• Hardware Platform (Jetson / GPU) - dGPU
• DeepStream Version - 6.2
• TensorRT Version - 8.5.2.2
• NVIDIA GPU Driver Version (valid for GPU only) - 530.xx
• Issue Type( questions, new requirements, bugs) - question
I’m using Deepstream SDK in Python. I read this link to understand how to set NTP timestamp with C++ application. However I’m interested in using this C API in Python. So I created a Python binding for this following this tutorial. Below is the code I added in src/bindfunctions.cpp to add a binding for the existing function configure_source_for_ntp_sync().
void bindfunctions(py::module &m) {
m.def("configure_source_for_ntp_sync",
&configure_source_for_ntp_sync,
"gst_element"_a,
pydsdoc::methodsDoc::configure_source_for_ntp_sync);
I built pyds wheel and installed it after making these changes. When I try to call the function configure_source_for_ntp_sync(uri_decode_bin) from the sample python application(deepstream-test3), with this way:
if file_loop:
# use nvurisrcbin to enable file-loop
uri_decode_bin=Gst.ElementFactory.make("nvurisrcbin", "uri-decode-bin")
uri_decode_bin.set_property("file-loop", 1)
uri_decode_bin.set_property("cudadec-memtype", 0)
else:
uri_decode_bin=Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
if not uri_decode_bin:
sys.stderr.write(" Unable to create uri decode bin \n")
# We set the input uri to the source element
print(type(uri_decode_bin))
pyds.configure_source_for_ntp_sync(uri_decode_bin)
uri_decode_bin.set_property("uri",uri)
I’m getting the below error:
File "deepstream_test_3.py", line 185, in create_source_bin
TypeError: configure_source_for_ntp_sync(): incompatible function arguments. The following argument types are supported:
1. (gst_element: _GstElement) -> None
Invoked with: <__gi__.GstURIDecodeBin object at 0x7f0fff6fc200 (GstURIDecodeBin at 0x1b5c080)>
Please let me know how to add a binding for the C API configure_source_for_ntp_sync() in Python. Ultimately, I wanted to access the NTP timestamp of the frame from rtsp source in PYTHON.
