NuRec `nre-ga main mode=train` raises `KeyError: '<camera_id>'` on a custom NCore V4 dataset
## Summary
`nre-ga main mode=train` (and `nre-tools-ga ncore-aux-data
--segmentation-backend=mask2former`) raise a bare `KeyError: ‘<camera_id>’`
immediately after the three component stores finish loading, before any
training step runs. The store is a fully custom NCore V4 sequence built with
the public `nvidia-ncore==19.0.0` Python API; `SequenceComponentGroupsReader`
and `SequenceLoaderV4` round-trip the store correctly and expose the expected
`sequence_id`, `camera_ids`, `lidar_ids`, intrinsics, and extrinsics.
The error appears to originate inside the `pycena_run_cc` binary in
a `TimestampFrameSampler.sample_frame` codepath that indexes
`cameras_frame_timestamps_us[unique_sensor_id]`. Whatever populates that dict
uses a different key than the bare `camera_id` we put into the store.
We’ve reproduced the failure with:
- multiple sensor-name conventions (Kodiak native, Hyperion-8.1
`camera_front_wide_120fov` / `camera_front_tele_30fov` /
`camera_cross_right_120fov` / `lidar_gt_top_p128_v4p5`, and Waymo
`camera_front_50fov` / `lidar_top`);
- multiple training configs (`apps/prod/Hyperion-8.1/car2sim_6cam.yaml`,
`apps/prod/Hyperion-8.1/sqa_default.yaml`, `apps/prod/Waymo/sqa_default.yaml`);
- 1, 2, and 3 cameras in the store;
- with and without `rig_properties.platform_name = “hy8.1_*”` in the manifest
`generic_meta_data`.
We’d like guidance on (a) which exact NCore V4 keying/metadata the trainer
expects beyond what the public NCore docs spell out, and ideally (b) a tiny
reference NCore V4 dataset we can diff against.
Environment
| Component | Version |
| Host OS | Ubuntu 22.04 (`Linux 5.15.0-176-generic x86_64`) |
| GPU / Driver | NVIDIA GeForce RTX 3090 / 580.105.08 |
| Docker | 29.3.0 |
| `nre-ga` image | `nvcr.io/nvidia/nre/nre-ga:latest` (`sha256:dbb6be50cabc…`, built 2026-02-04) |
| `nre-tools-ga` image | `nvcr.io/nvidia/nre/nre-tools-ga:latest` (`sha256:0ffe8dccab71…`, built 2026-02-04) |
| `nvidia-ncore` (PyPI) | `19.0.0` |
| Python | 3.11 (matching the runfiles interpreter inside the image) |
## What works
1. Building the store with the public NCore V4 API
(`SequenceComponentGroupsWriter` + `PosesComponent.Writer`,
`IntrinsicsComponent.Writer`, `CameraSensorComponent.Writer`,
`LidarSensorComponent.Writer`, plus empty `MasksComponent`/`CuboidsComponent`
groups required by `nre-tools-ga`).
2. Reading the store back with `SequenceComponentGroupsReader` and
`SequenceLoaderV4` — `loader.sequence_id`, `loader.camera_ids`,
`loader.lidar_ids`, `loader.pose_graph`, and `loader.get_camera_sensor(id)`
all return the values we put in.
3. `nre-tools-ga ncore-aux-data --segmentation-backend=none --no-ego-mask
--no-lidar-seg-camvis --depth-backend=none --store-meta` accepts the
manifest without errors. This confirms the V4 schema validates against
NVIDIA’s loader.
## What fails
```text
SequenceStoreReader: Loading component store …/kodiak_.ncore4-camera_front_50fov.zarr.itar
SequenceStoreReader: Loading component store …/kodiak_.ncore4-lidar_top.zarr.itar
SequenceStoreReader: Loading component store …/kodiak_.ncore4.zarr.itar
KeyError
‘camera_front_50fov’
(Exit 255, no Python traceback even with `HYDRA_FULL_ERROR=1` and
`PYTHONFAULTHANDLER=1` — see “Traceback suppression” below.)
The same error is produced by `nre-tools-ga ncore-aux-data
--segmentation-backend=mask2former` immediately after the semantic
segmentation checkpoint loads, with the same `KeyError` keyed by the same
`<camera_id>`.
