'nsight-system' not found in jetpack5.0.1
I installed jetpack5.0.1 on Xavier NX and when I use nsys I got the following error:
mec@mec-desktop:/$ nsys -h
-bash: nsys: command not found
Any idea?Thanks.
Nsight System is located at /opt/ rather than the CUDA library.
Could you try the following command?
$ sudo apt install nvidia-nsight-sys
$ /opt/nvidia/nsight-systems-cli/2021.5.4/bin/nsys --version
Hi, AastaLLL:
i tried:
But I still don’t have nsys:
Do you want to run it on XavierNX or a desktop machine?
The command shared above is for the Jetson device.
