Nvargus-daemon fails during runtime and camera stops streaming
I’m running a GStreamer pipeline on a Jetson Orin Nano with an Arducam IMX 477 (UC-698) camera. The pipeline will fail with a CONSUMER: ERROR OCCURRED message that comes from the GStreamer library.
When this happens, if I check the syslog, I see the following from the arducam-daemon:
Jan 08 04:57:50 jonano nvargus-daemon[890]: Module_id 30 Severity 2 : (fusa) Error: InvalidState Status syncpoint signaled but status value not updated in:/capture/src/fusaViHandler.cpp 861
Jan 08 04:57:50 jonano nvargus-daemon[890]: Module_id 30 Severity 2 : (fusa) Error: InvalidState propagating from:/capture/src/fusaViHandler.cpp 803
Jan 08 04:57:50 jonano nvargus-daemon[890]: SCF: Error InvalidState: Corr Error 8 Received for sensor 1 … Continuing!
Jan 08 04:57:50 jonano nvargus-daemon[890]: (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 652)
Jan 08 04:57:51 jonano nvargus-daemon[890]: SCF: Error Timeout: (propagating from src/components/amr/Snapshot.cpp, function waitForNewerSample(), line 91)
Jan 08 04:57:51 jonano nvargus-daemon[890]: SCF_AutocontrolACSync failed to wait for an earlier frame to complete.
Jan 08 04:57:51 jonano nvargus-daemon[890]: SCF: Error Timeout: (propagating from src/components/ac_stages/ACSynchronizeStage.cpp, function doHandleRequest(), line 145)
Jan 08 04:57:51 jonano nvargus-daemon[890]: SCF: Error Timeout: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 137)
Jan 08 04:57:51 jonano nvargus-daemon[890]: SCF: Error Timeout: Sending critical error event for Session 1
Jan 08 04:57:51 jonano nvargus-daemon[890]: (in src/api/Session.cpp, function sendErrorEvent(), line 1039)
Jan 08 04:57:51 jonano basic_pipeline.jetson_orin_nano[1012]: CONSUMER: ERROR OCCURRED
Here is the launch string I’m using:
nvarguscamerasrc name=mysource do-timestamp=true ! nvvidconv flip-method=2 ! video/x-raw(memory:NVMM),width=1920,height=1080,framerate=30/1,format=NV12 ! nvvidconv ! x264enc pass=cbr bitrate=4096 insert-vui=true tune=zerolatency speed-preset=ultrafast ! tee name=t ! queue ! appsink name=encoded_sink t. ! queue ! openh264dec ! nvvidconv ! video/x-raw,format=RGBA,width=224,height=224 ! videorate max-rate=10 ! videoconvert ! video/x-raw,format=RGB ! appsink name=raw_sink
I have seen similar posts that suggest to boost the clocks. I’ve tried using sudo jetson_clocks prior to starting the camera streaming, but no change.
Any suggestions for how to fix or to further debug?
What’s the version?
Check below link to find if any patch for your version.
https://elinux.org/Jetson/L4T
Hi Shane,
I’m running 36.3. I checked through the list of patches. Nothing seems related.
culinairy@culinairy-jonano:~$ cat /etc/nv_tegra_release
# R36 (release), REVISION: 3.0, GCID: 36106755, BOARD: generic, EABI: aarch64, DATE: Thu Apr 25 03:14:05 UTC 2024
Any idea what would cause the issues in the output above? Any debugging help would be greatly appreciated.
I would suggest upgrade to r36.4 to apply below change for stability issue.
