee037b8: 0000000000000000 00007f6c983f4b50
0x00007f6c9ee037c8: 00007f6c7d9b1e52 00007f6c9ee037e4
0x00007f6c9ee037d8: 00007f6bd8001f20 0000000000000014
0x00007f6c9ee037e8: 0000000000000000 00007f6c9ee03808
0x00007f6c9ee037f8: 00007f6c9ee03810 00007f6c98945c60
0x00007f6c9ee03808: 00007f6c98945d40 00007f6c7eb3a6c0
Instructions: (pc=0x00007f6c6fb55a18)
0x00007f6c6fb559f8: e7 5b 48 89 ef 5d 41 5c e9 eb fe ff ff 90 66 2e
0x00007f6c6fb55a08: 0f 1f 84 00 00 00 00 00 48 8b 07 48 85 c0 74 16
0x00007f6c6fb55a18: 48 3b 30 75 08 eb 5b 90 48 39 30 74 53 48 8b 40
0x00007f6c6fb55a28: 08 48 85 c0 75 f2 55 53 48 89 fd bf 18 00 00 00
Register to memory mapping:
RAX=0x0000000000000024 is an unknown value
RBX=0x00007f6c98a19280 is an unknown value
RCX=0x0000000000000142 is an unknown value
RDX=0x0000000000000014 is an unknown value
RSP=0x00007f6c9ee03618 is pointing into the stack for thread: 0x00007f6c98008000
RBP=0x00007f6c98a19280 is an unknown value
RSI=0x00007f6c9881d680 is an unknown value
RDI=0x00007f6c98a192b8 is an unknown value
R8 =0x00007f6c989a1070 is an unknown value
R9 =0x0000000000000000 is an unknown value
R10=0x0000000000000020 is an unknown value
R11=0x0000000000000000 is an unknown value
R12=0x00007f6c9881d680 is an unknown value
R13=0x0000000000000000 is an unknown value
R14=0x00007f6c9888ccd0 is an unknown value
R15=0x0000000000000014 is an unknown value
Stack: [0x00007f6c9ed05000,0x00007f6c9ee06000], sp=0x00007f6c9ee03618, free space=1017k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
J 2114 org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(JZ)Z (0 bytes) @ 0x00007f6c8988dec4 [0x00007f6c8988de80+0x44]
J 2113 C1 org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(JZ)Z (32 bytes) @ 0x00007f6c8989b7a4 [0x00007f6c8989b700+0xa4]
j org.eclipse.swt.widgets.Display.readAndDispatch()Z+36
j org.eclipse.jface.window.Window.runEventLoop(Lorg/eclipse/swt/widgets/Shell;)V+23
j org.eclipse.jface.window.Window.open()I+49
j org.eclipse.ui.internal.ide.ChooseWorkspaceDialog.prompt(Z)V+15
j org.eclipse.ui.internal.ide.application.IDEApplication.promptForWorkspace(Lorg/eclipse/swt/widgets/Shell;Lorg/eclipse/ui/internal/ide/ChooseWorkspaceData;Z)Ljava/net/URL;+15
j org.eclipse.ui.internal.ide.application.IDEApplication.checkInstanceLocation(Lorg/eclipse/swt/widgets/Shell;Ljava/util/Map;)Ljava/lang/Object;+184
j org.eclipse.ui.internal.ide.application.IDEApplication.start(Lorg/eclipse/equinox/app/IApplicationContext;)Ljava/lang/Object;+50
j org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Object;+135
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Object;)Ljava/lang/Object;+85
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Ljava/lang/Object;+82
j org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object;+109
j org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+132
v ~StubRoutines::call_stub
j sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+0
j sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+100
j sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+6
j java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+56
j org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+211
j org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+160
j org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
j org.eclipse.equinox.launcher.Main.main([Ljava/lang/String;)V+10
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x00007f6c28001000 JavaThread “SIGINT handler” daemon [_thread_blocked, id=24351, stack(0x00007f6c6c9ce000,0x00007f6c6cacf000)]
0x00007f6c0c061000 JavaThread “EMF Reference Cleaner” daemon [_thread_blocked, id=24345, stack(0x00007f6c6c02a000,0x00007f6c6c12b000)]
0x00007f6c0416b000 JavaThread “Worker-JM” [_thread_blocked, id=24343, stack(0x00007f6c6c487000,0x00007f6c6c588000)]
0x00007f6c04253800 JavaThread “Bundle File Closer” daemon [_thread_blocked, id=24342, stack(0x00007f6c6c5cc000,0x00007f6c6c6cd000)]
0x00007f6c04006800 JavaThread “[Timer] - Main Queue Handler” daemon [_thread_blocked, id=24341, stack(0x00007f6c6c8cd000,0x00007f6c6c9ce000)]
0x00007f6c98684800 JavaThread “Start Level: Equinox Container: d0191c8d-a55b-0017-1154-cad35ed2cf11” daemon [_thread_blocked, id=24339, stack(0x00007f6c6cccf000,0x00007f6c6cdd0000)]
0x00007f6c98682000 JavaThread “Framework Event Dispatcher: Equinox Container: d0191c8d-a55b-0017-1154-cad35ed2cf11” daemon [_thread_blocked, id=24338, stack(0x00007f6c6cdd0000,0x00007f6c6ced1000)]
0x00007f6c98637000 JavaThread “Active Thread: Equinox Container: d0191c8d-a55b-0017-1154-cad35ed2cf11” [_thread_blocked, id=24337, stack(0x00007f6c6ced1000,0x00007f6c6cfd2000)]
0x00007f6c98219000 JavaThread “Service Thread” daemon [_thread_blocked, id=24335, stack(0x00007f6c7eff0000,0x00007f6c7f0f1000)]
0x00007f6c9820e000 JavaThread “C1 CompilerThread3” daemon [_thread_blocked, id=24334, stack(0x00007f6c7f0f1000,0x00007f6c7f1f2000)]
0x00007f6c9820b800 JavaThread “C2 CompilerThread2” daemon [_thread_blocked, id=24333, stack(0x00007f6c7f1f2000,0x00007f6c7f2f3000)]
0x00007f6c9820a000 JavaThread “C2 CompilerThread1” daemon [_thread_blocked, id=24332, stack(0x00007f6c7f2f3000,0x00007f6c7f3f4000)]
0x00007f6c98207000 JavaThread “C2 CompilerThread0” daemon [_thread_blocked, id=24331, stack(0x00007f6c7f3f4000,0x00007f6c7f4f5000)]
0x00007f6c98205800 JavaThread “Signal Dispatcher” daemon [_thread_blocked, id=24330, stack(0x00007f6c7f4f5000,0x00007f6c7f5f6000)]
0x00007f6c981d2000 JavaThread “Finalizer” daemon [_thread_blocked, id=24329, stack(0x00007f6c7f5f6000,0x00007f6c7f6f7000)]
0x00007f6c981cd800 JavaThread “Reference Handler” daemon [_thread_blocked, id=24328, stack(0x00007f6c7f6f7000,0x00007f6c7f7f8000)]
=>0x00007f6c98008000 JavaThread “main” [_thread_in_native, id=24318, stack(0x00007f6c9ed05000,0x00007f6c9ee06000)]
Other Threads:
0x00007f6c981c6000 VMThread [stack: 0x00007f6c7f7f8000,0x00007f6c7f8f9000] [id=24327]
0x00007f6c9821c000 WatcherThread [stack: 0x00007f6c7eeef000,0x00007f6c7eff0000] [id=24336]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap:
PSYoungGen total 150016K, used 129024K [0x0000000719180000, 0x0000000723880000, 0x00000007c0000000)
eden space 129024K, 100% used [0x0000000719180000,0x0000000720f80000,0x0000000720f80000)
from space 20992K, 0% used [0x0000000722400000,0x0000000722400000,0x0000000723880000)
to space 20992K, 0% used [0x0000000720f80000,0x0000000720f80000,0x0000000722400000)
ParOldGen total 343040K, used 0K [0x00000005cb400000, 0x00000005e0300000, 0x0000000719180000)
object space 343040K, 0% used [0x00000005cb400000,0x00000005cb400000,0x00000005e0300000)
Metaspace used 17498K, capacity 18962K, committed 19072K, reserved 1067008K
