I am profiling a target x86 machine with CUDA 10.0 and cuDNN 7.6.1.34-1.
In profiles Timeline View I see no cuDNN events.
In Diagnostics Summary there is a message:
“Tracing libToolsInjectionCuDNN64_7_6.so library version 7.6 is currently not supported, library name: … .local/share/nsight_systems/libToolsInjectionCuDNN64_7_6.so, error: … .local/share/nsight_systems/libToolsInjectionCuDNN64_7_6.so: cannot open shared object file: No such file or directory”
And indeed, I have only .so files for the latest cudnn version being libToolsInjectionCuDNN64_7_4.so.
Does Nsight Systems support cuDNN 7.5 and 7.6?
Regards,
Peter
What version of Nsight Systems are you using?
I was using 2019.2.1 GUI on Mac OS to remotely profile applications on a Linux host.
Now I am trying to use the latest version - 2019.4.
Installing on a Linux host with NVDRV:410.78, CUDA:10.0, cuDNN:7.6.1.34-1.
Installed CLI-only package with:
$ sudo dpkg -i NVIDIA_Nsight_Systems_Linux_CLI_Only_2019.4.2.135.deb
Now I always get segmentation faults.
$ nsys profile python cifar100_VGG.py -b 300 -e 1 --iterations 1
**** collection configuration ****
force-overwrite = false
stop-on-exit = true
export_sqlite = false
stats = false
capture-range = none
stop-on-range-end = false
Beta: ftrace events:
ftrace-keep-user-config = false
delay = 0 seconds
duration = 0 seconds
kill = none
inherit-environment = true
show-output = true
trace-fork-before-exec = false
sample_cpu = true
backtrace_method = LBR
wait = all
trace_cublas = false
trace_cuda = true
trace_cudnn = false
trace_nvtx = true
trace_mpi = false
trace_openacc = false
trace_vulkan = false
trace_opengl = true
trace_osrt = true
osrt-threshold = 0 nanoseconds
cudabacktrace = false
cudabacktrace-threshold = 0 nanoseconds
profile_processes = tree
application command = python
application arguments = cifar100_VGG.py -b 300 -e 1 --iterations 1
application working directory = /HDD2/ML/mlbenchmarks/Keras/keras
NVTX profiler range trigger =
NVTX profiler domain trigger =
environment variables:
So, there is a bug in 2019.4.2.135, and I sent off a request for an update of the downloadable file to 2019.4.2.139 last week. I’m glad you reported this, because now I see that that update did not happen. I am working on fixing that. Meanwhile, if you email me directly at hwilper@nvidia.com, I will get you the correct bits.
