I have a kernel which uses shared memory to do a reduction. When I enter debugging to view memory locations, the shared memory pointer I am looking for isn’t in the locals list. If I right click its name to try to add it to the watch list, Visual Studio stops responding immediately and eventually goes non-responding. If I hang around long enough in that kernel VS will also stop responding.
code in question:
void summation(keyEntry* matrix, keyEntry* rowSums, int* incGuide, const int reduction_size, const int matrix_size, const int reductions, const int rows, const int threads)
device_summation << < rows, threads, reduction_size * sizeof(keyEntry) >>> (matrix, rowSums, incGuide, reduction_size, matrix_size, reductions);
__global__ void device_summation(keyEntry* matrix, keyEntry* rowSums, int* incGuide, const int reduction_size, const int matrix_size, const int reductions)
extern __shared__ keyEntry reductionData[];
//transfer from global to shared memory in two halves
//for the second half, pad with zeroes where neccessary.
reductionData[threadIdx.x] = matrix[blockIdx.x * (matrix_size)+threadIdx.x];
reductionData[threadIdx.x + reduction_size / 2] = (matrix_size-1 < threadIdx.x + reduction_size / 2) ? 0 : matrix[blockIdx.x * (matrix_size)+threadIdx.x + reduction_size / 2];
__syncthreads();
for (int i = 0; i < reductions; i++)
if (threadIdx.x < incGuide[i]) reductionData[threadIdx.x] += reductionData[threadIdx.x + incGuide[i]];
__syncthreads();
if (threadIdx.x == 0) rowSums[blockIdx.x] = reductionData[0];
I’ve ran this program through memcheck and didn’t get any errors from this kernel. I’ve read other people having problems like because the shared memory was optimized away - does this look likely here?
This code seems to work most of the time so something is being created to hold reductionData, although it fails with certain inputs.
full code available on github if needed.