class space used 1743K, capacity 2130K, committed 2176K, reserved 1048576K
Card table byte_map: [0x00007f6c88059000,0x00007f6c89000000] byte_map_base: 0x00007f6c851ff000
Marking Bits: (ParMarkBitMap*) 0x00007f6c9e1d8f60
Begin Bits: [0x00007f6c405a0000, 0x00007f6c482d0000)
End Bits: [0x00007f6c482d0000, 0x00007f6c50000000)
Polling page: 0x00007f6c9ee26000
CodeCache: size=245760Kb used=8792Kb max_used=8803Kb free=236967Kb
bounds [0x00007f6c89000000, 0x00007f6c898b0000, 0x00007f6c98000000]
total_blobs=2641 nmethods=2113 adapters=441
compilation: enabled
Compilation events (10 events):
Event: 1.969 Thread 0x00007f6c9820e000 2111 3 org.eclipse.swt.widgets.Widget::isDisposed (13 bytes)
Event: 1.969 Thread 0x00007f6c9820e000 nmethod 2111 0x00007f6c8988e410 code [0x00007f6c8988e580, 0x00007f6c8988e730]
Event: 1.969 Thread 0x00007f6c9820e000 2113 ! 3 org.eclipse.swt.internal.gtk.OS::g_main_context_iteration (32 bytes)
Event: 1.969 Thread 0x00007f6c9820e000 nmethod 2113 0x00007f6c8989b550 code [0x00007f6c8989b700, 0x00007f6c8989b998]
Event: 1.969 Thread 0x00007f6c9820b800 2115 ! 4 org.eclipse.swt.internal.Lock::lock (76 bytes)
Event: 1.971 Thread 0x00007f6c9820b800 nmethod 2115 0x00007f6c8989e910 code [0x00007f6c8989ea60, 0x00007f6c8989ecb8]
Event: 1.971 Thread 0x00007f6c9820b800 2116 ! 4 org.eclipse.swt.internal.Lock::unlock (55 bytes)
Event: 1.972 Thread 0x00007f6c9820b800 nmethod 2116 0x00007f6c8989cf50 code [0x00007f6c8989d0a0, 0x00007f6c8989d318]
Event: 10.788 Thread 0x00007f6c9820e000 2117 1 java.util.logging.LogManager$LoggerContext::getOwner (5 bytes)
Event: 10.788 Thread 0x00007f6c9820e000 nmethod 2117 0x00007f6c8989cc90 code [0x00007f6c8989cde0, 0x00007f6c8989cef0]
GC Heap History (0 events):
No events
Deoptimization events (10 events):
Event: 1.760 Thread 0x00007f6c98699800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x00007f6c8983ffe0 method=java.lang.StringCoding$StringDecoder.decode([BII)[C @ 20
Event: 1.891 Thread 0x00007f6c98008000 Uncommon trap: reason=unstable_if action=reinterpret pc=0x00007f6c8981f894 method=java.util.Properties$LineReader.readLine()I @ 180
Event: 1.894 Thread 0x00007f6c98008000 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x00007f6c89267c4c method=java.util.Collections$UnmodifiableCollection.size()I @ 4
Event: 1.894 Thread 0x00007f6c98008000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x00007f6c89291a7c method=java.util.Collections$UnmodifiableList.get(I)Ljava/lang/Object; @ 5
Event: 1.896 Thread 0x00007f6c98008000 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x00007f6c89267c4c method=java.util.Collections$UnmodifiableCollection.size()I @ 4
Internal exceptions (10 events):
Event: 0.118 Thread 0x00007f6c98008000 Exception <a ‘java/security/PrivilegedActionException’> (0x00000007193af508) thrown at [/HUDSON/workspace/8-2-build-linux-amd64/jdk8u131/8869/hotspot/src/share/vm/prims/jvm.cpp, line 1390]
Event: 0.118 Thread 0x00007f6c98008000 Exception <a ‘java/security/PrivilegedActionException’> (0x00000007193af900) thrown at [/HUDSON/workspace/8-2-build-linux-amd64/jdk8u131/8869/hotspot/src/share/vm/prims/jvm.cpp, line 1390]
Event: 0.118 Thread 0x00007f6c98008000 Exception <a ‘java/security/PrivilegedActionException’> (0x00000007193b1fa8) thrown at [/HUDSON/workspace/8-2-build-linux-amd64/jdk8u131/8869/hotspot/src/share/vm/prims/jvm.cpp, line 1390]
Event: 0.118 Thread 0x00007f6c98008000 Exception <a ‘java/security/PrivilegedActionException’> (0x00000007193b23a0) thrown at [/HUDSON/workspace/8-2-build-linux-amd64/jdk8u131/8869/hotspot/src/share/vm/prims/jvm.cpp, line 1390]
Event: 0.126 Thread 0x00007f6c98008000 Exception <a ‘java/io/FileNotFoundException’> (0x00000007193cf988) thrown at [/HUDSON/workspace/8-2-build-linux-amd64/jdk8u131/8869/hotspot/src/share/vm/prims/jni.cpp, line 709]
Event: 0.132 Thread 0x00007f6c98008000 Exception <a ‘java/lang/UnsatisfiedLinkError’: org.eclipse.equinox.launcher.JNIBridge._set_launcher_info(Ljava/lang/String;Ljava/lang/String;)V> (0x00000007196c6188) thrown at [/HUDSON/workspace/8-2-build-linux-amd64/jdk8u131/8869/hotspot/src/share/vm/pri
Event: 0.709 Thread 0x00007f6c98682000 Implicit null exception at 0x00007f6c891d0e0f to 0x00007f6c891d0eed
Event: 1.482 Thread 0x00007f6c00072000 Exception <a ‘java/io/FileNotFoundException’> (0x000000071f580190) thrown at [/HUDSON/workspace/8-2-build-linux-amd64/jdk8u131/8869/hotspot/src/share/vm/prims/jni.cpp, line 709]
Event: 1.592 Thread 0x00007f6c00072000 Exception <a ‘java/io/FileNotFoundException’> (0x000000071f8802c0) thrown at [/HUDSON/workspace/8-2-build-linux-amd64/jdk8u131/8869/hotspot/src/share/vm/prims/jni.cpp, line 709]
Event: 1.873 Thread 0x00007f6c98008000 Exception <a ‘java/io/FileNotFoundException’> (0x00000007202d0658) thrown at [/HUDSON/workspace/8-2-build-linux-amd64/jdk8u131/8869/hotspot/src/share/vm/prims/jni.cpp, line 709]
Events (10 events):
Event: 10.787 loading class java/util/IdentityHashMap$KeySet done
Event: 10.787 loading class java/util/IdentityHashMap$KeyIterator
Event: 10.787 loading class java/util/IdentityHashMap$IdentityHashMapIterator
Event: 10.787 loading class java/util/IdentityHashMap$IdentityHashMapIterator done
Event: 10.787 loading class java/util/IdentityHashMap$KeyIterator done
Event: 10.787 Thread 0x00007f6c041ba800 Thread added: 0x00007f6c041ba800
Event: 10.787 Thread 0x00007f6c040ff000 Thread added: 0x00007f6c040ff000
Event: 10.788 Thread 0x00007f6c04661800 Thread added: 0x00007f6c04661800
Event: 10.788 Thread 0x00007f6c041ba800 Thread exited: 0x00007f6c041ba800
Event: 10.788 Thread 0x00007f6c04661800 Thread exited: 0x00007f6c04661800
Dynamic libraries:
00400000-00401000 r-xp 00000000 fd:00 114688527 /usr/java/jdk1.8.0_131/jre/bin/java
00600000-00601000 rw-p 00000000 fd:00 114688527 /usr/java/jdk1.8.0_131/jre/bin/java
00e63000-00e84000 rw-p 00000000 00:00 0 [heap]
5cb400000-5e0300000 rw-p 00000000 00:00 0
5e0300000-719180000 —p 00000000 00:00 0
719180000-723880000 rw-p 00000000 00:00 0
723880000-7c0000000 —p 00000000 00:00 0
7c0000000-7c0220000 rw-p 00000000 00:00 0
7c0220000-800000000 —p 00000000 00:00 0
7f6bd8000000-7f6bd8021000 rw-p 00000000 00:00 0
7f6bd8021000-7f6bdc000000 —p 00000000 00:00 0
7f6be0000000-7f6be0022000 rw-p 00000000 00:00 0
7f6be0022000-7f6be4000000 —p 00000000 00:00 0
7f6be4000000-7f6be4022000 rw-p 00000000 00:00 0
7f6be4022000-7f6be8000000 —p 00000000 00:00 0
7f6be8000000-7f6be8021000 rw-p 00000000 00:00 0
7f6be8021000-7f6bec000000 —p 00000000 00:00 0
7f6bec000000-7f6bec022000 rw-p 00000000 00:00 0
7f6bec022000-7f6bf0000000 —p 00000000 00:00 0
7f6bf0000000-7f6bf0021000 rw-p 00000000 00:00 0
7f6bf0021000-7f6bf4000000 —p 00000000 00:00 0
7f6bf4000000-7f6bf4036000 rw-p 00000000 00:00 0
