Nvargus-daemon problem integrating camera
I’m bringing up a custom carrier board with a custom camera and facing some issues with nvargus-daemon.
I have integrated the camera. Have a device node in /dev/video0 and is able to get picture from it with v4l. But when trying to use `nvarguscamerasrc` I can’t getting it to work.
# gst-launch-1.0 nvarguscamerasrc sensor-id=0 num-buffers=1 !  'video/x-raw(memory:NVMM), width=2472, height=2064, framerate=60/1' !  nvvidconv !  nvjpegenc ! filesink location=capture.jpg
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Error generated. gstnvarguscamerasrc.cpp, execute:803 No cameras available
Redistribute latency...
Got EOS from element "pipeline0".
Execution ended after 0:00:00.003857129
Setting pipeline to NULL ...
Freeing pipeline ...
And here is the log from nvargus-daemon that I think is where the error is:
Jan 01 01:31:12 hostname nvargus-daemon[5185]: === gst-launch-1.05549)[5549]: Connection established (FFFF8F7398E0)
Jan 01 01:31:12 hostname nvargus-daemon[5185]: libEGL warning: pci id for fd 9: 10de:2b00, driver (null)
Jan 01 01:31:12 hostname nvargus-daemon[5185]: pci id for fd 10: 10de:2b00, driver (null)
Jan 01 01:31:12 hostname nvargus-daemon[5185]: kmsro: driver missing
Jan 01 01:31:12 hostname nvargus-daemon[5185]: libEGL warning: egl: failed to create dri2 screen
Jan 01 01:31:12 hostname nvargus-daemon[5185]: SCF: Error 0x00000006: Unable to initialize EGL (in src/services/gl/GLService.cpp, function initialize(), line 144)
Jan 01 01:31:12 hostname nvargus-daemon[5185]: SCF: Error 0x00000006:  (propagating from src/services/gl/GLService.cpp, function startService(), line 46)
Jan 01 01:31:12 hostname nvargus-daemon[5185]: SCF: Error 0x00000006:  (propagating from src/components/ServiceHost.cpp, function startServices(), line 142)
Jan 01 01:31:12 hostname nvargus-daemon[5185]: CaptureService:stop: is requested --------------------------
Jan 01 01:31:12 hostname nvargus-daemon[5185]: SCF: Error 0x00000006:  (propagating from src/api/CameraDriver.cpp, function initialize(), line 182)
Jan 01 01:31:12 hostname nvargus-daemon[5185]: SCF: Error 0x00000008: Services are already stopped (in src/components/ServiceHost.cpp, function stopServicesInternal(), line 193)
Jan 01 01:31:12 hostname nvargus-daemon[5185]: SCF: Error 0x00000006:  (propagating from src/api/CameraDriver.cpp, function getCameraDriver(), line 120)
Jan 01 01:31:12 hostname nvargus-daemon[5185]: (Argus) Error 0x00000006:  (propagating from src/api/GlobalProcessState.cpp, function createCameraProvider(), line 210)
Jan 01 01:31:12 hostname nvargus-daemon[5185]: === gst-launch-1.05549)[5549]: CameraProvider failed to initialize
Jan 01 01:31:12 hostname nvargus-daemon[5185]: === gst-launch-1.05549)[5549]: Connection closed (FFFF8F7398E0)
Jan 01 01:31:12 hostname nvargus-daemon[5185]: === gst-launch-1.05549)[5549]: Connection cleaned up (FFFF8F7398E0)
It would be great to get some insights here.
I’m facing same issues here :(
The error tell incorrect context in tegra_camera_platorm{} make argus can’t detect any camera.
@ShaneCCC and can you give us a hint why it can not detect any camera and where to start digging? I haven’t found any open source code to argus-daemon so it is really hard to debug.
I have my cameras available in the system. It is possible to use v4l-ctl to capture a picture. In what way do argus-daemon look for the cameras?