## Minimal repro
### 1. Build a single-camera NCore V4 sequence
This script depends only on `nvidia-ncore==19.0.0`, `numpy`, `scipy`, `opencv-python`,
`typed-argument-parser`, and `universal_pathlib`. It writes one image, one
identity rig pose, identity sensor extrinsics, and a trivial intrinsics block:
```python
# tiny_ncore_repro.py
import io
import numpy as np
import cv2
from upath import UPath
from ncore.data.v4 import (
CameraSensorComponent, CuboidsComponent, IntrinsicsComponent,
LidarSensorComponent, MasksComponent, PosesComponent,
SequenceComponentGroupsWriter,
from ncore.impl.common.transformations import HalfClosedInterval
from ncore.impl.data.types import (
OpenCVPinholeCameraModelParameters,
RowOffsetStructuredSpinningLidarModelParameters,
ShutterType,
OUT = UPath(“/tmp/ncore_repro”)
OUT.mkdir(parents=True, exist_ok=True)
SEQ = “tiny_seq_0001”
CAM = “camera_front_50fov” # also tried Hyperion + Kodiak-native names; same error
LID = “lidar_top”
T0 = 1_700_000_000_000_000
INTERVAL = HalfClosedInterval(T0, T0 + 1_000_000)
writer = SequenceComponentGroupsWriter(
output_dir_path=OUT,
store_base_name=f"{SEQ}",
sequence_id=SEQ,
sequence_timestamp_interval_us=INTERVAL,
store_type=“itar”,
generic_meta_data={
# Tried with and without; same KeyError either way.
“rig_properties”: {
“platform_name”: “hy8.1_tiny”, “layout”: “hyperion_8.1_tiny”,
# Identity rig trajectory (poses are written rebased so the first frame is
# the world origin; this matches the fix from NVIDIA/ncore#77).
poses = writer.register_component_writer(PosesComponent.Writer, “default”, group_name=None)
poses.store_dynamic_pose(
source_frame_id=“rig”, target_frame_id=“world”,
poses=np.tile(np.eye(4, dtype=np.float64)[None], (2, 1, 1)),
timestamps_us=np.array([T0, T0 + 500_000], dtype=np.uint64),
# (world, world_global) anchor — required as of NCore #76*, identity here.*
poses.store_static_pose(“world”, “world_global”, np.eye(4, dtype=np.float32))
poses.store_static_pose(CAM, “rig”, np.eye(4, dtype=np.float32))
poses.store_static_pose(LID, “rig”, np.eye(4, dtype=np.float32))
# Trivial pinhole intrinsics
intr = writer.register_component_writer(IntrinsicsComponent.Writer, “default”, group_name=None)
intr.store_camera_intrinsics(
CAM,
OpenCVPinholeCameraModelParameters(
resolution=np.array([640, 480], dtype=np.uint64),
shutter_type=ShutterType.ROLLING_TOP_TO_BOTTOM,
principal_point=np.array([320.0, 240.0], dtype=np.float32),
focal_length=np.array([500.0, 500.0], dtype=np.float32),
radial_coeffs=np.zeros(6, dtype=np.float32),
tangential_coeffs=np.zeros(2, dtype=np.float32),
thin_prism_coeffs=np.zeros(4, dtype=np.float32),
intr.store_lidar_intrinsics(
LID,
RowOffsetStructuredSpinningLidarModelParameters(
spinning_frequency_hz=10.0, spinning_direction=“ccw”,
n_rows=128, n_columns=3600,
row_elevations_rad=np.linspace(0.25, -0.43, 128, dtype=np.float32),
column_azimuths_rad=np.linspace(-np.pi, np.pi, 3600, endpoint=False, dtype=np.float32),
row_azimuth_offsets_rad=np.zeros(128, dtype=np.float32),
# nre-tools-ga requires these groups to exist even if empty
writer.register_component_writer(MasksComponent.Writer, “default”, group_name=None)
writer.register_component_writer(CuboidsComponent.Writer, “default”, group_name=None)
