Nvarguscamerasrc can not open camera with some errors
Remove these functions from driver, can not open with nvargus.
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Group Hold control not found! (cid = 0) ! Group Hold control is needed to prevent unexpected AE/Gain issues! If sensor does not support Group Hold, please create a dummy Group Hold control in kernel driver that always return success.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!(NvOdmDevice) Error BadParameter:  (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function findCustomCids(), line 424)
(NvOdmDevice) Error BadParameter:  (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initializeV4L2Items(), line 317)
(NvOdmDevice) Error BadParameter:  (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 121)
NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
NvPclStartPlatformDrivers: Failed to start module drivers
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xaaaab8e61e90
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffffa0aadbc0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffffa0aadca0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffffa0a1ab00
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffffa0a2d800
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffffa0a2c640
NvPclStateControllerOpen: Failed ImagerGUID 0. (error 0x4)
NvPclStateControllerClose: Module imx390_bottomleft closed
NvPclOpen: PCL Open Failed. Error: 0xf
NvPclClose: ++++++++++++++++++++++
NvPclClose: ----------------------
NvPclOpen: ----------------------
SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 725)
SCF: Error BadParameter:  (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 455)
SCF: Error BadParameter:  (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 382)
SCF: Error BadParameter:  (propagating from src/api/CameraDriver.cpp, function getSource(), line 554)
Hi Shane,
We change to R35.4.1 the driver code and nvarguscamera open success. but R36.4.3 still failed.
Hi Shane,
I remove all video node, just keep only one video node /dev/video0, still can not use nvarguscamera to open.
But we use v4l2 still works fine. What changes on R36.4.3 ? Any patch need for nvarguscamera ?
nvidia@ubuntu:~$ v4l2-ctl  -V --set-fmt-video width=1920,height=1080,pixelformat=RG12 --set-ctrl bypass_mode=0 --stream-mmap -d /dev/video0
Format Video Capture:
	Width/Height      : 1920/1080
	Pixel Format      : 'RG12' (12-bit Bayer RGRG/GBGB)
	Field             : None
	Bytes per Line    : 3840
	Size Image        : 4147200
	Colorspace        : sRGB
	Transfer Function : Default (maps to sRGB)
	YCbCr/HSV Encoding: Default (maps to ITU-R 601)
	Quantization      : Default (maps to Full Range)
	Flags             :
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 30.00 fps
Pipeline is live and does not need PREROLL ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 0.000000, max 30.000000; Exposure Range min 59000, max 33333000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 0
   Output Stream W = 1920 H = 1080
   seconds to Run    = 0
   Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadExecute:734 NvBufSurfaceFromFd Failed.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:245 (propagating)
Redistribute latency...
WARNING: from element /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0: Pipeline construction is invalid, please add queues.
Additional debug info:
../libs/gst/base/gstbasesink.c(1249): gst_base_sink_query_latency (): /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0:
Not enough buffering available for  the processing deadline of 0:00:00.015000000, add enough queues to buffer  0:00:00.015000000 additional data. Shortening processing latency to 0:00:00.000000000.
Got EOS from element "pipeline0".
EOS received - stopping pipeline...
Execution ended after 0:00:04.028938785
Setting pipeline to NULL ...
GST_ARGUS: Cleaning up
GST_ARGUS: Done Success
Freeing pipeline ...
apply:-----------------------
NvPclSettingsApply: Reading PCL settings
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 0, capture sequence ID = 0 draining session frameStart events 3
 (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 529)
SCF: Error InvalidState: Sensor 0 already in same state
 (in src/services/capture/CaptureServiceDeviceSensor.cpp, function setErrorState(), line 100)
SCF: Error InvalidState: Sensor GUID 0 is in error state. Skipping requests, capture sequence ID = 1 continue draining session frameStart events 2
 (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 543)
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 0, capture sequence ID = 0 draining session frameEnd events 3
 (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 646)
SCF: Error InvalidState: Sensor GUID 0 is in error state. Skipping requests, capture sequence ID = 2 continue draining session frameStart events 1
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 0, capture sequence ID = 1 draining session frameEnd events 2
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 0, capture sequence ID = 2 draining session frameEnd events 1
SCF: Error BadParameter: CC has already been disposed (in src/components/CaptureContainerManager.cpp, function dispose(), line 161)
SCF: Error Timeout: Sending critical error event for Session 0
 (in src/api/Session.cpp, function sendErrorEvent(), line 1039)
NvPclSettingsUpdate: Sending Updated Settings through PCL
NvPclSettingsApply: Applying last settings through PCL
apply:+++++++++++++++++++++++
Keep the Group Hold CID.
Hi ShaneCCC,
We porting from R35.4.1 imx390 driver source code to R36.4.3 instead nv_imx390.c now nvargus works fine. Thanks for your support.
Another questioin is if we use 12 cameras nvargus camera list is uncorrent, we try to open /dev/video2 but actually open /dev/video10 not /dev/video2, this issue is here
https://forums.developer.nvidia.com/t/nvarguscamera-open-sensor-id-2-is-camera-10-not-camera-2-with-more-than-10-cameras-on-agx-orin/333180?u=luna2020
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module10
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module11
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module3
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module4
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module5
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module6
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module7
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module8
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module9
I think the corrent senquence should be
