I’m trying to use Nsight Systems with Julia, but am hitting an issue where it attempts to open the wrong libpcre library. Julia sets its RUNPATH to be $ORIGIN/../lib:$ORIGIN/../lib/julia
and the library is in the second of these directories. However when I run
LD_DEBUG=libs nsys launch julia
I get the following piece:
21111: find library=libpcre2-8 [0]; searching
21111: search path=/central/software/nsight-systems/2023.2.1/target-linux-x64 (RPATH from file /central/software/nsight-systems/2023.2.1/target-linux-x64/libToolsInjectionProxy64.so)
21111: trying file=/central/software/nsight-systems/2023.2.1/target-linux-x64/libpcre2-8
21111: search path=/central/software/julia/1.8.5/lib:/central/slurm/install/current/lib:/central/software/hdf5/1.14.0-ompi415//lib:/central/software/OpenMPI/4.1.5//lib:/central/software/ucx/1.13.1_cuda-11.2//lib:/central/software/CUDA/11.2/lib64:/central/software/CUDA/11.2/extras/CUPTI/lib64:/central/software/CUDA/11.2/targets/x86_64-linux/lib (LD_LIBRARY_PATH)
21111: trying file=/central/software/julia/1.8.5/lib/libpcre2-8
21111: trying file=/central/slurm/install/current/lib/libpcre2-8
21111: trying file=/central/software/hdf5/1.14.0-ompi415//lib/libpcre2-8
21111: trying file=/central/software/OpenMPI/4.1.5//lib/libpcre2-8
21111: trying file=/central/software/ucx/1.13.1_cuda-11.2//lib/libpcre2-8
21111: trying file=/central/software/CUDA/11.2/lib64/libpcre2-8
21111: trying file=/central/software/CUDA/11.2/extras/CUPTI/lib64/libpcre2-8
21111: trying file=/central/software/CUDA/11.2/targets/x86_64-linux/lib/libpcre2-8
21111: search cache=/etc/ld.so.cache
21111: search path=/lib64/tls:/lib64:/usr/lib64/tls:/usr/lib64 (system search path)
21111: trying file=/lib64/tls/libpcre2-8
21111: trying file=/lib64/libpcre2-8
21111: trying file=/usr/lib64/tls/libpcre2-8
21111: trying file=/usr/lib64/libpcre2-8
21111:
21111:
21111: find library=dlopen hook: 'libpcre2-8' [0]; searching
21111: trying file=/central/software/nsight-systems/2023.2.1/target-linux-x64/dlopen hook: 'libpcre2-8'
21111: trying file=/central/software/julia/1.8.5/lib/dlopen hook: 'libpcre2-8'
21111: trying file=/central/slurm/install/current/lib/dlopen hook: 'libpcre2-8'
21111: trying file=/central/software/hdf5/1.14.0-ompi415//lib/dlopen hook: 'libpcre2-8'
21111: trying file=/central/software/OpenMPI/4.1.5//lib/dlopen hook: 'libpcre2-8'
21111: trying file=/central/software/ucx/1.13.1_cuda-11.2//lib/dlopen hook: 'libpcre2-8'
21111: trying file=/central/software/CUDA/11.2/lib64/dlopen hook: 'libpcre2-8'
21111: trying file=/central/software/CUDA/11.2/extras/CUPTI/lib64/dlopen hook: 'libpcre2-8'
21111: trying file=/central/software/CUDA/11.2/targets/x86_64-linux/lib/dlopen hook: 'libpcre2-8'
21111: trying file=/lib64/tls/dlopen hook: 'libpcre2-8'
21111: trying file=/lib64/dlopen hook: 'libpcre2-8'
21111: trying file=/usr/lib64/tls/dlopen hook: 'libpcre2-8'
21111: trying file=/usr/lib64/dlopen hook: 'libpcre2-8'
21111:
21111: find library=libpcre2-8.so [0]; searching
21111: trying file=/central/software/nsight-systems/2023.2.1/target-linux-x64/libpcre2-8.so
21111: trying file=/central/software/julia/1.8.5/lib/libpcre2-8.so
21111: trying file=/central/slurm/install/current/lib/libpcre2-8.so
21111: trying file=/central/software/hdf5/1.14.0-ompi415//lib/libpcre2-8.so
21111: trying file=/central/software/OpenMPI/4.1.5//lib/libpcre2-8.so
21111: trying file=/central/software/ucx/1.13.1_cuda-11.2//lib/libpcre2-8.so
21111: trying file=/central/software/CUDA/11.2/lib64/libpcre2-8.so
21111: trying file=/central/software/CUDA/11.2/extras/CUPTI/lib64/libpcre2-8.so
21111: trying file=/central/software/CUDA/11.2/targets/x86_64-linux/lib/libpcre2-8.so
21111: trying file=/lib64/libpcre2-8.so
21111:
21111:
21111:
21111: calling init: /lib64/libpcre2-8.so
From what I can tell, it is not attempting to search the RUNPATH for libpcre2-8.so
, so instead searches the cache and ends up with the wrong library.
This was with Nsight Systems 2023.2.1, on CentOS Linux.
