NuRec 26.04 with CARLA 0.9.16 and nvidia-nurec-grpc:0.2.0: 25.07 images and compatibility
We replay reconstructions of our own NCore v4 data in CARLA 0.9.16 with carlasimulator/nvidia-nurec-grpc:0.2.0 (NuRec 25.07), and want surrounding vehicles as separate layers. We tried the NRE 26.04 pipeline:
  • With nre-ga:26.04 and the car2sim_6cam config, track_label_sources=[EXTERNAL] is accepted, but training stops with NCOREDataSource: aux data was not loaded.
  • A model from the 26.x pipeline fails to load in the 0.2.0 container (Unknown calib name='free-pose-calib', missing model.appearance_embedding).
  • With our NGC key, nre-ga and nre-tools-ga have no 25.x tags (25.07, 25.07.00, 25.07.01, 25.7 and 25.11 return “no such manifest”). nre and nre-tools return an access error for every tag, including 26.04. Docker Hub lists only 0.2.0 and 0.1.0 for the CARLA gRPC image.
Questions
  1. Does a 25.07 nre/nre-ga (and nre-tools) image exist? If so, where, with what tag and digest, and how can our key be granted access, including to nre and nre-tools?
  2. Is there a released CARLA gRPC container for NuRec 26.04 (or an expected date or pre-release), and is there an official conversion path from 26.04 USDZ files to the 25.07 runtime? Which CARLA and container versions are officially supported with 26.04?
  3. For EXTERNAL tracks with classes such as pedestrian, construction_vehicle, barrier and traffic_cone, what class mapping is required to the config’s classes (e.g. person), and how are the dynamic layers built from them?
  • There are no 25.x tags in the public repositories, so “no such manifest” is expected. The public NuRec images start at 26.02:
  • CARLA 1.0 is the official path.** Its changelog lists “Added support for NVIDIA NuRec 26.04”. Its NuRec guide covers the setup: the installer pulls nre-ga:26.04.01 and downloads scenes from the 26.04 sample set. Until the release packages appear on the download page, you can use the nightly build or build from source. Moving from 0.9.16 to 1.0 also means moving from Unreal Engine 4 to Unreal Engine 5.8.
Workaround
If you use 26.04 in CARLA,
* Keep CARLA 0.9.16 and its scripts.
* Replace only the render server with the public 26.04 NuRec image
* Add the two arguments to the command in nurec_render_service.py, and set NUREC_IMAGE
export NUREC_IMAGE=nvcr.io/nvidia/nre/nre-ga:26.04.01
Add the two arguments to the command in nurec_render_service.py, and set NUREC_IMAGE as above:
diff
“–gpus=all”,
self.image,
  •        "serve-grpc",
           "--artifact-glob",
           f"{os.path.realpath(self.usdz_path)}",
           f"--port={self.final_port}",
           "--host=localhost",
           "--test-scenes-are-valid",
  •        "--enable-editing-actors",
It should work
  • Mapping to the config’s classes:** NuRec doesn’t need your labels mapped to person. It compares track labels only with the label lists of its two dynamic layers, and pedestrian is already on them. Rename only labels that are on neither list, such as construction_vehicle. For CARLA, also rename pedestrian to person.
W.r.t dynamic layers are built,
  1. At ingest, it decides whether the track is dynamic.** Tracks labeled pedestrian, stroller, person, person_group, rider, bicycle_with_rider,
    bicycle, CYCLIST, motorcycle, motorcycle_with_rider or cycle are always dynamic. Any other track is dynamic only if it moves more than 1.0 m, measu
    red as start-to-end displacement or as path length (dataset.cuboid_tracks_params).
  2. When the model is built, it assigns each dynamic track to the layer whose label_classes contains its label.** In car2sim_6cam, dynamic_rigids take
    s vehicles and dynamic_deformables takes people, cyclists and animals. Both accept only dynamic tracks.
FYI : NuRec is now opensource, Please check GitHub - NVIDIA/NuRec: NVIDIA Omniverse NuRec provides neural reconstruction APIs and libraries to reconstruct and render interactive simulations from real-world data. · GitHub
