Nvarguscamerasrc crashes after a few hours of working
Hi Shane,
We are hitting a similar issue. Could we can a binary for 36.5? Thank you!
Here’s the lib for r36.5
libnvfusacap.so.r36.5.dis_notify (232.0 KB)
I used it for my Yocto and now I can not even start 8 cameras. Right after I up the last two cameras I get this nvargus logs and all the streams drop:
Summary
Feb 27 10:20:36 media nvargus-daemon[1456]: SCF: Error InvalidState:  (propagating from src/services/gl/EGLStreamProducer.cpp, function returnFrame(), line 368)
Feb 27 10:20:36 media nvargus-daemon[1456]: SCF: Error InvalidState:  (propagating from src/services/gl/EGLStreamProducer.cpp, function getBuffer(), line 430)
Feb 27 10:20:36 media nvargus-daemon[1456]: SCF: Error InvalidState:  (propagating from src/components/CaptureContainerImpl.cpp, function assignAllBuffersFromStream(), line 275)
Feb 27 10:20:36 media nvargus-daemon[1456]: SCF: Error InvalidState:  (propagating from src/components/stages/CCDataSetupStage.cpp, function doHandleRequest(), line 76)
Feb 27 10:20:36 media nvargus-daemon[1456]: SCF: Error InvalidState:  (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 158)
Feb 27 10:20:36 media nvargus-daemon[1456]: SCF: Error InvalidState: Sending critical error event for Session 15
Feb 27 10:20:36 media nvargus-daemon[1456]:  (in src/api/Session.cpp, function sendErrorEvent(), line 1039)
Feb 27 10:20:36 media nvargus-daemon[1456]: SCF: Error CaptureAborted:  (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 137)
Feb 27 10:20:36 media nvargus-daemon[1456]: SCF: Error InvalidState: Sending critical error event for Session 13
Feb 27 10:20:36 media nvargus-daemon[1456]: Wrong frequency range!
Feb 27 10:20:36 media nvargus-daemon[1456]: assignAllBuffersFromStream if ii 0 stream 0xffff2801a120 and buffer (nil) 281472870945152meout 4af0000077f
Feb 27 10:20:36 media nvargus-daemon[1456]: assignAllBuffersFromStream if ii 0 stream 0xfffe6c0107f0 and buffer (nil) 281472261714304meout 4af0000077f
Feb 27 10:20:36 media nvargus-daemon[1456]: assignAllBuffersFromStream if ii 0 stream 0xfffe6c002270 and buffer (nil) 281472870945152meout 4af0000077f
Feb 27 10:20:36 media nvargus-daemon[1456]: assignAllBuffersFromStream if ii 0 stream 0xffff080013a0 and buffer (nil) 281472261714304meout 4af0000077f
Feb 27 10:20:36 media nvargus-daemon[1456]: SCF: Error InvalidState: Sending critical error event for Session 0
Feb 27 10:20:36 media nvargus-daemon[1456]: (Argus) Error FileOperationFailed: Failed socket read: Connection reset by peer (in src/rpc/socket/common/SocketUtils.cpp, function readSocket(), line 79)
Feb 27 10:20:36 media nvargus-daemon[1456]: (Argus) Error FileOperationFailed:  (propagating from libs/rpc_socket_server/ServerSocketManager.cpp, function recvThreadCore(), line 192)
Feb 27 10:20:36 media nvargus-daemon[1456]: (Argus) Error FileOperationFailed:  (propagating from libs/rpc_socket_server/ServerSocketManager.cpp, function run(), line 58)
Feb 27 10:20:36 media nvargus-daemon[1456]: === gst_pipeline_video_node[288]: Connection closed (FFFEDCF9B8E0)=== gst_pipeline_video_node[288]: WARNING: CameraProvider was not destroyed before client connection terminated.=== gst_pipeline_video_node[288]:          The client may have abnormally terminated. Destroying CameraProvider...=== gst_pipeline_video_node[288]: CameraProvider destroyed (0xfffebc00f750)=== gst_pipeline_video_node[288]: WARNING: Cleaning up 2 outstanding requests...=== gst_pipeline_video_node[288]: WARNING: Cleaning up 2 outstanding stream settings...=== gst_pipeline_video_node[288]: WARNING: Cleaning up 2 outstanding queues...=== gst_pipeline_video_node[288]: WARNING: Cleaning up 2 outstanding sessions...(Argus) Error FileOperationFailed: Failed socket read: Connection reset by peer (in src/rpc/socket/common/SocketUtils.cpp, function readSocket(), line 79)
Feb 27 10:20:36 media nvargus-daemon[1456]: assignAllBuffersFromStream if ii 0 stream 0xffff080013a0 and buffer (nil) 281472862491008meout 4af0000077f
Feb 27 10:20:36 media nvargus-daemon[1456]: assignAllBuffersFromStream if ii 0 stream 0xffff2801a120 and buffer (nil) 281472251158912meout 4af0000077f
Feb 27 10:20:36 media nvargus-daemon[1456]: SCF: Error InvalidState: Sending critical error event for Session 22
Feb 27 10:20:36 media nvargus-daemon[1456]: assignAllBuffersFromStream if ii 0 stream 0xfffe6c0107f0 and buffer (nil) 281472862491008meout 4af0000077f
