I am using TX2 sdk 32.4.3 and trying to capture video of sensor ov9732 using gstlaunch+ nvargus camerasrc.
using this command:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM),width=1280, height=720, framerate=30/1, format=NV12’ ! omxh264enc control-rate=2 bitrate=2000000 ! splitmuxsink max-files=3 send-keyframe-requests=true location=/home/ubuntu/videos/left_video%02d.mp4 max-size-time=30000000000 -e &
I am getting below nvargus deamon error during capture
===========console log===================
root@tegra-ubuntu:/home/ubuntu# Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 40
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:557 No cameras avaie
ERROR: from element /GstPipeline:pipeline0/GstSplitMuxSink:splitmuxsink0/GstMP4Mux:muxer: Downstream is not seekable - will not be able to cree
Additional debug info:
gstqtmux.c(2780): gst_qt_mux_start_file (): /GstPipeline:pipeline0/GstSplitMuxSink:splitmuxsink0/GstMP4Mux:muxer
EOS on shutdown enabled – waiting for EOS after Error
Waiting for EOS…
================syslog======================
an 27 10:26:29 localhost nvargus-daemon[7940]: === NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections…=== gst-launch-1.0[
8150]: Connection established (7F9AB551D0)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
Jan 27 10:26:29 localhost nvargus-daemon[7940]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
Jan 27 10:26:29 localhost nvargus-daemon[7940]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
Jan 27 10:26:29 localhost nvargus-daemon[7940]: NvPclHwGetModuleList: No module data found
Jan 27 10:26:29 localhost kernel: [ 189.234064] ov2735 2-003c: ov2735_power_on: power on exit
Jan 27 10:26:29 localhost kernel: [ 189.273600] ov2735 2-003c: ov2735_power_on: power on exit
Jan 27 10:26:29 localhost nvargus-daemon[7940]: message repeated 2 times: [ NvPclHwGetModuleList: No module data found]
Jan 27 10:26:29 localhost nvargus-daemon[7940]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Jan 27 10:26:29 localhost nvargus-daemon[7940]: ---- imager: Found override file [/var/nvidia/nvcam/settings/e33_topleft_P5V27C.isp]. ----
Jan 27 10:26:29 localhost nvargus-daemon[7940]: NvCameraIspConfigFileLoad: type = 0x75 Config file “sensor.cfg” Line 220: Error: Invalid isp c
onfig attribute: “detailenhancement.NumOfEntries=9”
Jan 27 10:26:29 localhost nvargus-daemon[7940]: NvCameraIspUnpackingBlob 156: Blob: Wrong magic number!
Jan 27 10:26:29 localhost nvargus-daemon[7940]: CAM: serial no file already exists, skips storing again---- imager: Found override file [/var/
nvidia/nvcam/settings/e33_centerright_P5V27C.isp]. ----
Jan 27 10:26:29 localhost nvargus-daemon[7940]: CAM: serial no file already exists, skips storing again---- imager: No override file found. -
Jan 27 10:26:29 localhost nvargus-daemon[7940]: LSC: LSC surface is not based on full res!
Jan 27 10:26:29 localhost nvargus-daemon: E/ libnvphs:socket: Error[2]: socket connection /var/lib/nvphs/nvphsd.ctl to PHS failed: No such fil
e or directory
Jan 27 10:26:29 localhost nvargus-daemon: D/ libnvphs:socket: Warning: connecting to Power Hinting Service failed. Is PHS running?
Jan 27 10:26:29 localhost nvargus-daemon[7940]: === gst-launch-1.0[8150]: CameraProvider initialized (0x7f94c89d70)SCF: Error BadValue: NvPHSS
endThroughputHints (in src/common/CameraPowerHint.cpp, function sendCameraPowerHint(), line 56)
e or directory
Jan 27 10:26:29 localhost nvargus-daemon: E/ libnvphs: Error: NvPHSSendThroughputHints[usecase=camera, hint=MinCPU, value=4294967295, timeout_
ms=1000]: queue_or_send() failed
Jan 27 10:26:29 localhost nvargus-daemon[7940]: CAM: serial no file already exists, skips storing againNvCameraIspConfigFileLoad: type = 0x75
Config file “sensor.cfg” Line 220: Error: Invalid isp config attribute: “detailenhancement.NumOfEntries=9”
Jan 27 10:27:17 localhost nvargus-daemon[7940]: CAM: serial no file already exists, skips storing again=== gst-launch-1.0[8150]: Connection cl
osed (7F9AB551D0)=== gst-launch-1.0[8150]: WARNING: CameraProvider was not destroyed before client connection terminated.=== gst-launch-1.0[81
50]: The client may have abnormally terminated. Destroying CameraProvider…=== gst-launch-1.0[8150]: CameraProvider destroyed (0x7f9
4c89d70)=== gst-launch-1.0[8150]: WARNING: Cleaning up 3 outstanding requests…=== gst-launch-1.0[8150]: WARNING: Cleaning up 3 outstanding s
treams…SCF: Error InvalidState: 5 buffers still pending during EGLStreamProducer destruction (propagating from src/services/gl/EGLStreamProd
ucer.cpp, function freeBuffers(), line 306)
Jan 27 10:27:17 localhost nvargus-daemon[7940]: SCF: Error InvalidState: (propagating from src/services/gl/EGLStreamProducer.cpp, function ~E
GLStreamProducer(), line 50)
Jan 27 10:27:17 localhost nvargus-daemon[7940]: SCF: Error InvalidState: 5 buffers still pending during EGLStreamProducer destruction (propaga
ting from src/services/gl/EGLStreamProducer.cpp, function freeBuffers(), line 306)
any help will be appricated,using SDK 32.4.3