7f6bf4036000-7f6bf8000000 —p 00000000 00:00 0
7f6bf8000000-7f6bf8021000 rw-p 00000000 00:00 0
7f6bf8021000-7f6bfc000000 —p 00000000 00:00 0
7f6bfc000000-7f6bfc021000 rw-p 00000000 00:00 0
7f6bfc021000-7f6c00000000 —p 00000000 00:00 0
7f6c00000000-7f6c00187000 rw-p 00000000 00:00 0
7f6c00187000-7f6c04000000 —p 00000000 00:00 0
7f6c04000000-7f6c048f3000 rw-p 00000000 00:00 0
7f6c048f3000-7f6c08000000 —p 00000000 00:00 0
7f6c08000000-7f6c08021000 rw-p 00000000 00:00 0
7f6c08021000-7f6c0c000000 —p 00000000 00:00 0
7f6c0c000000-7f6c0c0a6000 rw-p 00000000 00:00 0
7f6c0c0a6000-7f6c10000000 —p 00000000 00:00 0
7f6c10000000-7f6c10021000 rw-p 00000000 00:00 0
7f6c10021000-7f6c14000000 —p 00000000 00:00 0
7f6c14000000-7f6c14021000 rw-p 00000000 00:00 0
7f6c14021000-7f6c18000000 —p 00000000 00:00 0
7f6c18000000-7f6c18691000 rw-p 00000000 00:00 0
7f6c18691000-7f6c1c000000 —p 00000000 00:00 0
7f6c1c000000-7f6c1c8a9000 rw-p 00000000 00:00 0
7f6c1c8a9000-7f6c20000000 —p 00000000 00:00 0
7f6c20000000-7f6c20dc5000 rw-p 00000000 00:00 0
7f6c20dc5000-7f6c24000000 —p 00000000 00:00 0
7f6c24000000-7f6c24968000 rw-p 00000000 00:00 0
7f6c24968000-7f6c28000000 —p 00000000 00:00 0
7f6c28000000-7f6c28021000 rw-p 00000000 00:00 0
7f6c28021000-7f6c2c000000 —p 00000000 00:00 0
7f6c2d461000-7f6c34000000 r–p 00000000 fd:00 107486807 /usr/lib/locale/locale-archive
7f6c34000000-7f6c34021000 rw-p 00000000 00:00 0
7f6c34021000-7f6c38000000 —p 00000000 00:00 0
7f6c38000000-7f6c38021000 rw-p 00000000 00:00 0
7f6c38021000-7f6c3c000000 —p 00000000 00:00 0
7f6c3c000000-7f6c3c021000 rw-p 00000000 00:00 0
7f6c3c021000-7f6c40000000 —p 00000000 00:00 0
7f6c405a0000-7f6c50000000 rw-p 00000000 00:00 0
7f6c50000000-7f6c50021000 rw-p 00000000 00:00 0
7f6c50021000-7f6c54000000 —p 00000000 00:00 0
7f6c54000000-7f6c54021000 rw-p 00000000 00:00 0
7f6c54021000-7f6c58000000 —p 00000000 00:00 0
7f6c58000000-7f6c58021000 rw-p 00000000 00:00 0
7f6c58021000-7f6c5c000000 —p 00000000 00:00 0
7f6c5f4f3000-7f6c5f4f6000 —p 00000000 00:00 0
7f6c5f4f6000-7f6c5f5f4000 rw-p 00000000 00:00 0
7f6c5f5f4000-7f6c5f5fe000 r-xp 00000000 fd:00 116262506 /usr/local/cuda-8.0/libnsight/configuration/org.eclipse.osgi/300/0/.cp/libswt-atk-gtk-4430.so
7f6c5f5fe000-7f6c5f7fe000 —p 0000a000 fd:00 116262506 /usr/local/cuda-8.0/libnsight/configuration/org.eclipse.osgi/300/0/.cp/libswt-atk-gtk-4430.so
7f6c5f7fe000-7f6c5f7ff000 rw-p 0000a000 fd:00 116262506 /usr/local/cuda-8.0/libnsight/configuration/org.eclipse.osgi/300/0/.cp/libswt-atk-gtk-4430.so
7f6c5f7ff000-7f6c5f800000 —p 00000000 00:00 0
7f6c5f800000-7f6c60000000 rw-p 00000000 00:00 0
7f6c60000000-7f6c60021000 rw-p 00000000 00:00 0
7f6c60021000-7f6c64000000 —p 00000000 00:00 0
7f6c6404c000-7f6c6404f000 —p 00000000 00:00 0
7f6c6404f000-7f6c6414d000 rw-p 00000000 00:00 0
7f6c6414d000-7f6c641f9000 r–p 00000000 fd:00 108660835 /usr/share/fonts/dejavu/DejaVuSans-Bold.ttf
7f6c641f9000-7f6c64279000 rw-p 00000000 00:00 0
7f6c64279000-7f6c643f9000 —p 00000000 00:00 0
7f6c643f9000-7f6c643fa000 —p 00000000 00:00 0
7f6c643fa000-7f6c64bfa000 rw-p 00000000 00:00 0
7f6c64bfa000-7f6c64bfb000 —p 00000000 00:00 0
7f6c64bfb000-7f6c653fb000 rw-p 00000000 00:00 0
7f6c653fb000-7f6c653fc000 —p 00000000 00:00 0
7f6c653fc000-7f6c65bfc000 rw-p 00000000 00:00 0
7f6c65bfc000-7f6c65bfe000 r-xp 00000000 fd:00 107488447 /usr/lib64/libutil-2.24.so
7f6c65bfe000-7f6c65dfd000 —p 00002000 fd:00 107488447 /usr/lib64/libutil-2.24.so
7f6c65dfd000-7f6c65dfe000 r–p 00001000 fd:00 107488447 /usr/lib64/libutil-2.24.so
7f6c65dfe000-7f6c65dff000 rw-p 00002000 fd:00 107488447 /usr/lib64/libutil-2.24.so
7f6c65dff000-7f6c65e35000 r-xp 00000000 fd:00 107876301 /usr/lib64/gvfs/libgvfscommon.so
7f6c65e35000-7f6c66035000 —p 00036000 fd:00 107876301 /usr/lib64/gvfs/libgvfscommon.so
7f6c66035000-7f6c6603b000 r–p 00036000 fd:00 107876301 /usr/lib64/gvfs/libgvfscommon.so
7f6c6603b000-7f6c6603c000 rw-p 00000000 00:00 0
7f6c6603c000-7f6c6606b000 r-xp 00000000 fd:00 108009330 /usr/lib64/gio/modules/libgvfsdbus.so
7f6c6606b000-7f6c6626b000 —p 0002f000 fd:00 108009330 /usr/lib64/gio/modules/libgvfsdbus.so
7f6c6626b000-7f6c6626d000 r–p 0002f000 fd:00 108009330 /usr/lib64/gio/modules/libgvfsdbus.so
7f6c6626d000-7f6c6626e000 rw-p 00031000 fd:00 108009330 /usr/lib64/gio/modules/libgvfsdbus.so
7f6c6626e000-7f6c66280000 r-xp 00000000 fd:00 107487955 /usr/lib64/libgpg-error.so.0.19.1
7f6c66280000-7f6c66480000 —p 00012000 fd:00 107487955 /usr/lib64/libgpg-error.so.0.19.1
7f6c66480000-7f6c66481000 r–p 00012000 fd:00 107487955 /usr/lib64/libgpg-error.so.0.19.1
7f6c66481000-7f6c66482000 rw-p 00013000 fd:00 107487955 /usr/lib64/libgpg-error.so.0.19.1
7f6c66482000-7f6c6655e000 r-xp 00000000 fd:00 107487900 /usr/lib64/libgcrypt.so.20.0.6
7f6c6655e000-7f6c6675e000 —p 000dc000 fd:00 107487900 /usr/lib64/libgcrypt.so.20.0.6
7f6c6675e000-7f6c6675f000 r–p 000dc000 fd:00 107487900 /usr/lib64/libgcrypt.so.20.0.6
7f6c6675f000-7f6c66767000 rw-p 000dd000 fd:00 107487900 /usr/lib64/libgcrypt.so.20.0.6
7f6c66767000-7f6c66768000 rw-p 00000000 00:00 0
7f6c66768000-7f6c6677b000 r-xp 00000000 fd:00 107486950 /usr/lib64/liblz4.so.1.7.5
7f6c6677b000-7f6c6697a000 —p 00013000 fd:00 107486950 /usr/lib64/liblz4.so.1.7.5
7f6c6697a000-7f6c6697b000 r–p 00012000 fd:00 107486950 /usr/lib64/liblz4.so.1.7.5
7f6c6697b000-7f6c6697c000 rw-p 00000000 00:00 0
7f6c6697c000-7f6c669a1000 r-xp 00000000 fd:00 107488132 /usr/lib64/liblzma.so.5.2.2
7f6c669a1000-7f6c66ba0000 —p 00025000 fd:00 107488132 /usr/lib64/liblzma.so.5.2.2
7f6c66ba0000-7f6c66ba1000 r–p 00024000 fd:00 107488132 /usr/lib64/liblzma.so.5.2.2
7f6c66ba1000-7f6c66ba2000 rw-p 00000000 00:00 0
7f6c66ba2000-7f6c66ba6000 r-xp 00000000 fd:00 107487725 /usr/lib64/libcap.so.2.25
7f6c66ba6000-7f6c66da5000 —p 00004000 fd:00 107487725 /usr/lib64/libcap.so.2.25
7f6c66da5000-7f6c66da6000 r–p 00003000 fd:00 107487725 /usr/lib64/libcap.so.2.25
7f6c66da6000-7f6c66da7000 rw-p 00004000 fd:00 107487725 /usr/lib64/libcap.so.2.25
7f6c66da7000-7f6c66e2d000 r-xp 00000000 fd:00 107487200 /usr/lib64/libsystemd.so.0.16.0
7f6c66e2d000-7f6c66e30000 r–p 00085000 fd:00 107487200 /usr/lib64/libsystemd.so.0.16.0
7f6c66e30000-7f6c66e31000 rw-p 00088000 fd:00 107487200 /usr/lib64/libsystemd.so.0.16.0
7f6c66e31000-7f6c66e32000 rw-p 00000000 00:00 0
7f6c66e32000-7f6c66e94000 r-xp 00000000 fd:00 107486872 /usr/lib64/libibus-1.0.so.5.0.514
7f6c66e94000-7f6c67094000 —p 00062000 fd:00 107486872 /usr/lib64/libibus-1.0.so.5.0.514
7f6c67094000-7f6c67097000 r–p 00062000 fd:00 107486872 /usr/lib64/libibus-1.0.so.5.0.514
7f6c67097000-7f6c67098000 rw-p 00065000 fd:00 107486872 /usr/lib64/libibus-1.0.so.5.0.514
7f6c67098000-7f6c670e6000 r-xp 00000000 fd:00 107486621 /usr/lib64/libdbus-1.so.3.16.4
