Number of sources in a deepstream pipeline
How many sources support a deepstream pipeline?
Jetson AGX Orin
DeepStream 6.0
Question:
the number of sources depends on source types, decoding capability and GSteamer limitation. could you elaborate on the question?
Thanks for your answer.
Source type: rtsp
I want to use 4 rtsp sources in a deepstream pipeline. It’s possible? What do you mean by decoding capability and GSteamer limitation?
deepstream-app, which is a ready-made tool, can support 4 RTSP sources and the pipeline above. you only need to set source and type and address in the configuration file. the file path is
/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.yml. if you are using custom code, please refer to deepstream-test3 and deepstream-test2.
if inputting too many sources, maybe there will be decoding performance issue. and please refer to this topic for “GSteamer limitation”.
