I installed Jetpack 7.2.1 on the Jetson Thor Dev Kit. Then I installed Nsight DL Designer 2026.1 (the 2025.2 version that is listed here: JetPack SDK Downloads and Notes | NVIDIA Developer is not available to the public I guess. Also stated here: Request for Nsight Deep Learning Designer 2025.2 Historical Version Download - #2 by gxie )
With 2026.1 installed the profiling of a TensorRT model fails with this output:
INF] [TRT] Serialized 3877 bytes of code generator cache.
[INF] [TRT] Serialized 283141 bytes of compilation cache.
[INF] [TRT] Serialized 0 timing cache entries
[INF] Saved timing cache: /root/.config/NVIDIA Corporation/NVIDIA Nsight Deep Learning Designer/timing_cache.11.1.0.106.bin
GPU 0: General Metrics for NVIDIA GB10y
Processing events...
Generated:
No reports were generated
Exportation error: File not found: '/tmp/dld-c476-bc3a-57ec-7f57.nsys-rep'.
Nsys export returned nonzero error code: 1
Process terminated.
Profiler encountered an error during execution: 0x1u.
(I am running the DL Designer with root priv. so that should not be the problem.)
Which version of the DL Designer should I use on JetPack 7.2.1 with Jetson Linux 39.2.1?
And which Nsight Systems version should I use with it?
Thanks and kind regards,
Steve
Hello @stefan.rothhaupt!
Based on the title and content of your topic, it looks like it may receive better visibility and feedback in a different category. We took the liberty of moving it for you.
If this was an incorrect assessment, please send me a direct message.
Disclaimer: this moderation suggestion and message were generated with AI assistance.
DLD 2026.1 deploys its own Nsight Systems binaries. Be sure to use the Linux (aarch64, SBSA) platform target for JetPack Linux configurations.
From the log snippet you posted, it looks like no inference actually happened during your profiling run. Using your deployed NDLD directory, try running the profiling step manually (not from the GUI) and saving the logs. Feel free to redact paths or other sensitive information.
Example: ./DLDesignerWorker -v profile-trt11 /path/to/model.onnx /path/to/output.nv-dld-report 2>&1 | tee profiler.log
You can use ./DLDesignerWorker profile-trt11 --help to see the available options; they correspond to the activity settings available in the GUI.
Thank you for the instructions! You were right, there was no inference run during the profiling via the GUI!
I was now able to get a profile output through the command you posted (I adapted it slightly, since we use tensorrt 10, TensorRT version 10.16.2.10 is used as the system TRT).
I use this install of DLD: Log in | NVIDIA Developer on the Jetson Thor Dev Kit. I am logged in as the user set up during the installation process.
When I run this command sudo ./DLDesignerWorker -v profile-trt10 --use-system-trt /path/to/model.onnx path/to/output.nv-dld-report 2>&1 | tee profiler.log from /opt/nvidia/nsight_dl/2026.1.26173.1353/target/linux-v4l_l4t-dl-t210-a64:
I get a report that I then can open via the GUI. Is there a way to also trigger the profiling of the model through the GUI? I think I am missing some configuration step?!
Try profiling using the Linux (aarch64, SBSA) target instead of L4T. The latter is a compatibility holdover that–despite the name–is no longer intended for Jetson platforms.
Selecting the Linux (aarch64, SBSA) target via the GUI fails with the error I shared in my inital post.
In the subdirectory of nsight_dl->targets I see these three directories:
The linux-v4l-l4t-dl-t210-a64 is the one I was able to successfully run the terminal command for profiling from.
When I start the profile from linux-desktop-dl-t210-a64 I get this output message:
[INF] Loaded TensorRT version 10.16.2.10.
[INF] [TRT] [MemUsageChange] Init CUDA: CPU +21, GPU +0, now: CPU 29, GPU 13274 (MiB)
[INF] [TRT] ----------------------------------------------------------------
[INF] [TRT] Input filename: /path to/file.onnx
[INF] [TRT] Some Onnx Model info...
[INF] Building TensorRT engine. This may take some time.
[INF] [TRT] [MemUsageChange] Init builder kernel library: CPU +309, GPU +313, now: CPU 574, GPU 13925 (MiB)
[INF] [TRT] Global timing cache in use. Profiling results in this builder pass will be stored.
[INF] [TRT] Compiler backend is used during engine build.
[INF] Estimated builder progress: 10%...
[INF] [TRT] Some Model Info
[INF] [TRT] Total Host Persistent Memory: 80 bytes
[INF] [TRT] Total Device Persistent Memory: 0 bytes
[INF] [TRT] Max Scratch Memory: 41166848 bytes
[INF] [TRT] [BlockAssignment] Started assigning block shifts. This will take 1 steps to complete.
[INF] [TRT] [BlockAssignment] Algorithm ShiftNTopDown took 0.006149ms to assign 1 blocks to 1 nodes requiring 41166848 bytes.
[INF] [TRT] Total Activation Memory: 41166848 bytes
[INF] [TRT] Total Weights Memory: 2634304 bytes
[INF] [TRT] Compiler backend is used during engine execution.
[INF] [TRT] Engine generation completed in 6.86179 seconds.
[INF] [TRT] The following layers are used for L2 cache management and do not correspond to any layers in the INetworkDefinition: ...
[INF] [TRT] [MemUsageStats] Peak memory usage of TRT CPU/GPU memory allocators: CPU 0 MiB, GPU 57 MiB
[INF] [TRT] Serialized 15497 bytes of code generator cache.
[INF] [TRT] Serialized 27816202 bytes of compilation cache.
[INF] Saved timing cache: /root/.config/NVIDIA Corporation/NVIDIA Nsight Deep Learning Designer/timing_cache.10.16.2.10.bin
[ERR] Nsys not found in deployed environment. Path checked: /tmp/dld-4765-4a7d-fc0f-3797/target-linux-sbsa-armv8/nsys
Which of the subdirectories’ DLDesignerWorker corresponds to the Linux (aarch64, SBSA) target?
The final error complains about the missing Nsight System tool.
Have you installed it on your device first?
$ sudo apt install nvidia-nsight-systems
