Board: AGX Orin Industrial
L4T Version: r36.4.3
I made a custom driver and custom device tree for this board, and the following command works:
env -u DISPLAY gst-launch-1.0 \
nvarguscamerasrc sensor-id=0 ispdigitalgainrange="1 1" tnr-mode=0 aeantibanding=0 ! \
"video/x-raw(memory:NVMM),width=1928,height=1208" ! fakesink
But now the following doesn’t work:
(Without `tnr-mode=0`)
nvarguscamerasrc sensor-id=0 ispdigitalgainrange="1 1" aeantibanding=0 ! \
It gives the following errors:
gst-launch-1.0 log:
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 1928 x 1208 FR = 29,999999 fps Duration = 33333334 ; Analog Gain range min 1000000,000000, max inf; Exposure Range min 1000, max 33333000;GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 1928 H = 1208
seconds to Run = 0
Frame Rate = 29,999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: CANCELLED
Additional debug info:
Argus Error Status
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadExecute:734 NvBufSurfaceFromFd Failed.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:245 (propagating)
Execution ended after 0:00:00.421240522
Setting pipeline to NULL …
GST_ARGUS: Cleaning up
(Argus) Error Timeout: (propagating from src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 137)
(Argus) Error Timeout: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 92)
Freeing pipeline …
(Argus) Error InvalidState: Argus client is exiting with 4 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 366)
serial log:
verify_rate_range: FMON_NVCSI: rate 10045312 below min 18750000
fmon_update_config: FMON_NVCSI: detected fault 0x80
Argus daemon log:
sept 18 16:45:31 orinagx nvargus-daemon[2876]: === gst-launch-1.0[2878]: CameraProvider destroyed (0xffff9cad4fa0)=== gst-launch-1.0[2878]: Connection closed (FFFFA3ACB840)=== gst-launch-1.0[2878]: Connection cleaned up (FFFFA3ACB840)=== gst-launch-1.0[2936]: Connection established (FFFFA3ACB840)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
sept 18 16:45:31 orinagx nvargus-daemon[2876]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
sept 18 16:45:31 orinagx nvargus-daemon[2876]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
sept 18 16:45:31 orinagx nvargus-daemon[2876]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module3
sept 18 16:45:31 orinagx nvargus-daemon[2876]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module4
sept 18 16:45:31 orinagx nvargus-daemon[2876]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module5
sept 18 16:45:31 orinagx nvargus-daemon[2876]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module6
sept 18 16:45:31 orinagx nvargus-daemon[2876]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module7
sept 18 16:45:31 orinagx nvargus-daemon[2876]: NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
sept 18 16:45:31 orinagx nvargus-daemon[2876]: NvPclHwGetModuleList: No module data found
sept 18 16:45:31 orinagx nvargus-daemon[2876]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
sept 18 16:45:31 orinagx nvargus-daemon[2876]: ---- imager: No override file found. ----
sept 18 16:45:31 orinagx nvargus-daemon[2876]: (NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 256)
sept 18 16:45:31 orinagx nvargus-daemon[2876]: (NvCamV4l2) Error ModuleNotPresent: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 60)
sept 18 16:45:31 orinagx nvargus-daemon[2876]: (NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 111)
sept 18 16:45:31 orinagx nvargus-daemon[2876]: NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
sept 18 16:45:31 orinagx nvargus-daemon[2876]: NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
sept 18 16:45:31 orinagx nvargus-daemon[2876]: NvPclStartPlatformDrivers: Failed to start module drivers
sept 18 16:45:31 orinagx nvargus-daemon[2876]: NvPclStateControllerOpen: Failed ImagerGUID 0. (error 0xA000E)
sept 18 16:45:31 orinagx nvargus-daemon[2876]: NvPclOpen: PCL Open Failed. Error: 0xf
sept 18 16:45:31 orinagx nvargus-daemon[2876]: SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 725)
sept 18 16:45:31 orinagx nvargus-daemon[2876]: SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 455)
sept 18 16:45:31 orinagx nvargus-daemon[2876]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 382)
sept 18 16:45:31 orinagx nvargus-daemon[2876]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 554)
sept 18 16:45:31 orinagx nvargus-daemon[2876]: NvPclStateControllerOpen: Failed ImagerGUID 1. (error 0xA000E)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: LSC: LSC surface is not based on full res!
