Hi, I encountered two issues when using nurec’s val mode:
- When specifying parameters: OverrideParseException.
- Unrepaired parameters appeared in parsed.yaml.
environment
System Environment
Distributor ID: Ubuntu
Description: Ubuntu 20.04.6 LTS
Release: 20.04
Codename: focal
NVIDIA-SMI 550.127.08 Driver Version: 550.127.08 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA A100 80GB PCIe Off | 00000000:34:00.0 Off | 0 |
| N/A 77C P0 311W / 300W | 63391MiB / 81920MiB | 100% Default |
| | | Disabled
Copyright (c) 2005-2024 NVIDIA Corporation
Built on Tue_Feb_27_16:19:38_PST_2024
Cuda compilation tools, release 12.4, V12.4.99
Build cuda_12.4.r12.4/compiler.33961263_0
NuRrec environment
NuRec v26.2.158
Model v$26.2.158
nvcr.io/nvidia/nre/nre-tools-ga:latest
nvcr.io/nvidia/nre/nre-ga:latest
Execution process
Auxiliary data command
docker run --shm-size=2g -it --rm --gpus '"device=6"' \
--volume /share/home/hcy/NuRec/data/docker/dataset:/workdir/dataset \
--volume /share/home/hcy/NuRec/data/docker/output:/workdir/output \
nvcr.io/nvidia/nre/nre-tools-ga:latest \
--dataset-path=/workdir/dataset/yj/tj_short/my_custom_drive_001.json \
--output-dir=/workdir/output/yj/tj_short \
--store-meta \
--no-seg-logits \
--lidar-seg-camvis
log:
AuxiliaryData.log (4.3 KB)
Reconstruct command
docker run --shm-size=64g --rm --gpus '"device=6"' \
nvcr.io/nvidia/nre/nre-ga:latest \
mode=train \
out_dir=/workdir/output/reconstruction/yj/tj_short \
--config-name=configs/apps/prod/Hyperion-8.1/car2sim_6cam.yaml \
dataset.path=/workdir/dataset/yj/tj_short/my_custom_drive_001.json \
dataset.camera_ids=[cam_front] \
dataset.lidar_ids=[lidar_middle] \
dataset.aux_data=True \
model.layers.dynamic_deformables.tracks.label_classes.0=car \
dataset.cuboid_tracks_params.track_label_sources=null \
checkpoint.artifact.enabled=True \
dataset.n_samples_per_epoch=3000
log:
Reconstruct.log (69.9 KB)
parsed.yaml
parsed.yaml.txt (206.5 KB)
dataset.val_camera_ids
Validation(mode=val)
docker run --shm-size=64g --rm --gpus '"device=7"' \
--config-name=/workdir/output/reconstruction/yj/tj_short/iNWfKMyAewtQ97FBHQZyE3/config/parsed.yaml \
mode=val \
resume=/workdir/output/reconstruction/yj/tj_short/iNWfKMyAewtQ97FBHQZyE3/checkpoints/last.ckpt \
out_dir=/workdir/output/reconstruction/yj/tj_short/iNWfKMyAewtQ97FBHQZyE3/test \
dataset.val_camera_frame_step=1
Exception:
LexerNoViableAltException: dataset.path=/workdir/dataset/yj/tj_short/my_custom_drive_001.json
Temporary solution
Removing the specified parameters and moving them to parsed.yaml allows the program to run normally.
mode=val
Validation.log (12.6 KB)
