I try to run nv update engine on ramdisk based on JP5.0.2.
it reports errrors as follows:
/usr/sbin/nv_update_engine -i bl --payload /ota_work/bl_update_payload --no-reboot
Nvidia A/B-Redundancy Update tool Version 2.0
Got payload file: /ota_work/bl_update_payload
Error: read variable BootChainFwCurrent failed!
Error: installing bootloader updates failed: -5
Could you please help to check what’s wrong ? Thanks.
Thanks for your update. It seems JP5.02 doesn’t support AB redandunce update, but all slots update the same time.
However, for JP5.0.2 In normal rootfs(ubuntu brings up with UI), I can run cmds as follows: #nvbootctrl get-current-slot
0 #nvbootctrl dump-slots-info
Current bootloader slot: A
Active bootloader slot: A
num_slots: 2
slot: 0, status: normal
slot: 1, status: normal
If I change ramdisk init scripts run into ‘/bin/bash’, simiar issue was found as follows:
-bash-5.0# nvbootctrl get-current-slot
Invalid current slot found: -22(normally this means all slots are corrupted).
-bash-5.0# nvbootctrl dump-slots-info
Error: invalid current bootloader slot: return(-22)
could you please help to check what’s UEFI setting should be do to fix such issue? Thanks.
Yes, the previous code I did some change on jetpack4 to implement some update on ramdisk, which run nvbootctrl smoothly. However, after I switch to jetpack5/R35.1, such issue was found.
After some experiments, it seems due to efivar fs hasn’t been mount.
after mount efivarfs in ramdisk, it can be workable. Thanks #mount -t efivarfs efivarfs /sys/firmware/efi/efivars
