Nsys on windows
Hello i installed the night system on windows 10 GUI works, night compute works on both gui level and command line in case of command line for nsys i can not make it work as in documentation it is mainly about Linux for command line interface, any advices?
I just ran into the same problem, while reading the article on transitioning from nvprof to nsys here.
I was able to solve the problem by adding the nsys directory into the Path-variable. I saw that upon installation of the NSight system, the ncu package (Nsight Compute ) was added to the Path-variable, but not the nsys package (Nsight Systems).
In my case, adding the path C:\Program Files\NVIDIA Corporation\Nsight Systems 2021.3.3\target-windows-x64 solved this. Please note the last bit target-windows-x64