Feb 27 10:20:36 media nvargus-daemon[1456]: SCF: Error InvalidState: Failed to set the metadata for the frame (propagating from src/services/gl/EGLStreamProducer.cpp, function setFrameMetadata(), line 466)
Feb 27 10:20:36 media nvargus-daemon[1456]: SCF: Error InvalidState:  (propagating from src/services/gl/EGLStreamProducer.cpp, function presentBufferInternal(), line 533)
Feb 27 10:20:36 media nvargus-daemon[1456]: SCF: Error InvalidState:  (propagating from src/services/gl/EGLStreamProducer.cpp, function presentBufferInternal(), line 535)
Feb 27 10:20:36 media nvargus-daemon[1456]: === gst_pipeline_video_node[288]: WARNING: Cleaning up 2 outstanding streams...(Argus) Error InvalidState: Unknown stream deleted. (in src/api/CaptureSessionImpl.cpp, function outputStreamDeleted(), line 1106)
Feb 27 10:20:36 media nvargus-daemon[1456]: (Argus) Error InvalidState: Unknown stream deleted. (in src/api/CaptureSessionImpl.cpp, function outputStreamDeleted(), line 1106)
Feb 27 10:20:36 media nvargus-daemon[1456]: === gst_pipeline_video_node[288]: NOTE: Destroy all libargus objects before destroying the CameraProvider to avoid these warnings.=== gst_pipeline_video_node[288]: Connection cleaned up (FFFEDCF9B8E0)=== gst_pipeline_video_node[288]: Connection closed (FFFE7B7EB8E0)=== gst_pipeline_video_node[288]: WARNING: CameraProvider was not destroyed before client connection terminated.=== gst_pipeline_video_node[288]:          The client may have abnormally terminated. Destroying CameraProvider...=== gst_pipeline_video_node[288]: CameraProvider destroyed (0xfffe558f1b80)=== gst_pipeline_video_node[288]: WARNING: Cleaning up 2 outstanding requests...=== gst_pipeline_video_node[288]: WARNING: Cleaning up 2 outstanding stream settings...=== gst_pipeline_video_node[288]: WARNING: Cleaning up 2 outstanding queues...=== gst_pipeline_video_node[288]: WARNING: Cleaning up 2 outstanding sessions...assignAllBuffersFromStream if ii 0 stream 0xffff28015890 and buffer (nil) 281472251158912meout 4af0000077f
Feb 27 10:20:36 media nvargus-daemon[1456]: assignAllBuffersFromStream if ii 0 stream 0xffff08052180 and buffer (nil) 281472981438848meout 4af0000077f
Feb 27 10:20:36 media nvargus-daemon[1456]: assignAllBuffersFromStream if ii 0 stream 0xffff080013a0 and buffer (nil) 281472989892992meout 4af0000077f
Feb 27 10:20:36 media nvargus-daemon[1456]: SCF: Error InvalidState: Sending critical error event for Session 23
Feb 27 10:20:36 media nvargus-daemon[1456]: assignAllBuffersFromStream if ii 0 stream 0xffff08052180 and buffer (nil) 281472854036864meout 4af0000077f
Feb 27 10:20:37 media nvargus-daemon[1456]: assignAllBuffersFromStream if ii 0 stream 0xffff08052180 and buffer (nil) 281472251158912meout 4af0000077f
Feb 27 10:20:37 media nvargus-daemon[1456]: assignAllBuffersFromStream if ii 0 stream 0xffff080013a0 and buffer (nil) 281472896307584meout 4af0000077f
Feb 27 10:20:37 media nvargus-daemon[1456]: === gst_pipeline_video_node[288]: WARNING: Cleaning up 2 outstanding streams...(Argus) Error InvalidState: Unknown stream deleted. (in src/api/CaptureSessionImpl.cpp, function outputStreamDeleted(), line 1106)
Feb 27 10:20:37 media nvargus-daemon[1456]: (Argus) Error InvalidState: Unknown stream deleted. (in src/api/CaptureSessionImpl.cpp, function outputStreamDeleted(), line 1106)
Feb 27 10:20:37 media nvargus-daemon[1456]: === gst_pipeline_video_node[288]: NOTE: Destroy all libargus objects before destroying the CameraProvider to avoid these warnings.=== gst_pipeline_video_node[288]: Connection cleaned up (FFFE7B7EB8E0)=== gst_pipeline_video_node[288]: Connection closed (FFFF4F7EB8E0)=== gst_pipeline_video_node[288]: WARNING: CameraProvider was not destroyed before client connection terminated.=== gst_pipeline_video_node[288]:          The client may have abnormally terminated. Destroying CameraProvider...=== gst_pipeline_video_node[288]: CameraProvider destroyed (0xfffe74000c70)=== gst_pipeline_video_node[288]: WARNING: Cleaning up 2 outstanding requests...=== gst_pipeline_video_node[288]: WARNING: Cleaning up 2 outstanding stream settings...=== gst_pipeline_video_node[288]: WARNING: Cleaning up 2 outstanding queues...=== gst_pipeline_video_node[288]: WARNING: Cleaning up 2 outstanding sessions...assignAllBuffersFromStream if ii 0 stream 0xffff08052180 and buffer (nil) 281472879399296meout 4af0000077f
Feb 27 10:20:37 media nvargus-daemon[1456]: assignAllBuffersFromStream if ii 0 stream 0xffff080013a0 and buffer (nil) 281472989892992meout 4af0000077f
Feb 27 10:20:37 media nvargus-daemon[1456]: Wrong frequency range!
