Nvarguscamerasrc camera order
Hi, when I have 2 cameras plugged into the jetson nx dev board, nvarguscamerasrc sensor-id=1 displays output from CAM0 on the board, and sensor-id=0 displays CAM1.
Is this the intended operation?
Just to be sure, which connector is CAM0 for you when the CSI connectors are in front of you ?
On my NX dev board, AFAIK it is the left one (the right one being close to barrel jack power connector).
Not sure, but I think this is the opposite as compared to early Nano dev boards, maybe this can explain.
Or do you have a different DT than standard one for your cameras ?