  1. Dump the device tree to confirm the tegra_camera_platform{}
sudo dtc -I fs -O dts -o extracted_proc.dts /sys/firmware/devicetree/base
Get the device info by below command.
v4l2-ctl --list-devices
v4l2-ctl --all
@ShaneCCC here is the output from my system:
# v4l2-ctl --list-devices
NVIDIA Tegra Video Input Device (platform:tegra-capture-vi):
        /dev/media0
vi-output, imx568 18-003d (platform:tegra-capture-vi:2):
        /dev/video0
vi-output, imx568 19-003c (platform:tegra-capture-vi:4):
        /dev/video1
# v4l2-ctl --all
Driver Info:
        Driver name      : tegra-video
        Card type        : vi-output, imx568 18-003d
        Bus info         : platform:tegra-capture-vi:2
        Driver version   : 6.8.12
        Capabilities     : 0x84200001
                Video Capture
                Streaming
                Extended Pix Format
                Device Capabilities
        Device Caps      : 0x04200001
                Video Capture
                Streaming
                Extended Pix Format
Priority: 2
Video input : 0 (Camera 2: ok)
Format Video Capture:
        Width/Height      : 2472/2064
        Pixel Format      : 'RG10' (10-bit Bayer RGRG/GBGB)
        Field             : None
        Bytes per Line    : 4944
        Size Image        : 10204416
        Colorspace        : sRGB
        Transfer Function : Default (maps to sRGB)
        YCbCr/HSV Encoding: Default (maps to ITU-R 601)
        Quantization      : Default (maps to Full Range)
        Flags             :
Streaming Parameters Video Capture:
        Capabilities     : timeperframe
        Frames per second: 79.000 (79/1)
        Read buffers     : 0
Camera Controls
                     group_hold 0x009a2003 (bool)   : default=0 value=0 flags=execute-on-write
                    sensor_mode 0x009a2008 (int64)  : min=0 max=3 step=1 default=0 value=0 flags=slider
                           gain 0x009a2009 (int64)  : min=10 max=241 step=1 default=10 value=10 flags=slider
                       exposure 0x009a200a (int64)  : min=7 max=12651 step=1 default=10000 value=7 flags=slider
                     frame_rate 0x009a200b (int64)  : min=79000000 max=79000000 step=1 default=79000000 value=79000000 flags=slider
           sensor_configuration 0x009a2032 (u32)    : min=0 max=4294967295 step=1 default=0 dims=[22] flags=read-only, volatile, has-payload
         sensor_mode_i2c_packet 0x009a2033 (u32)    : min=0 max=4294967295 step=1 default=0 dims=[1026] flags=read-only, volatile, has-payload
      sensor_control_i2c_packet 0x009a2034 (u32)    : min=0 max=4294967295 step=1 default=0 dims=[1026] flags=read-only, volatile, has-payload
                    bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=0 (0 0x0)
                                0: 0 (0x0)
                                1: 1 (0x1)
                override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=0 (0 0x0)
                                0: 0 (0x0)
                                1: 1 (0x1)
                   height_align 0x009a2066 (int)    : min=1 max=16 step=1 default=1 value=1
                     size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0 (1 0x1)
                                0: 1 (0x1)
                                1: 65536 (0x10000)
                                2: 131072 (0x20000)
               write_isp_format 0x009a2068 (int)    : min=1 max=1 step=1 default=1 value=1
       sensor_signal_properties 0x009a2069 (u32)    : min=0 max=4294967295 step=1 default=0 dims=[30][18] flags=read-only, has-payload
        sensor_image_properties 0x009a206a (u32)    : min=0 max=4294967295 step=1 default=0 dims=[30][16] flags=read-only, has-payload
      sensor_control_properties 0x009a206b (u32)    : min=0 max=4294967295 step=1 default=0 dims=[30][36] flags=read-only, has-payload
              sensor_dv_timings 0x009a206c (u32)    : min=0 max=4294967295 step=1 default=0 dims=[30][16] flags=read-only, has-payload
               low_latency_mode 0x009a206d (bool)   : default=0 value=0
               preferred_stride 0x009a206e (int)    : min=0 max=65535 step=1 default=0 value=0
    override_capture_timeout_ms 0x009a206f (int)    : min=-1 max=2147483647 step=1 default=2500 value=2500
                   sensor_modes 0x009a2082 (int)    : min=0 max=30 step=1 default=30 value=3 flags=read-only
extracted_proc.dts.txt (338.7 KB)
Device tree looks fine.
