I’m trying to upgrade a board’s bootloader stack from R32.2 to R32.2.1 with nv_update_engine; things don’t seem to be behaving. I have generated the BUP and I get the following output from nv_update_engine in Linux, all looks good:
Nvidia A/B-Redundancy Update tool Version 1.2
current slot 0
Start updating slot 1
Tegra User Block Device: /dev/disk/by-partlabel
Tegra Boot Block Device: /dev/mmcblk0boot0
HEADER: MAGIC NVIDIA__BLOB__V2
HEX_VALUE 131072
BLOB_SIZE 5178144
HEADER_SIZE 48
NUMBER_OF_ELEMENTS 16
HEADER_TYPE 0
UNCOMP_SIZE 5178144
MB1_RATCHET_LV 0
MTS_RATCHET_LV 0
ROLLBACK_FUSE_LV 0
Device TN Spec: 3310-D01-1000-B.0-1-0-my-board-tx2-mmcblk0p3
Device is fused board.
ENTRY_TABLE:
PART POS LEN VER TNSPEC TYPE UPDATABLE
bpmp-fw 1968 533904 2 1 1
sce-fw 535872 125568 2 1 1
cpu-bootloader 661440 278176 2 1 1
mb2 939616 111648 2 0 1
spe-fw 1051264 95984 2 0 1
secure-os 1147248 313152 2 1 1
mb1 1460400 99664 2 2 1
mts-bootpack 1560064 2082144 2 1 1
mts-preboot 3642208 63104 2 0 1
sc7 3705312 23632 2 1 1
bpmp-fw-dtb 3728944 466240 2 3310-D01-1000-B.0-1-0-my-board-tx2-mmcblk0p3 1 1
bootloader-dtb 4195184 223840 2 3310-D01-1000-B.0-1-0-my-board-tx2-mmcblk0p3 1 1
BCT 4419024 3584 2 3310-D01-1000-B.0-1-0-my-board-tx2-mmcblk0p3 2 1
MB1_BCT 4422608 50016 2 3310-D01-1000-B.0-1-0-my-board-tx2-mmcblk0p3 0 1
kernel 4472624 481680 2 1 1
kernel-dtb 4954304 223840 2 3310-D01-1000-B.0-1-0-my-board-tx2-mmcblk0p3 1 1
Saving Entry table to /opt/ota_package/entry_table
Writing 533904 bytes to /dev/disk/by-partlabel/bpmp-fw_b for bpmp-fw
Writing 125568 bytes to /dev/disk/by-partlabel/sce-fw_b for sce-fw
Writing 278176 bytes to /dev/disk/by-partlabel/cpu-bootloader_b for cpu-bootloader
mb2 write: slot = 1 offset = 1276928 bytes = 111648
spe-fw write: slot = 1 offset = 883712 bytes = 95984
Writing 313152 bytes to /dev/disk/by-partlabel/secure-os_b for secure-os
Writing 2082144 bytes to /dev/disk/by-partlabel/mts-bootpack_b for mts-bootpack
mts-preboot write: slot = 1 offset = 1801216 bytes = 63104
Writing 23632 bytes to /dev/disk/by-partlabel/sc7_b for sc7
Writing 466240 bytes to /dev/disk/by-partlabel/bpmp-fw-dtb_b for bpmp-fw-dtb
Writing 223840 bytes to /dev/disk/by-partlabel/bootloader-dtb_b for bootloader-dtb
MB1_BCT write: slot = 1 offset = 622592 bytes = 50016
Writing 481680 bytes to /dev/disk/by-partlabel/kernel_b for kernel
Writing 223840 bytes to /dev/disk/by-partlabel/kernel-dtb_b for kernel-dtb
Update successful
Setting slot 1 as active boot slot
However, on the reboot, I see:
[0000.159] C> ERROR: Highest Layer Module = 0x40, Lowest Layer Module = 0x40,
Aux Info = 0x0, Reason = 0xd
[0000.139] C> ERROR: Highest Layer Module = 0x40, Lowest Layer Module = 0x40,
[0000.140] C> ERROR: Highest Layer Module = 0x40, Lowest Layer Module = 0x40,
[0000.194] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-1b47d5d9)
[0000.248] I> A/B: bin_type (16) slot 0
[0000.252] I> Loading partition bpmp-fw at 0xd7800000
[0000.283] I> A/B: bin_type (17) slot 0
[0000.287] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.490] I> Loading SCE-FW ...
[0000.493] I> A/B: bin_type (12) slot 0
[0000.497] I> Loading partition sce-fw at 0xd7300000
[0000.525] I> Loading APE-FW ...
[0000.528] I> A/B: bin_type (11) slot 0
[0000.531] I> Loading partition adsp-fw at 0xd7400000
[0000.560] I> A/B: bin_type (13) slot 0
[0000.563] I> Loading partition cpu-bootloader at 0x96000000
[0000.591] I> A/B: bin_type (20) slot 0
[0000.595] I> Loading partition bootloader-dtb at 0x8520f400
[0000.622] I> A/B: bin_type (14) slot 0
[0000.626] I> Loading partition secure-os at 0x8530f600
[0001.307] I> A/B: bin_type (21) slot 0
[0001.311] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.783] I> Loading kernel/boot.img from built-in storage ...
[0001.788] I> A/B: bin_type (24) slot 0
[0002.558] I> Loading partition kernel at 0x80400000 from device(0x1)
Those error messages don’t look good. And then slot #0 is used instead of slot#1, so the upgrade seems to be getting rejected. The documentation makes reference to a debug build of MB1 “that has [debug] messages available”. Is this available anywhere?
Edit: I don’t see the ERROR messages if I try to do a BUP from R32.2 to R32.2 (i.e. keep the same version of L4T). It looks like upgrading across releases does not work. However, even if I try to do just an R32.2 to R32.2 upgrade, things aren’t working right, as nvbootctrl get-current-slot
reports back 0
after the reboot even though slot 1 was actually used for the DTB & u-boot binaries during the boot.