7f6c670e6000-7f6c672e5000 —p 0004e000 fd:00 107486621 /usr/lib64/libdbus-1.so.3.16.4
7f6c672e5000-7f6c672e7000 r–p 0004d000 fd:00 107486621 /usr/lib64/libdbus-1.so.3.16.4
7f6c672e7000-7f6c672e8000 rw-p 0004f000 fd:00 107486621 /usr/lib64/libdbus-1.so.3.16.4
7f6c672e8000-7f6c672ee000 r-xp 00000000 fd:00 108004073 /usr/lib64/gtk-2.0/2.10.0/immodules/im-ibus.so
7f6c672ee000-7f6c674ee000 —p 00006000 fd:00 108004073 /usr/lib64/gtk-2.0/2.10.0/immodules/im-ibus.so
7f6c674ee000-7f6c674ef000 r–p 00006000 fd:00 108004073 /usr/lib64/gtk-2.0/2.10.0/immodules/im-ibus.so
7f6c674ef000-7f6c674f0000 rw-p 00007000 fd:00 108004073 /usr/lib64/gtk-2.0/2.10.0/immodules/im-ibus.so
7f6c674f0000-7f6c674f9000 r-xp 00000000 fd:00 116262490 /usr/local/cuda-8.0/libnsight/configuration/org.eclipse.osgi/300/0/.cp/libswt-cairo-gtk-4430.so
7f6c674f9000-7f6c676f9000 —p 00009000 fd:00 116262490 /usr/local/cuda-8.0/libnsight/configuration/org.eclipse.osgi/300/0/.cp/libswt-cairo-gtk-4430.so
7f6c676f9000-7f6c676fa000 rw-p 00009000 fd:00 116262490 /usr/local/cuda-8.0/libnsight/configuration/org.eclipse.osgi/300/0/.cp/libswt-cairo-gtk-4430.so
7f6c676fa000-7f6c676ff000 r-xp 00000000 fd:00 107487625 /usr/lib64/libXtst.so.6.1.0
7f6c676ff000-7f6c678fe000 —p 00005000 fd:00 107487625 /usr/lib64/libXtst.so.6.1.0
7f6c678fe000-7f6c678ff000 r–p 00004000 fd:00 107487625 /usr/lib64/libXtst.so.6.1.0
7f6c678ff000-7f6c67900000 rw-p 00005000 fd:00 107487625 /usr/lib64/libXtst.so.6.1.0
7f6c67900000-7f6c67974000 r-xp 00000000 fd:00 116262489 /usr/local/cuda-8.0/libnsight/configuration/org.eclipse.osgi/300/0/.cp/libswt-pi-gtk-4430.so
7f6c67974000-7f6c67b74000 —p 00074000 fd:00 116262489 /usr/local/cuda-8.0/libnsight/configuration/org.eclipse.osgi/300/0/.cp/libswt-pi-gtk-4430.so
7f6c67b74000-7f6c67b77000 rw-p 00074000 fd:00 116262489 /usr/local/cuda-8.0/libnsight/configuration/org.eclipse.osgi/300/0/.cp/libswt-pi-gtk-4430.so
7f6c67b77000-7f6c67b79000 rw-p 00000000 00:00 0
7f6c67b79000-7f6c67bf7000 r-xp 00000000 fd:00 116262488 /usr/local/cuda-8.0/libnsight/configuration/org.eclipse.osgi/300/0/.cp/libswt-gtk-4430.so
7f6c67bf7000-7f6c67df6000 —p 0007e000 fd:00 116262488 /usr/local/cuda-8.0/libnsight/configuration/org.eclipse.osgi/300/0/.cp/libswt-gtk-4430.so
7f6c67df6000-7f6c67dfe000 rw-p 0007d000 fd:00 116262488 /usr/local/cuda-8.0/libnsight/configuration/org.eclipse.osgi/300/0/.cp/libswt-gtk-4430.so
7f6c67dfe000-7f6c68000000 rw-p 00000000 00:00 0
7f6c68000000-7f6c68021000 rw-p 00000000 00:00 0
7f6c68021000-7f6c6c000000 —p 00000000 00:00 0
7f6c6c019000-7f6c6c02a000 r–p 00000000 fd:00 108660722 /usr/share/fonts/abattis-cantarell/Cantarell-Regular.otf
7f6c6c02a000-7f6c6c02d000 —p 00000000 00:00 0
7f6c6c02d000-7f6c6c12b000 rw-p 00000000 00:00 0
7f6c6c12b000-7f6c6c186000 r–s 009e2000 fd:00 116001725 /usr/local/cuda-8.0/libnsight/plugins/com.ibm.icu_52.1.0.v201404241930.jar
7f6c6c186000-7f6c6c189000 —p 00000000 00:00 0
7f6c6c189000-7f6c6c487000 rw-p 00000000 00:00 0
7f6c6c487000-7f6c6c48a000 —p 00000000 00:00 0
7f6c6c48a000-7f6c6c588000 rw-p 00000000 00:00 0
7f6c6c588000-7f6c6c5cc000 r–s 00390000 fd:00 116002730 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.ui.workbench_3.106.1.v20140827-1737.jar
7f6c6c5cc000-7f6c6c5cf000 —p 00000000 00:00 0
7f6c6c5cf000-7f6c6c8cd000 rw-p 00000000 00:00 0
7f6c6c8cd000-7f6c6c8d0000 —p 00000000 00:00 0
7f6c6c8d0000-7f6c6c9ce000 rw-p 00000000 00:00 0
7f6c6c9ce000-7f6c6c9d1000 —p 00000000 00:00 0
7f6c6c9d1000-7f6c6cccf000 rw-p 00000000 00:00 0
7f6c6cccf000-7f6c6ccd2000 —p 00000000 00:00 0
7f6c6ccd2000-7f6c6cdd0000 rw-p 00000000 00:00 0
7f6c6cdd0000-7f6c6cdd3000 —p 00000000 00:00 0
7f6c6cdd3000-7f6c6ced1000 rw-p 00000000 00:00 0
7f6c6ced1000-7f6c6ced4000 —p 00000000 00:00 0
7f6c6ced4000-7f6c6cfd2000 rw-p 00000000 00:00 0
7f6c6cfd2000-7f6c6cfd7000 r-xp 00000000 fd:00 107489469 /usr/lib64/libnss_dns-2.24.so
7f6c6cfd7000-7f6c6d1d7000 —p 00005000 fd:00 107489469 /usr/lib64/libnss_dns-2.24.so
7f6c6d1d7000-7f6c6d1d8000 r–p 00005000 fd:00 107489469 /usr/lib64/libnss_dns-2.24.so
7f6c6d1d8000-7f6c6d1d9000 rw-p 00006000 fd:00 107489469 /usr/lib64/libnss_dns-2.24.so
7f6c6d1d9000-7f6c6d1db000 r-xp 00000000 fd:00 107488215 /usr/lib64/libnss_mdns4_minimal.so.2
7f6c6d1db000-7f6c6d3da000 —p 00002000 fd:00 107488215 /usr/lib64/libnss_mdns4_minimal.so.2
7f6c6d3da000-7f6c6d3db000 r–p 00001000 fd:00 107488215 /usr/lib64/libnss_mdns4_minimal.so.2
7f6c6d3db000-7f6c6d3dc000 rw-p 00000000 00:00 0
7f6c6d3dc000-7f6c6d3ed000 r-xp 00000000 fd:00 114688591 /usr/java/jdk1.8.0_131/jre/lib/amd64/libnio.so
7f6c6d3ed000-7f6c6d5ec000 —p 00011000 fd:00 114688591 /usr/java/jdk1.8.0_131/jre/lib/amd64/libnio.so
7f6c6d5ec000-7f6c6d5ed000 rw-p 00010000 fd:00 114688591 /usr/java/jdk1.8.0_131/jre/lib/amd64/libnio.so
7f6c6d5ed000-7f6c6d603000 r-xp 00000000 fd:00 114688590 /usr/java/jdk1.8.0_131/jre/lib/amd64/libnet.so
7f6c6d603000-7f6c6d803000 —p 00016000 fd:00 114688590 /usr/java/jdk1.8.0_131/jre/lib/amd64/libnet.so
7f6c6d803000-7f6c6d804000 rw-p 00016000 fd:00 114688590 /usr/java/jdk1.8.0_131/jre/lib/amd64/libnet.so
7f6c6d804000-7f6c6d808000 r-xp 00000000 fd:00 108003803 /usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-bmp.so
7f6c6d808000-7f6c6da07000 —p 00004000 fd:00 108003803 /usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-bmp.so
7f6c6da07000-7f6c6da08000 r–p 00003000 fd:00 108003803 /usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-bmp.so
7f6c6da08000-7f6c6da09000 rw-p 00004000 fd:00 108003803 /usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-bmp.so
7f6c6da09000-7f6c6da0b000 r-xp 00000000 fd:00 107487876 /usr/lib64/libfreebl3.so
7f6c6da0b000-7f6c6dc0a000 —p 00002000 fd:00 107487876 /usr/lib64/libfreebl3.so
7f6c6dc0a000-7f6c6dc0b000 r–p 00001000 fd:00 107487876 /usr/lib64/libfreebl3.so
7f6c6dc0b000-7f6c6dc0c000 rw-p 00002000 fd:00 107487876 /usr/lib64/libfreebl3.so
7f6c6dc0c000-7f6c6dc13000 r-xp 00000000 fd:00 107490404 /usr/lib64/libcrypt-nss-2.24.so
7f6c6dc13000-7f6c6de12000 —p 00007000 fd:00 107490404 /usr/lib64/libcrypt-nss-2.24.so
7f6c6de12000-7f6c6de13000 r–p 00006000 fd:00 107490404 /usr/lib64/libcrypt-nss-2.24.so
7f6c6de13000-7f6c6de14000 rw-p 00007000 fd:00 107490404 /usr/lib64/libcrypt-nss-2.24.so
7f6c6de14000-7f6c6de42000 rw-p 00000000 00:00 0
7f6c6de42000-7f6c6de48000 r-xp 00000000 fd:00 107488232 /usr/lib64/libogg.so.0.8.2
7f6c6de48000-7f6c6e047000 —p 00006000 fd:00 107488232 /usr/lib64/libogg.so.0.8.2
7f6c6e047000-7f6c6e048000 r–p 00005000 fd:00 107488232 /usr/lib64/libogg.so.0.8.2
7f6c6e048000-7f6c6e049000 rw-p 00000000 00:00 0
7f6c6e049000-7f6c6e074000 r-xp 00000000 fd:00 107487289 /usr/lib64/libvorbis.so.0.4.8