# One camera frame
img = (np.random.rand(480, 640, 3) * 255).astype(np.uint8)
ok, png = cv2.imencode(“.png”, img)
assert ok
cam = writer.register_component_writer(CameraSensorComponent.Writer, CAM, group_name=CAM)
cam.store_frame(png.tobytes(), “png”, np.array([T0 + 200_000, T0 + 200_000], dtype=np.uint64), {}, {})
# One lidar frame
lidar = writer.register_component_writer(LidarSensorComponent.Writer, LID, group_name=LID)
n = 1024
direction = np.random.randn(n, 3).astype(np.float32)
direction /= np.linalg.norm(direction, axis=1, keepdims=True)
lidar.store_frame(
direction,
(T0 + 300_000) * np.ones(n, dtype=np.uint64),
None,
np.full((1, n), 5.0, *dtype*=np.float32),
np.full((1, n), 0.5, *dtype*=np.float32),
np.array(\[T0 + 300_000, T0 + 300_000\], *dtype*=np.uint64),
stores = writer.finalize()
import json
from ncore.data.v4 import SequenceComponentGroupsReader
reader = SequenceComponentGroupsReader(stores, open_consolidated=True)
with open(OUT / f"{SEQ}.json", “w”) as f:
json.dump(reader.get_sequence_meta().to_dict(), f, *indent*=2, *sort_keys*=True)
print(“wrote”, OUT / f"{SEQ}.json")
### 2. Run training
```bash
docker run --rm --gpus all \
-e NGC_API_KEY=“$NGC_API_KEY” \
-e HYDRA_FULL_ERROR=1 \
--volume /tmp/ncore_repro:/workdir/dataset \
--volume /tmp/ncore_repro_out:/workdir/output \
nvcr.io/nvidia/nre/nre-ga:latest \
main \
--config-name=configs/apps/prod/Waymo/sqa_default.yaml \
mode=train \
out_dir=/workdir/output \
dataset.path=/workdir/dataset/tiny_seq_0001.json \
‘dataset.camera_ids=[camera_front_50fov]’ \
‘dataset.val_camera_ids=[camera_front_50fov]’ \
‘dataset.lidar_ids=[lidar_top]’ \
dataset.aux_data=False
### 3. Observed output (last 12 lines)
```text
[INFO] World Size: 1
[INFO] Node Count: 1
[INFO] Device Count per Node: 1
[INFO] Log every 50 steps
Seed set to 42
[INFO] Setting up TensorProber with config
RUN id: …
[INFO] Number of checkpoints to save: 30
[INFO] SODataModule: train_num_workers=24 val_num_workers=8 test_num_workers=8
[INFO] SequenceStoreReader: Loading component store …/tiny_seq_0001.ncore4-camera_front_50fov.zarr.itar
[INFO] SequenceStoreReader: Loading component store …/tiny_seq_0001.ncore4-lidar_top.zarr.itar
[INFO] SequenceStoreReader: Loading component store …/tiny_seq_0001.ncore4.zarr.itar
KeyError
Exit code 255. No traceback.
## What we’ve verified about the store
```python
from ncore.data.v4 import SequenceComponentGroupsReader, SequenceLoaderV4
import glob
paths = sorted(UPath(p) for p in glob.glob(“/tmp/ncore_repro/*.zarr.itar”))
loader = SequenceLoaderV4(SequenceComponentGroupsReader(paths))
print(loader.sequence_id) # tiny_seq_0001
print(loader.camera_ids) # [‘camera_front_50fov’]
print(loader.lidar_ids) # [‘lidar_top’]
cam = loader.get_camera_sensor(“camera_front_50fov”)
print(cam.frames_count) # 1
print(cam.T_sensor_rig.shape) # (4, 4)
print(type(cam.model_parameters)._name_)
# OpenCVPinholeCameraModelParameters
All three lookups (`camera_front_50fov` in `IntrinsicsComponent`, in
`CameraSensorComponent` group names, and in `PosesComponent.get_static_pose(
“camera_front_50fov”, “rig”)`) succeed and return self-consistent metadata. The
JSON manifest reflects the same key — see “Manifest snippet” below.