sept 18 16:45:32 orinagx nvargus-daemon[2876]: ---- imager: No override file found. ----
sept 18 16:45:32 orinagx nvargus-daemon[2876]: (NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 256)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: (NvCamV4l2) Error ModuleNotPresent: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 60)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: (NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 111)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
sept 18 16:45:32 orinagx nvargus-daemon[2876]: NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
sept 18 16:45:32 orinagx nvargus-daemon[2876]: NvPclStartPlatformDrivers: Failed to start module drivers
sept 18 16:45:32 orinagx nvargus-daemon[2876]: NvPclStateControllerOpen: Failed ImagerGUID 3. (error 0xA000E)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: NvPclOpen: PCL Open Failed. Error: 0xf
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 725)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 455)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 382)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 554)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: NvPclStateControllerOpen: Failed ImagerGUID 4. (error 0xA000E)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: NvPclStateControllerOpen: Failed ImagerGUID 5. (error 0xA000E)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: NvPclStateControllerOpen: Failed ImagerGUID 6. (error 0xA000E)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: NvPclStateControllerOpen: Failed ImagerGUID 7. (error 0xA000E)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: === gst-launch-1.0[2936]: CameraProvider initialized (0xffff9d4b5fd0)LSC: LSC surface is not based on full res!
sept 18 16:45:32 orinagx nvargus-daemon[2876]: Module_id 23 Severity 2 : CheckNoiseReduction: Invalid gain
sept 18 16:45:32 orinagx nvargus-daemon[2876]: Module_id 23 Severity 2 : NvMediaISPSetNoiseReduction: Invalid controls for noise reduction
sept 18 16:45:32 orinagx nvargus-daemon[2876]: (NvCameraIspMergeExt) Error BadParameter: NR: error with setting control (in merge/NvCameraIspMergeExt.cpp, function mergeInputNR(), line 2001)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: (NvCameraIspMergeExt) Error BadParameter: (propagating from merge/NvCameraIspMergeExt.cpp, function update(), line 1735)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error BadParameter: (propagating from src/services/autocontrol/NvCameraIspDriver.cpp, function getIspProgram(), line 1566)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error BadParameter: (propagating from src/services/autocontrol/NvCameraIspDriver.cpp, function getIspProgram(), line 1617)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error BadParameter: (propagating from src/services/capture/DeviceRecordFusaCapture.cpp, function programIspInternal(), line 126)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error BadParameter: (propagating from src/services/capture/CaptureRecord.cpp, function programIsp(), line 461)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error BadParameter: (propagating from src/services/capture/CaptureRecord.cpp, function doMEMtoISPCapture(), line 619)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error BadParameter: (propagating from src/services/capture/CaptureRecord.cpp, function issueCapture(), line 502)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error BadParameter: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1565)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error BadParameter: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1394)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error BadParameter: (propagating from src/common/Utils.cpp, function workerThread(), line 125)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error BadParameter: Worker thread CaptureScheduler frameStart failed (in src/common/Utils.cpp, function workerThread(), line 144)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function waitForUnlock(), line 644)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error Timeout: (propagating from src/components/CaptureContainerImpl.cpp, function returnBuffer(), line 430)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error InvalidState: Capture Scheduler not running (in src/services/capture/CaptureServiceDevice.cpp, function addNewItemToSchedule(), line 1039)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error InvalidState: (propagating from src/services/capture/CaptureService.cpp, function addRequest(), line 413)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error InvalidState: (propagating from src/components/stages/MemoryToISPCaptureStage.cpp, function doHandleRequest(), line 148)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error InvalidState: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 158)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error InvalidState: Sending critical error event for Session 2
sept 18 16:45:32 orinagx nvargus-daemon[2876]: (in src/api/Session.cpp, function sendErrorEvent(), line 1039)
sept 18 16:45:32 orinagx nvargus-daemon[2876]: SCF: Error InvalidState: (propagating from src/components/stages/SensorCaptureStage.cpp, function doHandleRequest(), line 91)
sept 18 16:45:41 orinagx nvargus-daemon[2876]: SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
sept 18 16:45:41 orinagx nvargus-daemon[2876]: Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc for sensor guid 2 count 2822164592
sept 18 16:45:48 orinagx nvargus-daemon[2876]: SCF: Error InvalidState: 3 buffers still pending during EGLStreamProducer destruction (in src/services/gl/EGLStreamProducer.cpp, function freeBuffers(), line 300)
sept 18 16:45:53 orinagx nvargus-daemon[2876]: waitForIdleLocked remaining request 107
sept 18 16:45:53 orinagx nvargus-daemon[2876]: waitForIdleLocked remaining request 106
sept 18 16:45:53 orinagx nvargus-daemon[2876]: waitForIdleLocked remaining request 105
sept 18 16:45:53 orinagx nvargus-daemon[2876]: waitForIdleLocked remaining request 104
sept 18 16:45:53 orinagx nvargus-daemon[2876]: waitForIdleLocked remaining request 103
sept 18 16:45:53 orinagx nvargus-daemon[2876]: waitForIdleLocked remaining request 102
sept 18 16:45:53 orinagx nvargus-daemon[2876]: SCF: Error Timeout: waitForIdle() timed out (in src/api/Session.cpp, function waitForIdleLocked(), line 969)
Do you have any idea what could be wrong ?
Thanks !