7f6c6e074000-7f6c6e273000 —p 0002b000 fd:00 107487289 /usr/lib64/libvorbis.so.0.4.8
7f6c6e273000-7f6c6e274000 r–p 0002a000 fd:00 107487289 /usr/lib64/libvorbis.so.0.4.8
7f6c6e274000-7f6c6e275000 rw-p 00000000 00:00 0
7f6c6e275000-7f6c6e27e000 r-xp 00000000 fd:00 107486938 /usr/lib64/libltdl.so.7.3.1
7f6c6e27e000-7f6c6e47d000 —p 00009000 fd:00 107486938 /usr/lib64/libltdl.so.7.3.1
7f6c6e47d000-7f6c6e47e000 r–p 00008000 fd:00 107486938 /usr/lib64/libltdl.so.7.3.1
7f6c6e47e000-7f6c6e47f000 rw-p 00009000 fd:00 107486938 /usr/lib64/libltdl.so.7.3.1
7f6c6e47f000-7f6c6e494000 r-xp 00000000 fd:00 107487212 /usr/lib64/libtdb.so.1.3.13
7f6c6e494000-7f6c6e693000 —p 00015000 fd:00 107487212 /usr/lib64/libtdb.so.1.3.13
7f6c6e693000-7f6c6e694000 r–p 00014000 fd:00 107487212 /usr/lib64/libtdb.so.1.3.13
7f6c6e694000-7f6c6e695000 rw-p 00015000 fd:00 107487212 /usr/lib64/libtdb.so.1.3.13
7f6c6e695000-7f6c6e69c000 r-xp 00000000 fd:00 107487291 /usr/lib64/libvorbisfile.so.3.3.7
7f6c6e69c000-7f6c6e89c000 —p 00007000 fd:00 107487291 /usr/lib64/libvorbisfile.so.3.3.7
7f6c6e89c000-7f6c6e89d000 r–p 00007000 fd:00 107487291 /usr/lib64/libvorbisfile.so.3.3.7
7f6c6e89d000-7f6c6e89e000 rw-p 00000000 00:00 0
7f6c6e89e000-7f6c6e8af000 r-xp 00000000 fd:00 107487723 /usr/lib64/libcanberra.so.0.2.5
7f6c6e8af000-7f6c6eaae000 —p 00011000 fd:00 107487723 /usr/lib64/libcanberra.so.0.2.5
7f6c6eaae000-7f6c6eaaf000 r–p 00010000 fd:00 107487723 /usr/lib64/libcanberra.so.0.2.5
7f6c6eaaf000-7f6c6eab0000 rw-p 00011000 fd:00 107487723 /usr/lib64/libcanberra.so.0.2.5
7f6c6eab0000-7f6c6eab4000 r-xp 00000000 fd:00 107487721 /usr/lib64/libcanberra-gtk.so.0.1.9
7f6c6eab4000-7f6c6ecb3000 —p 00004000 fd:00 107487721 /usr/lib64/libcanberra-gtk.so.0.1.9
7f6c6ecb3000-7f6c6ecb4000 r–p 00003000 fd:00 107487721 /usr/lib64/libcanberra-gtk.so.0.1.9
7f6c6ecb4000-7f6c6ecb5000 rw-p 00000000 00:00 0
7f6c6ecb5000-7f6c6ecba000 r-xp 00000000 fd:00 108004058 /usr/lib64/gtk-2.0/modules/libcanberra-gtk-module.so
7f6c6ecba000-7f6c6eeba000 —p 00005000 fd:00 108004058 /usr/lib64/gtk-2.0/modules/libcanberra-gtk-module.so
7f6c6eeba000-7f6c6eebb000 r–p 00005000 fd:00 108004058 /usr/lib64/gtk-2.0/modules/libcanberra-gtk-module.so
7f6c6eebb000-7f6c6eebc000 rw-p 00000000 00:00 0
7f6c6eebc000-7f6c6eebd000 r-xp 00000000 fd:00 108004048 /usr/lib64/gtk-2.0/modules/libpk-gtk-module.so
7f6c6eebd000-7f6c6f0bc000 —p 00001000 fd:00 108004048 /usr/lib64/gtk-2.0/modules/libpk-gtk-module.so
7f6c6f0bc000-7f6c6f0bd000 r–p 00000000 fd:00 108004048 /usr/lib64/gtk-2.0/modules/libpk-gtk-module.so
7f6c6f0bd000-7f6c6f0be000 rw-p 00000000 00:00 0
7f6c6f0be000-7f6c6f0c8000 r-xp 00000000 fd:00 108004052 /usr/lib64/gtk-2.0/2.10.0/engines/libpixmap.so
7f6c6f0c8000-7f6c6f2c7000 —p 0000a000 fd:00 108004052 /usr/lib64/gtk-2.0/2.10.0/engines/libpixmap.so
7f6c6f2c7000-7f6c6f2c8000 r–p 00009000 fd:00 108004052 /usr/lib64/gtk-2.0/2.10.0/engines/libpixmap.so
7f6c6f2c8000-7f6c6f2c9000 rw-p 00000000 00:00 0
7f6c6f2c9000-7f6c6f2cb000 r-xp 00000000 fd:00 108003491 /usr/lib64/gtk-2.0/2.10.0/engines/libadwaita.so
7f6c6f2cb000-7f6c6f4cb000 —p 00002000 fd:00 108003491 /usr/lib64/gtk-2.0/2.10.0/engines/libadwaita.so
7f6c6f4cb000-7f6c6f4cc000 r–p 00002000 fd:00 108003491 /usr/lib64/gtk-2.0/2.10.0/engines/libadwaita.so
7f6c6f4cc000-7f6c6f4cd000 rw-p 00000000 00:00 0
7f6c6f4cd000-7f6c6f4d1000 r-xp 00000000 fd:00 107487267 /usr/lib64/libuuid.so.1.3.0
7f6c6f4d1000-7f6c6f6d0000 —p 00004000 fd:00 107487267 /usr/lib64/libuuid.so.1.3.0
7f6c6f6d0000-7f6c6f6d1000 r–p 00003000 fd:00 107487267 /usr/lib64/libuuid.so.1.3.0
7f6c6f6d1000-7f6c6f6d2000 rw-p 00000000 00:00 0
7f6c6f6d2000-7f6c6f70f000 r-xp 00000000 fd:00 107486535 /usr/lib64/libblkid.so.1.1.0
7f6c6f70f000-7f6c6f90f000 —p 0003d000 fd:00 107486535 /usr/lib64/libblkid.so.1.1.0
7f6c6f90f000-7f6c6f913000 r–p 0003d000 fd:00 107486535 /usr/lib64/libblkid.so.1.1.0
7f6c6f913000-7f6c6f914000 rw-p 00041000 fd:00 107486535 /usr/lib64/libblkid.so.1.1.0
7f6c6f914000-7f6c6f915000 rw-p 00000000 00:00 0
7f6c6f918000-7f6c6f923000 r–s 00000000 fd:00 101450069 /var/cache/fontconfig/b79f3aaa7d385a141ab53ec885cc22a8-le64.cache-7
7f6c6f923000-7f6c6f930000 r–s 00000000 fd:00 101451130 /var/cache/fontconfig/8cf84b531759d4484556eb8586bc5925-le64.cache-7
7f6c6f930000-7f6c6f950000 r–s 00000000 fd:00 101451108 /var/cache/fontconfig/02770245eac059faefae62cb0d56fbcb-le64.cache-7
7f6c6f950000-7f6c6f97a000 r–s 00240000 fd:00 116002226 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.ui.ide_3.10.1.v20140828-0944.jar
7f6c6f97a000-7f6c6fdf3000 r-xp 00000000 fd:00 107488006 /usr/lib64/libgtk-x11-2.0.so.0.2400.31
7f6c6fdf3000-7f6c6fff3000 —p 00479000 fd:00 107488006 /usr/lib64/libgtk-x11-2.0.so.0.2400.31
7f6c6fff3000-7f6c6fffd000 r–p 00479000 fd:00 107488006 /usr/lib64/libgtk-x11-2.0.so.0.2400.31
7f6c6fffd000-7f6c6fffe000 rw-p 00483000 fd:00 107488006 /usr/lib64/libgtk-x11-2.0.so.0.2400.31
7f6c6fffe000-7f6c70000000 rw-p 00000000 00:00 0
7f6c70000000-7f6c70021000 rw-p 00000000 00:00 0
7f6c70021000-7f6c74000000 —p 00000000 00:00 0
7f6c74002000-7f6c74004000 r–s 00000000 fd:00 101451081 /var/cache/fontconfig/87f5e051180a7a75f16eb6fe7dbd3749-le64.cache-7
7f6c74004000-7f6c74006000 r–s 00000000 fd:00 101451133 /var/cache/fontconfig/2e1514a9fdd499050989183bb65136db-le64.cache-7
7f6c74006000-7f6c74008000 r–s 00000000 fd:00 101451132 /var/cache/fontconfig/3f821257dd33660ba7bbb45c32deb84c-le64.cache-7
7f6c74008000-7f6c7400b000 r–s 00000000 fd:00 101451131 /var/cache/fontconfig/b206e14174e2821e837cf852f8b3a00e-le64.cache-7
7f6c7400b000-7f6c7400c000 r–s 00000000 fd:00 101451129 /var/cache/fontconfig/4e602040080c966cb821813a3e584564-le64.cache-7
7f6c7400c000-7f6c7400f000 r–s 00000000 fd:00 101451128 /var/cache/fontconfig/830f035fa84a65ce80e050178dbb630d-le64.cache-7
7f6c7400f000-7f6c74010000 r–s 00000000 fd:00 101451127 /var/cache/fontconfig/81a173283b451552b599cfaafd6236bd-le64.cache-7
7f6c74010000-7f6c74011000 r–s 00000000 fd:00 101451126 /var/cache/fontconfig/ac68f755438cc3dc5a526084839fc7ca-le64.cache-7
7f6c74011000-7f6c74012000 r–s 00000000 fd:00 101451125 /var/cache/fontconfig/f951a6bc01c50d58ac4af16a0108457e-le64.cache-7
7f6c74012000-7f6c74013000 r–s 00000000 fd:00 101451124 /var/cache/fontconfig/8cab66d8f642305e525ba3e322d0979c-le64.cache-7
7f6c74013000-7f6c74014000 r–s 00000000 fd:00 101451123 /var/cache/fontconfig/12513961c6e7090f8648812f9eaf65d6-le64.cache-7
7f6c74014000-7f6c74017000 r–s 00000000 fd:00 101451122 /var/cache/fontconfig/e26bf336397aae6fcef4d3803472adec-le64.cache-7
7f6c74017000-7f6c74022000 r–s 00084000 fd:00 116002729 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.ui.workbench.texteditor_3.9.0.v20140411-1521.jar
