Nvargus_nvraw error printout
Hello Nvidia,
I’m trying dump raw image by “nvargus-nvraw”, it seems that output image is fine, while a lot of error message captured in nvargus-daemon. can you help to find what’s wrong with the mmapi?
my platform is jetson orin agx and jetpack R35.1
here is the command of nvargus_nvraw it’s output:
$ nvargus_nvraw --file demo --format "raw"
nvargus_nvraw version 1.13.1
capture: Total captured frame count 90
+------ Exposure info results -----------+
Exposure | Exposure Time | Sensor Gain |
       0 |      0.006311 |     5.80000 |
       1 |      0.000025 |     5.80000 |
HDR Ratio: 256.00
Note: The ratio between the Exposure Time in Exposure 0 and
      the Exposure Time in Exposure 1 is equal to HDR Ratio
writeToFile: files demo.raw and demo.txt are successfully created
and the output of nvargus-daemon:
$ === NVIDIA Libargus Camera Service (0.98.3)=== Listening for connections...=== nvargus_nvraw[1220383]: Connection established (FFFF7C1F0900)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module3
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module4
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module5
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module6
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module7
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: Found override file [/var/nvidia/nvcam/settings/ar0820_front_0120.isp]. ----
CAM: serial no file already exists, skips storing again---- imager: Found override file [/var/nvidia/nvcam/settings/ar0820_front_0030.isp]. ----
CAM: serial no file already exists, skips storing again---- imager: Found override file [/var/nvidia/nvcam/settings/ar0820_rear_0070.isp]. ----
CAM: serial no file already exists, skips storing again---- imager: No override file found. ----
LSC: LSC surface is not based on full res!
---- imager: Found override file [/var/nvidia/nvcam/settings/ar0820_frontleft_0120.isp]. ----
CAM: serial no file already exists, skips storing again---- imager: Found override file [/var/nvidia/nvcam/settings/ar0820_rearleft_0120.isp]. ----
CAM: serial no file already exists, skips storing again---- imager: Found override file [/var/nvidia/nvcam/settings/ar0820_frontright_0120.isp]. ----
CAM: serial no file already exists, skips storing again(Argus) Error BadParameter: Unidentified sensor placement (in src/common/ScfTranslate.cpp, function fromScfSensorPlacement(), line 592)
---- imager: Found override file [/var/nvidia/nvcam/settings/ar0820_rearright_0120.isp]. ----
=== nvargus_nvraw[1220383]: CameraProvider initialized (0xffff747021a0)SCF: Error BadValue: NvPHSSendThroughputHints (in src/common/CameraPowerHint.cpp, function sendCameraPowerHint(), line 56)
CAM: serial no file already exists, skips storing again(NvCameraIspMergeExt) Error BadParameter: NvColorSpace_NonColor is set for isp for isp capture (in merge/NvCameraIspMergeExt.cpp, function isYuvColorSpace(), line 1327)
Best regards
We have later release r35.3.1(Jetpack 5.1.1). Could you upgrade and give it a try? We would suggest use latest release.
