Nsight - Launch Failed. Binary not found
I’ve successfully installed Cuda SDK and tested the compiler with an HelloWorld. Then I’ve opened Nsight and I’ve tried with the same code. I got this answer " Launch Failed. Binary not found." How could solve the problem ?
Thank you!
Hi sebastianstefaniga,
Could you tell me more about your steps, I’m not quit sure what you did and it’s hard for me to help you.