7f6c74022000-7f6c7402d000 r–s 00082000 fd:00 116002222 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.ui.editors_3.8.200.v20140401-1310.jar
7f6c7402d000-7f6c74049000 r–s 00144000 fd:00 116002216 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.team.ui_3.7.100.v20130710-1213.jar
7f6c74049000-7f6c74067000 r–s 00180000 fd:00 116002215 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.team.cvs.ui_3.3.600.v20130514-1224.jar
7f6c74067000-7f6c74068000 r–s 00000000 fd:00 101451121 /var/cache/fontconfig/f132fa2327207a6ac3298c0518879731-le64.cache-7
7f6c74068000-7f6c74069000 r–s 00000000 fd:00 101451120 /var/cache/fontconfig/6fcb01a03a016cc71057b587cdea6709-le64.cache-7
7f6c74069000-7f6c7406d000 r–s 00000000 fd:00 101451119 /var/cache/fontconfig/8aa05f52519ebacbdf5713e01a6153b0-le64.cache-7
7f6c7406d000-7f6c7406e000 r–s 00000000 fd:00 101451118 /var/cache/fontconfig/b887eea8f1b96e1d899b44ed6681fc27-le64.cache-7
7f6c7406e000-7f6c7406f000 r–s 00000000 fd:00 101451117 /var/cache/fontconfig/860639f272b8b4b3094f9e399e41bccd-le64.cache-7
7f6c7406f000-7f6c74070000 r–s 00000000 fd:00 101451116 /var/cache/fontconfig/5d33f04e74a97395cf88bbd83847f1f1-le64.cache-7
7f6c74070000-7f6c74071000 r–s 00000000 fd:00 101451115 /var/cache/fontconfig/df893b4576ad6107f9397134092c4059-le64.cache-7
7f6c74071000-7f6c74072000 r–s 00000000 fd:00 101451114 /var/cache/fontconfig/1e1e03b57ed9f0c723c5aeafda46c3fb-le64.cache-7
7f6c74072000-7f6c74073000 r–s 00000000 fd:00 101451113 /var/cache/fontconfig/900402270e15d763a6e008bb2d4c7686-le64.cache-7
7f6c74073000-7f6c74074000 r–s 00000000 fd:00 101451112 /var/cache/fontconfig/47f48679023f44a4d1e44699a69464f6-le64.cache-7
7f6c74074000-7f6c74075000 r–s 00000000 fd:00 101451111 /var/cache/fontconfig/2881ed3fd21ca306ddad6f9b0dd3189f-le64.cache-7
7f6c74075000-7f6c74076000 r–s 00000000 fd:00 101451110 /var/cache/fontconfig/3c3fb04d32a5211b073874b125d29701-le64.cache-7
7f6c74076000-7f6c74077000 r–s 00000000 fd:00 101451109 /var/cache/fontconfig/aa1e7e339e8ba54420bca0caa86a076f-le64.cache-7
7f6c74077000-7f6c74078000 r–s 00000000 fd:00 101451107 /var/cache/fontconfig/e61abf8156cc476151baa07d67337cae-le64.cache-7
7f6c74078000-7f6c7407d000 r–s 00000000 fd:00 101451106 /var/cache/fontconfig/b67b32625a2bb51b023d3814a918f351-le64.cache-7
7f6c7407d000-7f6c7407f000 r–s 00000000 fd:00 101451105 /var/cache/fontconfig/d3379abda271c4acd2ad0c01f565d0b0-le64.cache-7
7f6c7407f000-7f6c74086000 r–s 0004a000 fd:00 116002220 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.ui.cheatsheets_3.4.200.v20131227-1524.jar
7f6c74086000-7f6c7408f000 r–s 00086000 fd:00 116002213 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.team.cvs.core_3.3.600.v20131112-1442.jar
7f6c7408f000-7f6c740a4000 r–s 00266000 fd:00 116002210 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.swt.gtk.linux.x86_64_3.103.1.v20140903-1947.jar
7f6c740a4000-7f6c740ae000 r–s 0006a000 fd:00 116002209 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.search_3.9.100.v20140226-1637.jar
7f6c740ae000-7f6c740c8000 r–s 0017f000 fd:00 116002208 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.rse.ui_3.3.100.201404091417.jar
7f6c740c8000-7f6c740ca000 r–s 00003000 fd:00 116002204 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.rse.subsystems.shells.telnet_1.2.300.201403100950.jar
7f6c740ca000-7f6c740cc000 r–s 00003000 fd:00 116002203 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.rse.subsystems.shells.ssh_2.1.400.201403100950.jar
7f6c740cc000-7f6c740d0000 r–s 0001e000 fd:00 116002194 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.rse.subsystems.files.core_3.3.1.201403100950.jar
7f6c740d0000-7f6c740d3000 r–s 00052000 fd:00 116002187 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.rse.services.dstore_3.3.0.201406041609.jar
7f6c740d3000-7f6c740da000 r–s 00061000 fd:00 116002192 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.rse.services_3.3.0.nvidia-qualifier.jar
7f6c740da000-7f6c740dd000 r–s 00010000 fd:00 116002186 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.rse.processes.ui_3.0.400.201403100950.jar
7f6c740dd000-7f6c740e2000 r–s 00035000 fd:00 116002185 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.rse.importexport_1.2.300.201403100950.jar
7f6c740e2000-7f6c740ea000 r–s 00071000 fd:00 116002184 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.rse.files.ui_3.2.200.201403211850.jar
7f6c74101000-7f6c74181000 rw-s 00000000 00:05 9109536 /SYSV00000000 (deleted)
7f6c74181000-7f6c741a3000 r-xp 00000000 fd:00 107487655 /usr/lib64/libatk-1.0.so.0.22209.1
7f6c741a3000-7f6c743a3000 —p 00022000 fd:00 107487655 /usr/lib64/libatk-1.0.so.0.22209.1
7f6c743a3000-7f6c743a6000 r–p 00022000 fd:00 107487655 /usr/lib64/libatk-1.0.so.0.22209.1
7f6c743a6000-7f6c743a7000 rw-p 00025000 fd:00 107487655 /usr/lib64/libatk-1.0.so.0.22209.1
7f6c743a7000-7f6c743bd000 r-xp 00000000 fd:00 107486200 /usr/lib64/libgcc_s-6.3.1-20161221.so.1
7f6c743bd000-7f6c745bc000 —p 00016000 fd:00 107486200 /usr/lib64/libgcc_s-6.3.1-20161221.so.1
7f6c745bc000-7f6c745bd000 r–p 00015000 fd:00 107486200 /usr/lib64/libgcc_s-6.3.1-20161221.so.1
7f6c745bd000-7f6c745be000 rw-p 00016000 fd:00 107486200 /usr/lib64/libgcc_s-6.3.1-20161221.so.1
7f6c745be000-7f6c7462c000 r-xp 00000000 fd:00 107489556 /usr/lib64/libGLdispatch.so.0.0.0
7f6c7462c000-7f6c7482b000 —p 0006e000 fd:00 107489556 /usr/lib64/libGLdispatch.so.0.0.0
7f6c7482b000-7f6c74853000 r–p 0006d000 fd:00 107489556 /usr/lib64/libGLdispatch.so.0.0.0
7f6c74853000-7f6c74854000 rw-p 00095000 fd:00 107489556 /usr/lib64/libGLdispatch.so.0.0.0
7f6c74854000-7f6c74874000 rw-p 00000000 00:00 0
7f6c74874000-7f6c748bb000 r-xp 00000000 fd:00 107486969 /usr/lib64/libmount.so.1.1.0
7f6c748bb000-7f6c74aba000 —p 00047000 fd:00 107486969 /usr/lib64/libmount.so.1.1.0
7f6c74aba000-7f6c74abc000 r–p 00046000 fd:00 107486969 /usr/lib64/libmount.so.1.1.0
7f6c74abc000-7f6c74abd000 rw-p 00048000 fd:00 107486969 /usr/lib64/libmount.so.1.1.0
7f6c74abd000-7f6c74abe000 rw-p 00000000 00:00 0
7f6c74abe000-7f6c74ad5000 r-xp 00000000 fd:00 107489472 /usr/lib64/libresolv-2.24.so
7f6c74ad5000-7f6c74cd5000 —p 00017000 fd:00 107489472 /usr/lib64/libresolv-2.24.so
7f6c74cd5000-7f6c74cd6000 r–p 00017000 fd:00 107489472 /usr/lib64/libresolv-2.24.so
7f6c74cd6000-7f6c74cd7000 rw-p 00018000 fd:00 107489472 /usr/lib64/libresolv-2.24.so
7f6c74cd7000-7f6c74cd9000 rw-p 00000000 00:00 0
7f6c74cd9000-7f6c74cfc000 r-xp 00000000 fd:00 107487483 /usr/lib64/libselinux.so.1
7f6c74cfc000-7f6c74efc000 —p 00023000 fd:00 107487483 /usr/lib64/libselinux.so.1
7f6c74efc000-7f6c74efd000 r–p 00023000 fd:00 107487483 /usr/lib64/libselinux.so.1
7f6c74efd000-7f6c74efe000 rw-p 00024000 fd:00 107487483 /usr/lib64/libselinux.so.1
7f6c74efe000-7f6c74f00000 rw-p 00000000 00:00 0
