• Hardware Platform (Jetson / GPU) GPU RTX 2080ti
• DeepStream Version 6.0 triton
• NVIDIA GPU Driver Version (valid for GPU only) 470.103.01
• Python Version: 3.6.15
• Issue Type: bugs
Logs detail
I0311 07:45:17.484594 10848 plan_backend.cc:859] Created instance detector_0_0_gpu0 on GPU 0 with stream priority 0 and optimization profile default[0];
I0311 07:45:17.484653 10848 model_repository_manager.cc:1212] successfully loaded 'detector' version 1
INFO: infer_trtis_backend.cpp:206 TrtISBackend id:1 initialized model: detector
Decodebin child added: source
Now playing...
Starting pipeline
Decodebin child added: decodebin0
Decodebin child added: rtph264depay0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: nvv4l2decoder0
In cb_newpad
gstname= video/x-raw
Decodebin linked to pipeline
• Reproduce
Funct: tiler_sink_pad_buffer_probe
n_frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
frame_copy = np.array(n_frame, copy=True, order='C')
rgb_frame = cv2.cvtColor(frame_copy, cv2.COLOR_RGBA2RGB)
Successful to install NumPy (1.19.5, 1.19.4, 1.19.3, 1.19.2). However, these NumPy versions are still the cause of the code dumps.
Alternatively, I also tried python3-numpy, but it still doesn’t work.
Hope to get help! Thanks
