Nsight Warp Occupancy
I have profiled a shader in Nsight, and the SM Warp Occupancy is like in the image below.
The top one, stalled register allocations as I understand it, is that a shader is using too many registers, so the SM cannot start new warps because of it. But what are TRAM Allocation and ISBE Allocation? I cannot find any documentation about them.
Is there any way of seeing how many registers are used by a shader, and how many registers are needed to be removed to remove register allocation limitations?
occupancy
Thank you for using Nsight Graphics and I have discussed with the engineering team and have some responses for you below.
This is correct.
TRAM and ISBE are on-chip buffers. TRAM contains pixel shader attributes; ISBE contains “VTG” attributes. VTG = vertex, tessellation, geometry.
The “Advanced Learning” document provides a little more information: https://docs.nvidia.com/nsight-graphics/AdvancedLearning/index.html
Currently, GPU Trace cannot directly answer this question. However, other tools directly reveal this:
In existing versions of Nsight Graphics, the Frame Profiler’s Linked Programs view shows PSO-level values: https://docs.nvidia.com/nsight-graphics/UserGuide/index.html#linked_programs_view_0
Starting in version 2022.4, the Shader Profiler’s summary page will show detailed occupancy calculations: https://docs.nvidia.com/nsight-graphics/UserGuide/index.html#uireference_shaderprofiler
The architectural warp-occupancy-per-register-count can be explored in the Nsight Compute Occupancy Calculator: https://docs.nvidia.com/nsight-compute/NsightCompute/index.html#occupancy-calculator
It can also be directly calculated in a spreadsheet with these formulas:
uint32_t regRowsPerSubp = 512; // note: regRowsPerSubp * subpPerSm * 32 threads/warp = 65536 reg/SM
uint32_t maxWarpCountLimitedByRegCount = min(warpCountPerSm, 4 * floor(regRowsPerSubp / roundUpToMultipleOf8(regCount)))
Finally, “Please also try the trace analysis tool. This view provides, in addition to performance insights and recommendations, important information on the traced data”
Thanks for a good answer