7f6c74f00000-7f6c74f72000 r-xp 00000000 fd:00 107487065 /usr/lib64/libpcre.so.1.2.8
7f6c74f72000-7f6c75171000 —p 00072000 fd:00 107487065 /usr/lib64/libpcre.so.1.2.8
7f6c75171000-7f6c75172000 r–p 00071000 fd:00 107487065 /usr/lib64/libpcre.so.1.2.8
7f6c75172000-7f6c75173000 rw-p 00072000 fd:00 107487065 /usr/lib64/libpcre.so.1.2.8
7f6c75173000-7f6c7517a000 r-xp 00000000 fd:00 107487863 /usr/lib64/libffi.so.6.0.2
7f6c7517a000-7f6c75379000 —p 00007000 fd:00 107487863 /usr/lib64/libffi.so.6.0.2
7f6c75379000-7f6c7537a000 r–p 00006000 fd:00 107487863 /usr/lib64/libffi.so.6.0.2
7f6c7537a000-7f6c7537b000 rw-p 00007000 fd:00 107487863 /usr/lib64/libffi.so.6.0.2
7f6c7537b000-7f6c7537d000 r–s 00003000 fd:00 116002202 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.rse.subsystems.shells.local_2.1.400.201403100950.jar
7f6c7537d000-7f6c7537f000 r–s 00004000 fd:00 116002182 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.rse.efs.ui_2.1.400.201403100950.jar
7f6c7537f000-7f6c75381000 r–s 00007000 fd:00 116002183 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.rse.efs_2.1.401.201403100950.jar
7f6c75381000-7f6c75383000 r–s 00033000 fd:00 116002181 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.rse.doc.user_3.4.100.201403101646.jar
7f6c75383000-7f6c7538b000 r–s 0005c000 fd:00 116002180 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.rse.core_3.3.100.201406091451.jar
7f6c7538b000-7f6c7538d000 r–s 00005000 fd:00 116002179 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.rse.connectorservice.telnet_1.2.300.201403100950.jar
7f6c7538d000-7f6c7538f000 r–s 00008000 fd:00 116002178 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.rse.connectorservice.ssh_2.1.300.201403100950.jar
7f6c7538f000-7f6c75391000 r–s 0000f000 fd:00 116002176 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.rse.connectorservice.dstore_3.1.301.201403100950.jar
7f6c75391000-7f6c75394000 r–s 0001c000 fd:00 116002175 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.remote.ui_1.1.0.201409111520.jar
7f6c75396000-7f6c753b3000 r–s 00000000 fd:00 101451104 /var/cache/fontconfig/e34b99a1e22e6f7451938fb9934274e6-le64.cache-7
7f6c753b3000-7f6c753b4000 r–s 00000000 fd:00 101451103 /var/cache/fontconfig/b4d0b56f766d89640448751fcd18ec1e-le64.cache-7
7f6c753b4000-7f6c753b5000 r–s 00000000 fd:00 101451102 /var/cache/fontconfig/30c5f4a3fa007ce7189acb0c5244d5e0-le64.cache-7
7f6c753b5000-7f6c753b8000 r–s 00000000 fd:00 101451100 /var/cache/fontconfig/7ee6df7a8311986241317a58487e0145-le64.cache-7
7f6c753b8000-7f6c753cb000 r–s 00000000 fd:00 101451096 /var/cache/fontconfig/614d1caaa4d7914789410f6367de37ca-le64.cache-7
7f6c753cb000-7f6c753d6000 r–s 00000000 fd:00 101451090 /var/cache/fontconfig/12b26b760a24f8b4feb03ad48a333a72-le64.cache-7
7f6c753d6000-7f6c753e6000 r-xp 00000000 fd:00 107489826 /usr/lib64/libGLX.so.0.0.0
7f6c753e6000-7f6c755e5000 —p 00010000 fd:00 107489826 /usr/lib64/libGLX.so.0.0.0
7f6c755e5000-7f6c755e6000 r–p 0000f000 fd:00 107489826 /usr/lib64/libGLX.so.0.0.0
7f6c755e6000-7f6c755e7000 rw-p 00010000 fd:00 107489826 /usr/lib64/libGLX.so.0.0.0
7f6c755e7000-7f6c75607000 rw-p 00000000 00:00 0
7f6c75607000-7f6c7561c000 r-xp 00000000 fd:00 107488609 /usr/lib64/libz.so.1.2.8
7f6c7561c000-7f6c7581b000 —p 00015000 fd:00 107488609 /usr/lib64/libz.so.1.2.8
7f6c7581b000-7f6c7581c000 r–p 00014000 fd:00 107488609 /usr/lib64/libz.so.1.2.8
7f6c7581c000-7f6c7581d000 rw-p 00015000 fd:00 107488609 /usr/lib64/libz.so.1.2.8
7f6c7581d000-7f6c7581e000 r–s 00003000 fd:00 116002177 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.rse.connectorservice.local_2.1.400.201403100950.jar
7f6c7581e000-7f6c75820000 r–s 00000000 fd:00 101451101 /var/cache/fontconfig/b14e78aa9400ae7a28193faee1d62280-le64.cache-7
7f6c75820000-7f6c75822000 r–s 00000000 fd:00 101451099 /var/cache/fontconfig/99a1ce9f8b6a0434aadb01d3779b0780-le64.cache-7
7f6c75822000-7f6c75824000 r–s 00000000 fd:00 101451098 /var/cache/fontconfig/f9d379b867d7c69c85310a4f24e5228f-le64.cache-7
7f6c75824000-7f6c75825000 r–s 00000000 fd:00 101451097 /var/cache/fontconfig/a0c19c2c21e758d73376b5942921cc72-le64.cache-7
7f6c75825000-7f6c75826000 r–s 00000000 fd:00 101451095 /var/cache/fontconfig/0f80fa86029ae75a63f21d682b864529-le64.cache-7
7f6c75826000-7f6c7582d000 r–s 00000000 fd:00 101451016 /var/cache/fontconfig/a116919b8bdb14ffaacd61d02e607fb8-le64.cache-7
7f6c7582d000-7f6c75832000 r–s 00000000 fd:00 101451014 /var/cache/fontconfig/a289f7e03715303a9a1b010d74c00c6a-le64.cache-7
7f6c75832000-7f6c75834000 r–s 00000000 fd:00 101451006 /var/cache/fontconfig/3640555adad8a8f6978400293cfce7ab-le64.cache-7
7f6c75834000-7f6c75838000 r–s 00000000 fd:00 101451134 /var/cache/fontconfig/beeeeb3dfe132a8a0633a017c99ce0c0-le64.cache-7
7f6c75838000-7f6c7583f000 r–s 00050000 fd:00 116001982 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.emf.common_2.10.1.v20140901-1043.jar
7f6c7583f000-7f6c75846000 r–s 00055000 fd:00 116001962 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.e4.ui.model.workbench_1.1.0.v20140512-1820.jar
7f6c75846000-7f6c75848000 r-xp 00000000 fd:00 107487607 /usr/lib64/libXau.so.6.0.0
7f6c75848000-7f6c75a48000 —p 00002000 fd:00 107487607 /usr/lib64/libXau.so.6.0.0
7f6c75a48000-7f6c75a49000 r–p 00002000 fd:00 107487607 /usr/lib64/libXau.so.6.0.0
7f6c75a49000-7f6c75a4a000 rw-p 00000000 00:00 0
7f6c75a4a000-7f6c75a59000 r-xp 00000000 fd:00 107486546 /usr/lib64/libbz2.so.1.0.6
7f6c75a59000-7f6c75c58000 —p 0000f000 fd:00 107486546 /usr/lib64/libbz2.so.1.0.6
7f6c75c58000-7f6c75c59000 r–p 0000e000 fd:00 107486546 /usr/lib64/libbz2.so.1.0.6
7f6c75c59000-7f6c75c5a000 rw-p 0000f000 fd:00 107486546 /usr/lib64/libbz2.so.1.0.6
7f6c75c5a000-7f6c75c83000 r-xp 00000000 fd:00 107487961 /usr/lib64/libgraphite2.so.3.0.1
7f6c75c83000-7f6c75e83000 —p 00029000 fd:00 107487961 /usr/lib64/libgraphite2.so.3.0.1
7f6c75e83000-7f6c75e85000 r–p 00029000 fd:00 107487961 /usr/lib64/libgraphite2.so.3.0.1
7f6c75e85000-7f6c75e86000 rw-p 00000000 00:00 0
7f6c75e86000-7f6c75e8c000 r-xp 00000000 fd:00 107487788 /usr/lib64/libdatrie.so.1.3.2
7f6c75e8c000-7f6c7608c000 —p 00006000 fd:00 107487788 /usr/lib64/libdatrie.so.1.3.2
7f6c7608c000-7f6c7608d000 r–p 00006000 fd:00 107487788 /usr/lib64/libdatrie.so.1.3.2
7f6c7608d000-7f6c7608e000 rw-p 00000000 00:00 0
7f6c7608e000-7f6c760ff000 r-xp 00000000 fd:00 107486356 /usr/lib64/libGL.so.1.0.0
7f6c760ff000-7f6c762fe000 —p 00071000 fd:00 107486356 /usr/lib64/libGL.so.1.0.0
7f6c762fe000-7f6c76318000 r–p 00070000 fd:00 107486356 /usr/lib64/libGL.so.1.0.0
7f6c76318000-7f6c76319000 rw-p 0008a000 fd:00 107486356 /usr/lib64/libGL.so.1.0.0
7f6c76319000-7f6c7631a000 rw-p 00000000 00:00 0
