NTP timestamp (RTSP Sender Report) is not set to NvDsAudioFrameMeta::ntp_timestamp in my pipeline
• Hardware Platform (Jetson / GPU) dGPU
• DeepStream Version 6.1.1
• TensorRT Version
• Issue Type( questions, new requirements, bugs) question
I am testing ntp timestamp (from RTSP sender report) in audio pieline.
I got NvDsAudioFrameMeta::npt_timestamp=0 in my custom pipeline.
1) I ran deepstream-audio with “attach-sys-ts-as-ntp=0” and could get correct ntp timestamp from RTSP sender report.
GST_DEBUG=nvstreammux_ntp:5
../deepstream-audio -c ds_audio_sonyc_rtsp_test_config.txt 2>&1  | grep -i ntp
0:00:26.782460284  1448 0x7f38d40265e0 DEBUG        nvstreammux_ntp gstnvstreammux_ntp.cpp:187:apply_correction_if_needed_rtcp:<src_bin_muxer> Frame rate based NTP timestamp correction applied.
0:00:26.782470088  1448 0x7f38d4003120 DEBUG        nvstreammux_ntp gstnvstreammux_ntp.cpp:187:apply_correction_if_needed_rtcp:<src_bin_muxer> Frame rate based NTP timestamp correction applied.
0:00:26.782507663  1448 0x7f38d4003120 INFO         nvstreammux_ntp gstnvstreammux_ntp.cpp:269:gst_nvds_ntp_calculator_get_buffer_ntp:<src_bin_muxer> Frame NTP calculated. Correction required.mode: RTCP SR. source 0: PTS:0:00:23.526679105(23526679105) NTP: 2023-03-24T11:16:21.644Z(1679656581644254392). NTP diff:-40264523975. Corrected ntp: 2023-03-24T11:17:01.977Z(1679656621977045033). ntp_time_epoch_ns = 2023-03-24T11:16:02.454Z(1679656562454999999) ntp_frame_timestamp = 0:00:04.337424712(4337424712) System Time: 2003-03-29T11:16:21.628Z Avg Frame Time: 0:00:00.068266666 Avg. Frame Rate: 14.65
0:00:26.782517693  1448 0x7f38d40265e0 INFO         nvstreammux_ntp gstnvstreammux_ntp.cpp:269:gst_nvds_ntp_calculator_get_buffer_ntp:<src_bin_muxer> Frame NTP calculated. Correction required.mode: RTCP SR. source 1: PTS:0:00:23.526687491(23526687491) NTP: 2023-03-24T11:16:21.644Z(1679656581644254392). NTP diff:-40264523975. Corrected ntp: 2023-03-24T11:17:01.977Z(1679656621977045033). ntp_time_epoch_ns = 2023-03-24T11:16:02.454Z(1679656562454999999) ntp_frame_timestamp = 0:00:04.337433098(4337433098) System Time: 2003-03-29T11:16:21.628Z Avg Frame Time: 0:00:00.068266666 Avg. Frame Rate: 14.65
### label:[ 2_machinery-impact ] source_id:[1] ntp 1679656621977045033 buf-pts 147579740436532640
### source_id:[1] ntp 1679656621977045033 buf-pts 147579740436532640
### label:[ 2_machinery-impact ] source_id:[0] ntp 1679656621977045033 buf-pts 147579740436532640
### source_id:[0] ntp 1679656621977045033 buf-pts 147579740436532640
“label: …” is a debug print which prints NvDsAudioFrameMeta::ntp_timestamp, which matches to nvstreammux_ntp debug print info.
2) In my pipeline, ntp_timestamp is always 0 and buf_pts seems to be “PTS”. Is there any hidden condition so that ntp_timestamp is properly written? I could not debug since streammux-new is closed source. I would appreciate any hints or suggestion. Thanks.
0:00:19.967665857   267 0x56013eff11e0 DEBUG        nvstreammux_ntp gstnvstreammux_ntp.cpp:187:apply_correction_if_needed_rtcp:<src_bin_muxer_audio> Frame rate based NTP timestamp correction applied.
