Number of monitors and resolution calculation
I’ve been tasked with building a PC that can support 8 4k monitors. I’ll likely need 2 cards that can support 4 monitors, but some of the specs are unclear. For example, the Quadro P5000 can support 4 monitors, but it doesn’t say at what resolution. Some of the other cards give a maximum resolution but that is probably for 1 monitor. How can I figure this out?
Hi jeff_payne,
The Quadro datasheets provide information on what resolutions are supported:
Thanks,
Ryan Park
You misunderstood the question. I need to know the maximum resolution for 4 displays at a time. I know that some cards at maximum resolution are limited to 1 or 2 displays even though they support more displays at lower resolution.
Hi jeff_payne,
The resolution shown on the datasheet is the max resolution supported for 4 displays at a time.
Specifically for your use-case, you should go with 2 Quadro P5000s with a dual 8 pin connnector.
If you have budgetary constraints, you can also go with 2 Quadro P4000s, that would also support your use-case as well.
Thanks,
Ryan Park