Could be EGL driver didn’t load.
Have below command first.
export DISPLAY=:0
gst-launch-1.0 .....
I realized I had several EGL libraries in my rootfs and the one that was loaded was `libEGL_mesa.so.0`. This didn’t have support for Thor and the `Unable to initialize EGL` error was probably due to that.
I have changed my rootfs and now the library `libEGL_nvidia.so.0` is loaded by `nvargus-daemon`. The result at the top is similar, no cameras available for argus but under the hood the error message has changed a bit to `No EGL device available`.
Here is the new output:
# DISPLAY=:0 /usr/sbin/nvargus-daemon
=== NVIDIA Libargus Camera Service (0.99.33)
=== Listening for connections...
=== gst-launch-1.05221)[5221]: Connection established (FFFF75E998E0)
��INFO: END TASK:MB��
INFO: enter idle task.
INFO: END TASK:MB��
��ph =��ter idle ta��GPC ��sk.
        ��> logic map: 0=>0 1=>2 2=>1
��SCF: Error 0x00000002: No EGL device available (in src/services/gl/GLService.cpp, function initialize(), line 128)
SCF: Error 0x00000002:  (propagating from src/services/gl/GLService.cpp, function startService(), line 46)
SCF: Error 0x00000002:  (propagating from src/components/ServiceHost.cpp, function startServices(), line 142)
SCF: Error 0x00000008: Service not running (in src/services/gl/GLService.cpp, function stopService(), line 55)
SCF: Error 0x00000008:  (propagating from src/components/ServiceHost.cpp, function stopServicesInternal(), line 208)
SCF: Error 0x00000002:  (propagating from src/api/CameraDriver.cpp, function initialize(), line 182)
SCF: Error 0x00000002:  (propagating from src/api/CameraDriver.cpp, function getCameraDriver(), line 120)
(Argus) Error 0x00000002:  (propagating from src/api/GlobalProcessState.cpp, function createCameraProvider(), line 210)
=== gst-launch-1.05221)[5221]: CameraProvider failed to initialize
=== gst-launch-1.05221)[5221]: Connection closed (FFFF75E998E0)
=== gst-launch-1.05221)[5221]: Connection cleaned up (FFFF75E998E0)
I’m building my rootfs with meta-tegra and Yocto. I have used LD_DEBUG and strace to see what happens in nvargus-daemon and I share it in the attached file. Can you please take a look and try to help out to fins the reason that no EGL devices is found?
nvargus.log (446.0 KB)
Could you flash the system by sdkmanager again.
No. It is a custom board with a Thor module.
I have a Thor dev-kit with JP7 and my custom board with custom image. My `nvargus_daemon`seems to fail when trying to initialize EGL and for that reason I have this EGL reproducer that I run on both systems:
#include <stdio.h>
#include <dlfcn.h>
#include <EGL/egl.h>
int main() {
    void *handle;
    handle = dlopen("libnvidia-eglcore.so.580.00", RTLD_NOW);
    if (!handle) {
        fprintf(stderr, "Failed to load libnvidia-eglcore.so.580.00: %s\n", dlerror());
        return 1;
    printf("libnvidia-eglcore.so.580.00 loaded successfully.\n");
    // Try a simple EGL query
    EGLDisplay dpy = eglGetDisplay(EGL_DEFAULT_DISPLAY);
    if (dpy == EGL_NO_DISPLAY) {
        fprintf(stderr, "eglGetDisplay failed\n");
        dlclose(handle);
        return 1;
    if (!eglInitialize(dpy, NULL, NULL)) {
        fprintf(stderr, "eglInitialize failed\n");
        dlclose(handle);
        return 1;
    printf("EGL initialized successfully.\n");
    eglTerminate(dpy);
    dlclose(handle);
    return 0;
On my dev-kit the output is:
# ./test_egl
On my custom board the output is:
# ./test_egl
So the function `eglInitialize` have different return values on the different platforms. I have made sure the setup of libraries are similar. Tried to work with `strace` and `LD_DEBUG` to understand the difference. I attach the logs from the two. Just before the return it starts working with `/dev/nvidia0` and sending ioctl’s to that node.