Feb 27 10:20:37 media nvargus-daemon[1456]: SCF: Error InvalidState: Failed to set the metadata for the frame (propagating from src/services/gl/EGLStreamProducer.cpp, function setFrameMetadata(), line 466)
Feb 27 10:20:37 media nvargus-daemon[1456]: SCF: Error InvalidState:  (propagating from src/services/gl/EGLStreamProducer.cpp, function presentBufferInternal(), line 533)
Feb 27 10:20:37 media nvargus-daemon[1456]: SCF: Error InvalidState:  (propagating from src/services/gl/EGLStreamProducer.cpp, function presentBufferInternal(), line 535)
Feb 27 10:20:37 media nvargus-daemon[1456]: === gst_pipeline_video_node[288]: NOTE: Destroy all libargus objects before destroying the CameraProvider to avoid these warnings.=== gst_pipeline_video_node[288]: Connection cleaned up (FFFF4F7EB8E0)=== gst_pipeline_video_node[288]: Connection closed (FFFE967CB8E0)=== gst_pipeline_video_node[288]: WARNING: CameraProvider was not destroyed before client connection terminated.=== gst_pipeline_video_node[288]:          The client may have abnormally terminated. Destroying CameraProvider...=== gst_pipeline_video_node[288]: CameraProvider destroyed (0xffff48002ef0)=== gst_pipeline_video_node[288]: WARNING: Cleaning up 2 outstanding requests...=== gst_pipeline_video_node[288]: WARNING: Cleaning up 2 outstanding stream settings...=== gst_pipeline_video_node[288]: WARNING: Cleaning up 2 outstanding queues...=== gst_pipeline_video_node[288]: WARNING: Cleaning up 2 outstanding sessions...assignAllBuffersFromStream if ii 0 stream 0xffff08052180 and buffer (nil) 281472870945152meout 4af0000077f
Feb 27 10:20:37 media nvargus-daemon[1456]: assignAllBuffersFromStream if ii 0 stream 0xffff08052180 and buffer (nil) 281472981438848meout 4af0000077f
Feb 27 10:20:37 media nvargus-daemon[1456]: assignAllBuffersFromStream if ii 0 stream 0xffff08052180 and buffer (nil) 281472261714304meout 4af0000077f
Feb 27 10:20:37 media nvargus-daemon[1456]: assignAllBuffersFromStream if ii 0 stream 0xffff08052180 and buffer (nil) 281472989892992meout 4af0000077f
Feb 27 10:20:37 media nvargus-daemon[1456]: assignAllBuffersFromStream if ii 0 stream 0xffff08052180 and buffer (nil) 281472896307584meout 4af0000077f
Feb 27 10:20:37 media nvargus-daemon[1456]: assignAllBuffersFromStream if ii 0 stream 0xffff08052180 and buffer (nil) 281472879399296meout 4af0000077f
Feb 27 10:20:37 media nvargus-daemon[1456]: assignAllBuffersFromStream if ii 0 stream 0xffff08052180 and buffer (nil) 281472854036864meout 4af0000077f
Could you please help me with that
Could you start camera one by one to check launching how many cameras to failed.
Streams from cameras start to freeze right after I start first 2 ones and fully crashes when I start the last 8th one
I would suggest modify the sensor CID function as dummy function to verify if unvalidate sensor REG cause the capture failed.