## Manifest snippet
`tiny_seq_0001.json` — produced by `SequenceComponentGroupsReader(…).get_sequence_meta()`:
```json
“version”: “v4”,
“sequence_id”: “tiny_seq_0001”,
“sequence_timestamp_interval_us”: {“start”: 1700000000000000, “stop”: 1700000001000000},
“generic_meta_data”: {
“rig_properties”: {“platform_name”: “hy8.1_tiny”, “layout”: “hyperion_8.1_tiny”}
“component_stores”: [
{"path": "tiny_seq_0001.ncore4-camera_front_50fov.zarr.itar",
“components”: {“cameras”: {“camera_front_50fov”: {“generic_meta_data”: {}, “version”: “v1”}}}},
{"path": "tiny_seq_0001.ncore4-lidar_top.zarr.itar",
“components”: {“lidars”: {“lidar_top”: {“generic_meta_data”: {}, “version”: “v1”}}}},
{"path": "tiny_seq_0001.ncore4.zarr.itar",
“components”: {
“poses”: {“default”: {“generic_meta_data”: {}, “version”: “v1”}},
“intrinsics”: {“default”: {“generic_meta_data”: {}, “version”: “v1”}},
“masks”: {“default”: {“generic_meta_data”: {}, “version”: “v1”}},
“cuboids”: {“default”: {“generic_meta_data”: {}, “version”: “v1”}}
## Findings from inspecting `pycena_run_cc`
The error message format (`KeyError\n’'` with no traceback) is produced by
a custom `sys.excepthook` installed by the obfuscated runner — see
`pycena_run_cc` ≈ offset 849069, function `11lllllll1lI1IlIIl11lllI1` calling
`sys.excepthook(BaseException, …)`. Setting `HYDRA_FULL_ERROR=1`,
`PYTHONFAULTHANDLER=1`, and injecting a `sitecustomize.py` via `PYTHONPATH` all
fail to surface the underlying traceback because the obfuscation layer
replaces `sys.excepthook` before user code runs.
Two relevant classes recovered from strings + bytecode shape:
```python
# pycena_run_cc, around offset 1716375
class SensorCalibProvider:
\_camera_ids: List\[str\]
\_sequence_id: str | None
def _init_(self, rig_trajectories):
self._camera_ids, self._sequence_id = _split(rig_trajectories)
def get_unique_sensor_id(self, camera_id: str) → str:
return f"{camera_id}@{self._sequence_id}" if self._sequence_id else camera_id
# pycena_run_cc, around offset 2273259
class TimestampFrameSampler:
cameras_frame_timestamps_us: Dict\[str, torch.Tensor\]   *# populated from rig_trajectory*
lidars_frame_timestamps_us:  Dict\[str, torch.Tensor\]
def _init_(self, dataset, …):
    rt = dataset.get_datasource().get_rig_trajectories()
self.cameras_frame_timestamps_us = rt.cameras_frame_timestamps_us
def sample_frame(self, rng, batch_idx, frame_range, unique_sensor_id):
    sensor_timestamps = self.cameras_frame_timestamps_us\[unique_sensor_id\]\[:, 0\].numpy()
# ^^^ KeyError: ‘<camera_id>’ here
The `KeyError`'s argument is the bare `camera_id` (no `@<sequence_id>`
suffix), so on this code path `_sequence_id` was `None`. That points at either
(a) some metadata field on the manifest / rig that NCore reads to populate
`_sequence_id`, which we’re not setting, or (b) the dict was populated under a
different key (e.g. logical sensor name vs. unique sensor id) and the
`sample_frame` lookup uses the bare form regardless.
Around offsets 986471 / 1865134 the rig-trajectory loader does iterate
`for uci in rig_trajectories: trajectory.camera_calibrations[uci].logical_sensor_name`,
which suggests the trajectory dict is keyed by some “unique camera id” derived
from the sequence. We haven’t been able to locate where that key is
materialized from the on-disk store.
