NV 257.21, GL 3.2 + CUDA and errors
I installed new drivers and now my application doesn’t work. Earlier I had sth like:
#version 150
#extension GL_EXT_geometry_shader4 : enable
precision highp float;
layout(triangles) in;
layout(triangle, max_vertices = 3) out;
gl_Position = gl_PositionIn[i];
and everything was ok. Now I got error:
error C3008: unknown layout specifier ‘triangle’
I changed “triangle” for “triangles”:
error C3008: unknown layout specifier ‘triangles’
#version 150 core
in vec4 glPositionIn[];
gl_Position = glPositionIn[i];
and same errors.
Few months ago I had same problem - I installed 197.25 but after updating to next version my program worked ok.
I checked other option: layout(max_vertices = 3) out; (instead (triangle, max_vertices = 3)). No compilation errors but the window shows only for short time and disappears in line:
cutilSafeCall(cudaGLRegisterBufferObject(myVBO[i].cVBO_normals));
  • CUDA error - “Runtime API error in … line … : out of memory”. :sick:
According to the GLSL 1.50 spec, the valid layout qualifier ID for a geometry shader is points, line_strip, or triangle_strip (see section 4.3.8.2).
