hi,
My system specs are:
Driver: 440.33.01
CUDA: 10.2
Docker: pytorch:19.12-py3
For a simple python file
foo.py
print(“foo”)
import torch
When I run
$ python foo.py
the application runs fine.
However, when I run
$ nv-nsight-cu-cli python foo.py
I get,
free(): invalid pointer
==ERROR== The application returned an error code (6)
==WARNING== No kernels were profiled
==WARNING== Profiling kernels launched by child processes requires the --target-processes all option
However, if I comment out the “import torch” statement, and run
the error goes away. This indicates that there is some weird interaction between nv-nsight-cu-cli and pytorch. I read a few related issues on github (https://github.com/pytorch/pytorch/issues/19739) and it appears this error could be because of the differences in the CXX_ABI flag (D_GLIBCXX_USE_CXX11_ABI) used to compile different libraries / binaries.
Can you please look into this?