I have observed one difference in the reference of the kernel modules. On my custom board there are no users of the drivers `nvidia_drm` or `tegra_drm`. On the dev-kit during execution the `/dev/nvidia1` is opened but that does not happen on my custom board, but it is present in both. Also some difference when searhing for drm in the kernel log that I show here:
dev-kit:
# dmesg | grep -i drm
[    7.096887] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[    7.762612] [drm] Initialized tegra 1.0.99 20120330 for 8181200000.host1x.drm on minor 0
[   11.995036]  tegra234_oc_event(O) r8126(O) rfkill snd_hda_codec_hdmi tegra23x_psc(O) snd_soc_rt5640 nvethernet(O) tegra_aconnect snd_soc_rl6231 thermal_trip_event(O) tegra_cactmon_mc_all(O) nvidia_vrs_pseq(O) lm90 snd_hda_tegra snd_hda_codec at24 mttcan(O) snd_hda_core host1x_fence(O) nvpps(O) can_dev pwm_tegra_tachometer(O) nvidia_cspmu ramoops spi_tegra114 tegra_dce(O) reed_solomon arm_cspmu_module tpm_ftpm_tee camera_diagnostics(O) nvhost_isp5(O) tegra_capture_isp(O) tegra_camera(O) v4l2_dv_timings host1x_nvhost(O) tegra_drm(O) tegra_wmark(O) nvhwpm(O) drm_display_helper drm_dp_aux_bus cec drm_kms_helper host1x(O) tegra_camera_platform(O) mc_utils(O) capture_ivc(O) v4l2_fwnode v4l2_async videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videodev videobuf2_common mc camchar(O) rtcpu_debug(O) tegra_camera_rtcpu(O) ivc_bus(O) hsp_mailbox_client(O) nvme_fabrics fuse drm nfnetlink ip_tables x_tables ipv6 pwm_fan pwm_tegra tegra_bpmp_thermal tegra_xudc uas ucsi_ccg typec_ucsi typec nvme nvme_core phy_tegra194_p2u
[   12.033654] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[   12.995781] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[   12.995794] nvidia 0000:01:00.0: [drm] No compatible format found
[   12.995809] nvidia 0000:01:00.0: [drm] Cannot find any crtc or sizes
[   12.995837] [drm] [nvidia-drm] [GPU ID 0x00020000] Loading driver
[   13.340936] [drm] Initialized nvidia-drm 0.0.0 20160202 for 8808c00000.display on minor 2
[   13.340941] [drm] [nvidia-drm] [GPU ID 0x00020000] Invalid framebuffer console info
[   13.350038] nv_platform 8808c00000.display: [drm] Cannot find any crtc or sizes
custom board:
[   14.070696] systemd[1]: Starting Load Kernel Module drm...
[   14.525650] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   14.527076] systemd[1]: Finished Load Kernel Module drm.
[   18.212023] [drm] Initialized tegra 1.0.99 20120330 for 8181200000.host1x.drm on minor 0
[   21.480082] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[   22.690216] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[   22.690239] nvidia 0000:01:00.0: [drm] No compatible format found
[   22.690245] nvidia 0000:01:00.0: [drm] Cannot find any crtc or sizes
One obvious difference is that my custom board is headless and have no display interface. Any ideas around this issue and how to get `nvargus_daemon`running are welcome!
test_egl.dev-kit.log (239.9 KB)
test_egl.custom.log (201.9 KB)
One step ahead. You must have a display configured in your device-tree even if it is a headless system. In my case I had to enable this in my dts:
        display@8808c00000 {
               status = "okay";
               nvdisplay-niso {
                       status = "okay";
This made a new dri device node called `dev/dri/card2` and with this my EGL test program works. I can also list my cameras in argus with `argus_oneshot -l`.
Below for headless referecing.
What kind of reference is this @ShaneCCC ? For me kind of irrelevant from what I found. The reference is talking about to disable the display node and I found I must have the display node enabled. Please clarify this.
Maybe it could be different for Thor(JP7)
Thanks for the information.
