I met an unexpected error when using argus to grab image, the kernel log showed as link, it seems that RTCPU had met mistake, how can I solve this problem?
kernel_log.tar.gz (2.7 MB)
hello buaa_hebiao,
there’s FALCON_ERROR according to failure messages,
Aug 19 17:46:56 xavier nvargus-daemon[6150]: NvCaptureStatusErrorDecode Stream 2.0 failed: sof_ts 4181504009312 eof_ts 133808365476864 frame 58218 error 14 data 0x00020000
Aug 19 17:46:56 xavier nvargus-daemon[6150]: NvCaptureStatusErrorDecode Capture-Error: FALCON_ERROR (0x0000000e)
Aug 19 17:46:56 xavier nvargus-daemon[6150]: SCF: Error InvalidState: Capture error with status 14 (channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 913)
Aug 19 17:46:56 xavier nvargus-daemon[6150]: NvCaptureStatusErrorDecode Stream 2.0 failed: sof_ts 4181529096640 eof_ts 133809167185920 frame 58219 error 14 data 0x00020000
Aug 19 17:46:56 xavier nvargus-daemon[6150]: NvCaptureStatusErrorDecode Stream 2.0 failed: sof_ts 4181554021024 eof_ts 133809965151232 frame 58220 error 14 data 0x00020000
Aug 19 17:46:56 xavier nvargus-daemon[6150]: NvCaptureStatusErrorDecode Stream 2.0 failed: sof_ts 4181579017440 eof_ts 133810765621248 frame 58221 error 14 data 0x00020000
Aug 19 17:46:58 xavier nvargus-daemon[6150]: SCF: Error Timeout: (propagating from src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 884)
Aug 19 17:46:58 xavier nvargus-daemon[6150]: SCF: Error InvalidState: Timeout waiting on frame end sensor guid 2, capture sequence ID = 123697, channel = 1/1 (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 891)
Aug 19 17:46:58 xavier kernel: [ 4177.032411] tegra194-vi5 15c10000.vi: no reply from camera processor
Aug 19 17:46:58 xavier kernel: [ 4177.032567] tegra194-vi5 15c10000.vi: vi capture get status failed:(-110)
Aug 19 17:46:58 xavier kernel: [ 4177.036430] fence timeout on [ffffffc13b0c30c0] after 1500ms
Aug 19 17:46:58 xavier nvargus-daemon[6150]: SCF: Error Timeout: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 990)
Aug 19 17:46:58 xavier nvargus-daemon[6150]: SCF: Error InvalidState: Something went wrong with waiting on frame end (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 972)
may I know which JetPack release you’re working with?
could you please also share your use-case, or please share the commands you’re used for testing.
thanks
I’m facing the same issue and I’d need help to overcome this.
Aug 15 08:23:42 sam nvargus-daemon[5950]: SCF: Error InvalidState: Capture error with status 14 (channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 913)
Aug 15 08:23:42 sam nvargus-daemon[5950]: NvCaptureStatusErrorDecode Stream 0.0 failed: sof_ts 762157912320 eof_ts 24390080635904 frame 0 error 14 data 0x00020000
Aug 15 08:23:42 sam nvargus-daemon[5950]: NvCaptureStatusErrorDecode Capture-Error: FALCON_ERROR (0x0000000e)
Aug 15 08:23:42 sam nvargus-daemon[5950]: NvCaptureStatusErrorDecode Stream 0.0 failed: sof_ts 762191245472 eof_ts 24391147298816 frame 0 error 14 data 0x00020000
I’m using Jetson Xavier 4.2. Driver pkg 32.2
the system also includes some serdeses:
s5k2g1-sensor → mipi → max9295 → gmsl → max9296 → mipi → Jetson
While the video stream is playing this error keeps showing up against every frame
hello peter.sh.rosen,
interesting, may I know what’s the preview frame-rate?
could you please also share the commands to access your SerDes camera sensors,
thanks
the frame rate is 30fps
not sure I understand this request.
max9296 and max9295 have their own drivers
thanks
- am I understand correctly that you could saw output streaming as 30-fps “and” shown Argus failure messages?
- please share the user-space commands to access camera sensor for review, such as $ gst-launch-1.0 nvarguscamerasrc…
argus_camera
