Porting driver from imx274 to imx334.
12bit rggb bayer, 3840X2160 30fps.
Set gain/exposure/fps functions to dummy.
Save raw image successed by
v4l2-ctl -d /dev/video0 --set-fmt-video=width=3840,height=2160,pixelformat=RG12 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=ss.raw
But if run
gst-launch-1.0 nvarguscamerasrc ! fakesink
Desktop will hang then reboot.
Dts list below
#include <dt-bindings/media/camera.h>
#include <dt-bindings/platform/t210/t210.h>
#define CAM1_PWDN TEGRA_GPIO(S, 7)
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
status = "okay";
num_csi_lanes = <4>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <12>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <750000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
modules {
module0 {
badge = "imx334_rear_imx334";
position = "rear";
status = "okay";
orientation = "0";
cam_module0_drivernode0: drivernode0 {
pcl_id = "v4l2_sensor";
devname = "imx334 6-001a";
proc-device-tree = "/proc/device-tree/host1x/i2c@546c0000/imx334_a@1a";
gpio@6000d000 {
camera-control-output-low {
gpio-hog;
output-low;
gpios = < CAM1_PWDN 0 >;
label = "cam1-pwdn";
host1x {
vi {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
imx334_vi_in0: endpoint {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&imx334_csi_out0>;
nvcsi {
num-channels = <1>;
#size-cells = <0>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
imx334_csi_in0: endpoint@0 {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&imx334_out0>;
port@1 {
reg = <1>;
imx334_csi_out0: endpoint@1 {
remote-endpoint = <&imx334_vi_in0>;
i2c@546c0000 {
clock-frequency = <200000>;
imx334_a@1a {
compatible = "nvidia,imx334";
/* I2C device address */
reg = <0x1a>;
/* V4L2 device node location */
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "3.674";
physical_h = "2.738";
clocks = <&tegra_car TEGRA210_CLK_CLK_OUT_3>;
clock-names = "clk_out_3";
clock-frequency = <24000000>;
reset-gpios = <&gpio CAM1_PWDN GPIO_ACTIVE_HIGH>;
sensor_model = "imx334";
use_sensor_mode_id = "true";
mode0 {
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "3840";
active_h = "2160";
dynamic_pixel_bit_depth = "12";
csi_pixel_bit_depth = "12";
mode_type = "bayer";
pixel_phase = "rggb";
readout_orientation = "0";
line_length = "4538";
inherent_gain = "1";
pix_clk_hz = "297000000";
gain_factor = "10000";
min_gain_val = "11250";/* 1DB*/
max_gain_val = "320000";/* 32DB*/
step_gain_val = "625";
default_gain = "11250";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "1500000";/*1.5 */
max_framerate = "30000000";/*30*/
step_framerate = "1";
default_framerate = "30000000";
exposure_factor = "1000000";
min_exp_time = "34";/* us */
max_exp_time = "358733";/* us */
step_exp_time = "1";
default_exp_time = "12000";/* us */
#default_exp_time = "12000";/* us */
embedded_metadata_height = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
imx334_out0: endpoint {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&imx334_csi_in0>;
Thanks for your help!!
