Hi! New user here, excited to dive into Omniverse!
But facing a connection issue that I can’t sort on my own.
I’m on a single local machine, 2080 Ti.
Installed the Nucleus Collaboration Service and I’m able to log in to its config page, as well as add a server.
But no app or connector relying on a connection works.
I then realized the Nucleus app (v.109.8-1935) shows as not running, with an error log.
From: [Info] [omni.server] Successfully launched the DeltaContent Server Process
It leads to: [...] [Info] [omni.server] Attempt to connect Delta server failed, retry after 2000 ms. (10/10) [Fatal] [omni.server] Failed to connect to the DeltaContentServer, can't continue
Since it doesn’t display much more, does anybody have an idea what it could be?
I tried whitelisting all the ports mentioned in the documentation, as well as reinstalling the Nucleus service on varied locations. No change.
Hi phscatena, sorry you’re having issues with Nucleus. Unfortunately I can’t repro your issue. Can you provide some more info to help us resolve this issue please?
What is your environment OS?
Do you still repro the issue when you kill the omni.server.app process and restart it?
Can you share your full Nucleus server log? It can be found in the .nvidia-omniverse directory. It can also be found in System Monitor (localhost:3080), under Logs.
Also, one more question to tack on to @j-san’s requests :
Can you check to see if omni.delta-server.app.exe is actually running in your Task Manager Details tab? (CTRL+SHIFT+ESCAPE, click More Details at the bottom if you don’t have a Details tab, I find sorting by name helps quickly find processes in the list).
Indeed, it sounds more like a specific local issue. I had a colleague with similar specs try a fresh install and it all ran smoothly. So I’m trying to narrow it down…
I am running Win 10 v1909, and he is running v20H2. Maybe that could be a thing? I’m queuing up an update anyways.
For the process,omni.delta-server.app.exe runs while the Nucleus attempt to use it (i.e., when I set it to “start” from the system monitor). When it fails, the process is killed. If I start the process on my own, nothing changes.
I did update Windows to its latest version, to no changes. Tried fresh re-installs of launcher and nucleus service on different drives. Always the same undesired error, in what would be step 4.
It’s sounding like it is a problem very specific to this machine. I wonder why.
I will update here if I manage to do a full system reinstall.
Hi @phscatena, it’s no problem. I’m grateful for your patience while we try and get this issue resolved.
Checking Search Service logs, it looks like it can’t communicate with the Nucleus Server.
A couple more questions
Is the Nucleus Server itself running? It is omniverse.server.app.exe in task manager
If so, can you try running this command in Windows and dump the output here please? netstat -nao
It’s possible another process is running on the default Nucleus Server and Delta Server ports. Nucleus Server uses 3009, and Delta Server uses 3001. Checking the netstat output should help verify that.
The nucleus server process runs only while attempting to connect. When the error happens, it gets killed, together with the Delta Server.
I had formerly used the Resource Monitor to check if something else was listening at said ports, and it didn’t seem so.
I believe Netstat points in the same direction.
For better review, in attachment are the output of netstat in four different moments: before the Omniverse services were started, during the attempted connection, shortly after, and a couple of minutes after, when the processes are fully terminated again.
Apparently the Omni servers are the only ones using such ports.
@j-san, thanks for the info and suggestion.
Sorry for the late reply. I had tried the suggestion at the time, to no effect, but ended up forgetting to write here.
Today I tried it again with the current release: Nucleus v.109.9 / nucleus-workstation-2020.3.1
Still same error, regardless if I increase the timeout or retries tolerance.
It still looks very specific to this one workstation. But I appreciate the support!
Hi there,
its been a while this thread was active. So, I have the same issues, omni.delta-server.app.exe is beeing killed after a while, so I don’t have access to the localhost. Any news on that?
Hi, I have the exact same problem as the people above.
Nucleus service gives error and stops running after 15-20 secs in Local Nucleus Service 2022.3.0 so I get “[127.0.0.1] (NUCLEUS) service is not accessible. Please check your network connection and the server status with administrator.”
If the service is restarted manually through the localhost:3080 page+start button, same thing happens, the process gives error and stops (gets killed) after a while.
Tried running manually omni.delta-server.app.exe, high CPU usage for about 20-30 secs, then the cmd window closes and the process gets killed.
I have been trying about a month now, with multiple installations-uninstallations, different installation paths & drives, using the clean-up tool, deleting every leftover trace I can find, with and without cache, disabling firewall, updating graphics card drivers and windows updates with no luck. The problem remains every single time.
I can replicate this error only on one specific machine. Installation and nucleus service on another pc (Windows 10 Pro) within the same network, same firewall, same antivirus works just fine.
Processor Intel(R) Core™ i9-9900X CPU / 64GB ram
GPU RTX 3090
OS: Windows 10 Pro 21H2 Nucleus.log (39.6 KB)
