Hi!
I have a problem during flasing jetson tx2.
23:27:09.942 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: [host] [ Disk Avail:23.74 GB ]
23:27:09.943 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: Using GenericInstaller to Install NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP
23:27:09.943 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: change working directory to /home/ninux/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra
23:27:09.943 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: [ Component Install Started ]
23:27:09.943 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: current working directory is /home/ninux/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra
23:27:09.943 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: exec_command [host]:
23:27:09.943 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: **********************
23:27:09.943 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: #!/bin/bash
23:27:09.943 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: set -e
23:27:09.943 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: if [ -e ./bootloader/system.img ]; then
23:27:09.943 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: echo sudo ./flash.sh --no-systemimg jetson-tx2 mmcblk0p1
23:27:09.943 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: sudo ./flash.sh --no-systemimg jetson-tx2 mmcblk0p1
23:27:09.943 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: else
23:27:09.943 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: echo sudo ./flash.sh jetson-tx2 mmcblk0p1
23:27:09.943 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: sudo ./flash.sh jetson-tx2 mmcblk0p1
23:27:09.943 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: fi
23:27:09.943 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: sleep 20
23:27:09.944 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: **********************
23:27:09.944 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: exec_command: /tmp/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh
23:27:09.944 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: sudo ./flash.sh jetson-tx2 mmcblk0p1
23:27:09.944 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: ###############################################################################
23:27:09.944 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: # L4T BSP Information:
23:27:09.944 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: # R32 , REVISION: 4.4
23:27:09.944 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: Error: probing the target board failed.
23:27:09.944 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: Make sure the target board is connected through
23:27:09.944 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: USB port and is in recovery mode.
23:27:09.944 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: [ Component Install Finished with Error ]
23:27:09.944 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: [host] [ 4.00 KB used. Disk Avail: 23.74 GB ]
23:27:09.944 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: [ NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP Install took 0s ]
23:27:09.944 - error: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2: [error]: : [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh; [error]:
23:27:09.945 - info: Event: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2 - error is: [error]: : [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh; [error]:
23:27:09.945 - info: NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2:
23:27:09.945 - error: cmd finished failure SDKM_END_CODE_FAILURE_d5541038-cd85-4c72-a0cd-bb90dd843db7_11
how it can be solved?
