I’m using codework 1R6u1 with Visual studio 2015, using Nsight Tegra 3.4 try to debug an android project.
I’m connect a android phone, making the apk with DebugGame option,deploy the apk to the device,then i use vs2015 with DebugGame-Android Configuration, when debugging the breakpoint is hit, but the local variable can’t show any useful information, local variable with FString type in a function always “Unable to evaluate the expression”,but int32 shows correct, i even surround the code block with PRAGMA_DISABLE_OPTIMIZATION Macro, but not working. How do i property use android debug the code with type like FString to show useful debug message? Please Help Me Out!