## What we’ve tried that did not change the failure
| # | Variation | Result |
| 1 | 3 cameras, Kodiak-native names (`camera_front_left`, …) | `KeyError: ‘camera_front_left’` |
| 2 | 3 cameras, Hyperion-8.1 names (`camera_front_tele_30fov`, `camera_front_wide_120fov`, `camera_cross_right_120fov`) | `KeyError: ‘camera_front_tele_30fov’` |
| 3 | 1 camera, Waymo names (`camera_front_50fov` + `lidar_top`) — minimal repro above | `KeyError: ‘camera_front_50fov’` |
| 4 | Added `rig_properties.platform_name = “hy8.1_kodiak_research”` + `layout` in `generic_meta_data` | unchanged |
| 5 | Training configs: `apps/prod/Hyperion-8.1/car2sim_6cam.yaml`, `…/sqa_default.yaml`, `apps/prod/Waymo/sqa_default.yaml` | all same error |
| 6 | `dataset.aux_data=False`, plus `–no-ego-mask`, `–no-lidar-seg-camvis` | unchanged |
| 7 | `HYDRA_FULL_ERROR=1` + `PYTHONFAULTHANDLER=1` + sitecustomize-injected `sys.excepthook` | traceback still suppressed |
| 8 | Applied the [#76 / #77]( Waymo converter produces poses incompatible with NuRec training: missing `(world, world_global)` static pose · Issue #76 · NVIDIA/ncore · GitHub ) fix — rebased `(rig, world)` dynamic poses to be local to the first frame and added `(world, world_global)` static pose | **unchanged** — same `KeyError`. Distinct from the `ValueError: World-to-world_global poses are currently required…` reported in #76. |
## Questions
1. **What populates `cameras_frame_timestamps_us`?** Is it keyed by the
`CameraSensorComponent` group name, the `IntrinsicsComponent` camera id,
the `PosesComponent` static-pose source frame id, or something else
entirely (e.g. a `logical_sensor_name` field we haven’t set)?
2. **How is `SensorCalibProvider._sequence_id` populated?** Is it pulled from
`sequence_meta.sequence_id`, from `rig_properties`, or from a separate
`RigTrajectoriesComponent`-style block we should be emitting? In our
repro, `SequenceLoaderV4(…).sequence_id` returns the right value, but
the `SensorCalibProvider` clearly didn’t pick it up (the `KeyError` key
has no `@` suffix).
3. **Are `MasksComponent` / `CuboidsComponent` / a `PointCloudsComponent`
required to be non-empty for `nre-ga` to construct its rig trajectory?**
We register empty `default` groups for the first two (required by
`nre-tools-ga`) and emit no point cloud component.
4. **Is there a published `tiny_dataset` / reference NCore V4 sample we can
download and diff against?** The NCore tutorial
([data_loading.html]( NCore V4 Data Loading — NCore ))
references a `ncore-demo/sequence-ncore4.json` but doesn’t ship a
downloadable copy of the underlying `.zarr.itar` files.
5. Is there a documented `–config` or env var to **disable the
short-exception `sys.excepthook`** inside `pycena_run_cc` so we can see
the actual traceback? We tried `NRE_DEBUGPY_*` but couldn’t get a normal
traceback path even with `debugpy` attached.
## Why we care
We’re building a research prototype that converts logs from a custom AV
platform (Kodiak Robotics’ autonomous semi truck) into NCore V4 so we can
evaluate NuRec for closed-loop simulation. Everything upstream of the trainer
works — image and lidar capture, calibration, pose data, NCore loader
round-trip, `nre-tools-ga` aux-data generation in minimal mode — but we can’t
get past the dataset-construction step inside `nre-ga`. A pointer to the right
rig metadata, a documented contract for what the loader expects beyond the
public NCore V4 schema, or a diffable reference dataset (e.g. the
`ncore-demo/sequence-ncore4.json` referenced in the
[data_loading tutorial]( NCore V4 Data Loading — NCore ))
would unblock us. We’re happy to share our converter if that helps diagnose.
It would be helpful to share your converter for this community.
Can you please try following?
masks_writer =
++# After registering the masks writer, for EACH camera:
++masks_writer.store_camera_masks(“camera_front_50fov”, {})
Based on ncore/tools/data_converter/pai/converter.py at main · NVIDIA/ncore · GitHub
PAI always calls store_camera_masks(camera_id, mask_images) for every camera — even when mask_images is just an empty {} you might try store_observations for cuboid as well.
The NRE binary walks the masks component to discover which cameras exist for mask/segmentation association. When masks/default/cameras/ is empty (zero camera entries because store_camera_masks was never called) that agrees with “–segmentation-backend=none” working.