7f6c7631a000-7f6c76326000 r-xp 00000000 fd:00 107488560 /usr/lib64/libxcb-render.so.0.0.0
7f6c76326000-7f6c76526000 —p 0000c000 fd:00 107488560 /usr/lib64/libxcb-render.so.0.0.0
7f6c76526000-7f6c76527000 r–p 0000c000 fd:00 107488560 /usr/lib64/libxcb-render.so.0.0.0
7f6c76527000-7f6c76528000 rw-p 0000d000 fd:00 107488560 /usr/lib64/libxcb-render.so.0.0.0
7f6c76528000-7f6c7654f000 r-xp 00000000 fd:00 107488576 /usr/lib64/libxcb.so.1.1.0
7f6c7654f000-7f6c7674e000 —p 00027000 fd:00 107488576 /usr/lib64/libxcb.so.1.1.0
7f6c7674e000-7f6c7674f000 r–p 00026000 fd:00 107488576 /usr/lib64/libxcb.so.1.1.0
7f6c7674f000-7f6c76750000 rw-p 00027000 fd:00 107488576 /usr/lib64/libxcb.so.1.1.0
7f6c76750000-7f6c76753000 r-xp 00000000 fd:00 107486767 /usr/lib64/libgmodule-2.0.so.0.5000.3
7f6c76753000-7f6c76952000 —p 00003000 fd:00 107486767 /usr/lib64/libgmodule-2.0.so.0.5000.3
7f6c76952000-7f6c76953000 r–p 00002000 fd:00 107486767 /usr/lib64/libgmodule-2.0.so.0.5000.3
7f6c76953000-7f6c76954000 rw-p 00003000 fd:00 107486767 /usr/lib64/libgmodule-2.0.so.0.5000.3
7f6c76954000-7f6c76956000 r–s 00000000 fd:00 101450083 /var/cache/fontconfig/b3043b29744cf0a429678d296f5e4026-le64.cache-7
7f6c76956000-7f6c76958000 r–s 0000c000 fd:00 116001955 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.e4.core.di_1.4.0.v20140414-1837.jar
7f6c76958000-7f6c7695b000 r–s 00018000 fd:00 116001914 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.core.commands_3.6.100.v20140528-1422.jar
7f6c7695b000-7f6c76962000 r–s 0003f000 fd:00 116001969 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.e4.ui.workbench_1.2.1.v20140901-1244.jar
7f6c76962000-7f6c76977000 r–s 00107000 fd:00 116002058 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.jface_3.10.1.v20140813-1009.jar
7f6c76977000-7f6c7697b000 r–s 00013000 fd:00 116002067 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.osgi.services_3.4.0.v20140312-2051.jar
7f6c7697b000-7f6c7697d000 r–s 00012000 fd:00 116001842 /usr/local/cuda-8.0/libnsight/plugins/org.apache.felix.gogo.runtime_0.10.0.v201209301036.jar
7f6c7697d000-7f6c76980000 r–s 0000f000 fd:00 116002011 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.equinox.p2.core_2.3.0.v20131211-1531.jar
7f6c76980000-7f6c76982000 r–s 00007000 fd:00 116002014 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.equinox.p2.directorywatcher_1.1.0.v20131211-1531.jar
7f6c76982000-7f6c76985000 r–s 0002d000 fd:00 116001991 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.equinox.ds_1.4.200.v20131126-2331.jar
7f6c76985000-7f6c76987000 r–s 00015000 fd:00 116001939 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.core.runtime.compatibility_3.2.200.v20140128-0851.jar
7f6c76987000-7f6c7698a000 r–s 00013000 fd:00 116001986 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.equinox.app_1.3.200.v20130910-1609.jar
7f6c7698a000-7f6c7698f000 r–s 00037000 fd:00 116002735 /usr/local/cuda-8.0/libnsight/plugins/org.sat4j.pb_2.3.5.v201404071733.jar
7f6c7698f000-7f6c76995000 r–s 00053000 fd:00 116002734 /usr/local/cuda-8.0/libnsight/plugins/org.sat4j.core_2.3.5.v201308161310.jar
7f6c76995000-7f6c7699e000 r–s 000d3000 fd:00 116002733 /usr/local/cuda-8.0/libnsight/plugins/org.mozilla.javascript_1.7.2.v201005080400.jar
7f6c7699e000-7f6c769a7000 r–s 0005a000 fd:00 116002679 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.ui.navigator_3.5.401.v20140724-1117.jar
7f6c769a7000-7f6c769b9000 r-xp 00000000 fd:00 107486353 /usr/lib64/libEGL.so.1.0.0
7f6c769b9000-7f6c76bb8000 —p 00012000 fd:00 107486353 /usr/lib64/libEGL.so.1.0.0
7f6c76bb8000-7f6c76bb9000 r–p 00011000 fd:00 107486353 /usr/lib64/libEGL.so.1.0.0
7f6c76bb9000-7f6c76bba000 rw-p 00012000 fd:00 107486353 /usr/lib64/libEGL.so.1.0.0
7f6c76bba000-7f6c76c5b000 r-xp 00000000 fd:00 107488281 /usr/lib64/libpixman-1.so.0.34.0
7f6c76c5b000-7f6c76e5a000 —p 000a1000 fd:00 107488281 /usr/lib64/libpixman-1.so.0.34.0
7f6c76e5a000-7f6c76e62000 r–p 000a0000 fd:00 107488281 /usr/lib64/libpixman-1.so.0.34.0
7f6c76e62000-7f6c76e63000 rw-p 000a8000 fd:00 107488281 /usr/lib64/libpixman-1.so.0.34.0
7f6c76e63000-7f6c76e64000 r-xp 00000000 fd:00 107486832 /usr/lib64/libgthread-2.0.so.0.5000.3
7f6c76e64000-7f6c77063000 —p 00001000 fd:00 107486832 /usr/lib64/libgthread-2.0.so.0.5000.3
7f6c77063000-7f6c77064000 r–p 00000000 fd:00 107486832 /usr/lib64/libgthread-2.0.so.0.5000.3
7f6c77064000-7f6c77065000 rw-p 00000000 00:00 0
7f6c77065000-7f6c77067000 r–s 0000d000 fd:00 116001841 /usr/local/cuda-8.0/libnsight/plugins/org.apache.felix.gogo.command_0.10.0.v201209301215.jar
7f6c77067000-7f6c77069000 r–s 00016000 fd:00 116001926 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.core.jobs_3.6.0.v20140424-0053.jar
7f6c77069000-7f6c7706d000 r–s 0001c000 fd:00 116002037 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.equinox.preferences_3.5.200.v20140224-1527.jar
7f6c7706d000-7f6c77071000 r–s 00021000 fd:00 116002223 /usr/local/cuda-8.0/libnsight/plugins/org.eclipse.ui.externaltools_3.2.300.v20140327-1949.jar
7f6c77071000-7f6c77073000 r-xp 00000000 fd:00 107488564 /usr/lib64/libxcb-shm.so.0.0.0
7f6c77073000-7f6c77273000 —p 00002000 fd:00 107488564 /usr/lib64/libxcb-shm.so.0.0.0
7f6c77273000-7f6c77274000 r–p 00002000 fd:00 107488564 /usr/lib64/libxcb-shm.so.0.0.0
7f6c77274000-7f6c77275000 rw-p 00003000 fd:00 107488564 /usr/lib64/libxcb-shm.so.0.0.0
7f6c77275000-7f6c772a6000 r-xp 00000000 fd:00 107487085 /usr/lib64/libpng16.so.16.27.0
7f6c772a6000-7f6c774a6000 —p 00031000 fd:00 107487085 /usr/lib64/libpng16.so.16.27.0
7f6c774a6000-7f6c774a7000 r–p 00031000 fd:00 107487085 /usr/lib64/libpng16.so.16.27.0
7f6c774a7000-7f6c774a8000 rw-p 00000000 00:00 0
7f6c774a8000-7f6c774cf000 r-xp 00000000 fd:00 107487856 /usr/lib64/libexpat.so.1.6.2
7f6c774cf000-7f6c776ce000 —p 00027000 fd:00 107487856 /usr/lib64/libexpat.so.1.6.2
7f6c776ce000-7f6c776d1000 r–p 00026000 fd:00 107487856 /usr/lib64/libexpat.so.1.6.2
7f6c776d1000-7f6c776d2000 rw-p 00000000 00:00 0
7f6c776d2000-7f6c77776000 r-xp 00000000 fd:00 107486711 /usr/lib64/libfreetype.so.6.12.5
7f6c77776000-7f6c77976000 —p 000a4000 fd:00 107486711 /usr/lib64/libfreetype.so.6.12.5
7f6c77976000-7f6c7797c000 r–p 000a4000 fd:00 107486711 /usr/lib64/libfreetype.so.6.12.5
7f6c7797c000-7f6c7797d000 rw-p 00000000 00:00 0
7f6c7797d000-7f6c779de000 r-xp 00000000 fd:00 107488028 /usr/lib64/libharfbuzz.so.0.10302.0
7f6c779de000-7f6c77bde000 —p 00061000 fd:00 107488028 /usr/lib64/libharfbuzz.so.0.10302.0
7f6c77bde000-7f6c77be0000 r–p 00061000 fd:00 107488028 /usr/lib64/libharfbuzz.so.0.10302.0
7f6c77be0000-7f6c77be1000 rw-p 00063000 fd:00 107488028 /usr/lib64/libharfbuzz.so.0.10302.0
7f6c77be1000-7f6c77be9000 r-xp 00000000 fd:00 107488443 /usr/lib64/l