0:00:19.967714101   267 0x56013eff11e0 INFO         nvstreammux_ntp gstnvstreammux_ntp.cpp:269:gst_nvds_ntp_calculator_get_buffer_ntp:<src_bin_muxer_audio> Frame NTP calculated. Correction required.mode: RTCP SR. source 0: PTS:0:00:09.216094839(9216094839) NTP: 2023-03-24T11:06:31.521Z(1679655991521093749). NTP diff:-11212810408. Corrected ntp: 2023-03-24T11:06:42.800Z(1679656002800037490). ntp_time_epoch_ns = 2023-03-24T11:06:25.958Z(1679655985958999999) ntp_frame_timestamp = 0:00:03.654001089(3654001089) System Time: 2023-03-24T11:06:31.505Z Avg Frame Time: 0:00:00.066133333 Avg. Frame Rate: 15.12
### source_id:[0] ntp 0 buf-pts 9216094839
“### source_id:[0] ntp 0 buf-pts 9216094839” is from printf() in the probe function attached to src of streammux(new) element.
My pipeline is like (rtspsrc → decodebin … ->streammux-new → nvinferserver → … → sink )
input was dynamically added after streammux-new is played.
Why do you testing ntp timestamp from RTSP SR? What is your pipeline’s sink?
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_FAQ.html#how-do-i-configure-the-pipeline-to-get-ntp-timestamps
I want to use ntp timestamp (from rtcp SR) in my product (audio pipeline).
Customized msgbroker.
But tihs problem will reproduce with fakesink
because I debug printed at “src” of nvstreammux-new
Frequently Asked Questions — DeepStream 6.3 Release documentation
I already set it to false.
If you want to get the original ntp from rtcp SR, please access the rtcp information from rtcp. E.G. gst_rtcp_packet_sr_get_sender_info() interface GstRTCPBuffer. You may need to construct rtp session without rtspsrc. Please refer to GStreamer. rtpsession (gstreamer.freedesktop.org)
I just want to use NTP timestamp feature of deepstream in my app.
My issue/question is
Frequently Asked Questions — DeepStream 6.2 Release documentation (nvidia.com)
Even if I set System clock to 2003/3/, I got 2023year NPT log ( like this: NTP: 2023-03-24T11:06:31.521Z ).
So my app is indeed receiving SR
@Fiona.Chen
In my app, streammux(new) surely knows NTP time from SR:
0:00:25.982500533   474 0x55f4a69e6640 INFO         nvstreammux_ntp gstnvstreammux_ntp.cpp:269:gst_nvds_ntp_calculator_get_buffer_ntp:<src_bin_muxer_audio> Frame NTP calculated. Correction required.mode: RTCP SR. source 0: PTS:0:00:16.859157729(16859157729) NTP: 2023-04-03T07:15:25.011Z(1680506125011312499). NTP diff:-23948810238. Corrected ntp: 2023-04-03T07:15:49.026Z(1680506149026256070). ntp_time_epoch_ns = 2023-04-03T07:15:13.661Z(1680506113661999999) ntp_frame_timestamp = 0:00:05.509845229(5509845229) System Time: 2023-04-03T07:15:25.075Z Avg Frame Time: 0:00:00.066133333 Avg. Frame Rate: 15.12
But NvDsAudioFrameMeta::ntp_timestamp is 0 (probed at “src” of streammux).
I am 100% sure that attach-sys-ts-as-ntp=0 is set because the above ntp log does not appear when I set attach-sys-ts-as-ntp=1.
Could you please check the source code to see if there are conditions under which ntp_timestamp is not set?
@Fiona.Chen
When debuggin in DeepStream 6.2 instead of 6.1.1,
following message appears in my app.
Maybe related?
0:00:26.417152042  1451 0x55f967bb4300 DEBUG        nvstreammux_ntp gstnvstreammux_ntp.cpp:185:apply_correction_if_needed_rtcp:<src_bin_muxer_audio> Frame rate based NTP timestamp correction is disabled.
@Fiona.Chen
Ping.
When the “Frame rate based NTP timestamp correction is disabled.” message appear?
@Fiona.Chen ping
@Fiona.Chen May I have some support?
Please check your RTSP source. The ntp comes from the rtsp rtcp SR, it is not generated by DeepStream.
@Fiona.Chen
To summarize what I know:
  • The gstreamer pipeline correctly recognizes the RTSP SR time (confirmed by logs)
  • I confirmed attach-sys-ts-as-ntp=0 is set in my app
  • But ntp_timestamp is 0 in my app
  • When ntp_timestamp is 0, I get the message “Frame rate based NTP timestamp correction is disabled.”
This means the received framerate is invalid.
@Fiona.Chen When the recieved framerate is invliad? What is the condition?
It is caused by the server side. You need to check the server.
