Hello everyone!
I am developing a GStreamer application that reads images from a CSI-Camera, manipulates those images and sends them to two separate branches using the tee-element.
One branch saves images to the disk using a multifilesink and the other branch sends those images to an udpsink for further delivery. Each of those branches is connected to the tee-element via a queue-element. I think I should also mention that the “save images” branch is dynamically connected to the pipeline when another part of my project requests it.
My problem is that the “save images” branch always crashes after about 100 images with the following error:
(Argus) Error BadParameter: (propagating from src/eglstream/ImageImpl.cpp, function initialize(), line 382)
(Argus) Error BadParameter: (propagating from src/eglstream/ImageImpl.cpp, function copyToNvBuffer(), line 440)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadExecute:476 IImageNativeBuffer not supported by Image.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:177 (propagating)
My google search of that error didn’t turn up anything useful.
I also tried changing the queue parameters with no effect.
My pipeline looks like this:
(The pipeline is big and I don’t know how else I could show/explain it, sorry for the spam)
# Camera capture elements
source = Gst.ElementFactory.make("nvarguscamerasrc", "nvarguscamerasrc")
capsfilter = Gst.ElementFactory.make("capsfilter", "capsfilter")
nvvidconv = Gst.ElementFactory.make("nvvidconv", "nvvidconv")
tee = Gst.ElementFactory.make("tee", "tee")
# Bin for gather-testdata module
self.testdata = Gst.Bin.new("testdata")
# Bin for streaming module
self.streaming = Gst.Bin.new("streaming")
# Streaming elements
queue1 = Gst.ElementFactory.make("queue", "queue1")
encoder = Gst.ElementFactory.make("nvv4l2h265enc", "nvv4l2h265enc")
udpsink = Gst.ElementFactory.make("udpsink", "udpsink")
# Gather-testdata elements
queue2 = Gst.ElementFactory.make("queue", "queue2")
videorate = Gst.ElementFactory.make("videorate", "videorate")
framefilter = Gst.ElementFactory.make("capsfilter", "framefilter")
jpegenc = Gst.ElementFactory.make("nvjpegenc", "nvjpegenc")
identity = Gst.ElementFactory.make("identity", "identity")
multifilesink = Gst.ElementFactory.make("multifilesink","sink")
elements = [source, capsfilter, nvvidconv, tee, self.streaming, self.testdata, queue1, encoder, udpsink, queue2, videorate, framefilter, jpegenc, identity, multifilesink]
# Configure elements
source.set_property("maxperf", True)
source.set_property("do-timestamp", True)
caps = Gst.caps_from_string("video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, framerate=(fraction)30/1, format=(string)NV12")
capsfilter.set_property("caps", caps)
nvvidconv.set_property("flip-method", 2)
queue1.set_property("flush-on-eos", True)
encoder.set_property("maxperf-enable", True)
encoder.set_property("bitrate", 1000000)
encoder.set_property("insert-sps-pps", True)
queue2.set_property("flush-on-eos", True)
caps = Gst.caps_from_string("video/x-raw(memory:NVMM), framerate=(fraction)5/1, format=(string)NV12, width=(int)1920, height=(int)1080")
framefilter.set_property("caps", caps)
identity.connect("handoff", self.on_handoff)
multifilesink.set_property("post-messages", True)
multifilesink.set_property("location", car.config.TESTDATA_LOCATION + "frame%d.jpg")
# Add elements to pipeline and bin
self.streaming.add(queue1)
self.streaming.add(encoder)
self.streaming.add(udpsink)
pad = queue1.get_static_pad("sink")
ghostpad = Gst.GhostPad.new("sink", pad)
self.streaming.add_pad(ghostpad)
self.testdata.add(queue2)
self.testdata.add(videorate)
self.testdata.add(framefilter)
self.testdata.add(jpegenc)
self.testdata.add(identity)
self.testdata.add(multifilesink)
pad = queue2.get_static_pad("sink")
self.testdata.add_pad(ghostpad)
self.pipeline.add(source)
self.pipeline.add(capsfilter)
self.pipeline.add(nvvidconv)
self.pipeline.add(tee)
self.pipeline.add(self.streaming)
# Link all elements that can be automatically linked
source.link(capsfilter)
capsfilter.link(nvvidconv)
nvvidconv.link(tee)
queue1.link(encoder)
encoder.link(udpsink)
queue2.link(videorate)
videorate.link(framefilter)
framefilter.link(jpegenc)
jpegenc.link(identity)
identity.link(multifilesink)
# Manually link the tee_pads because they are "request"-pads
tee_streaming_pad = tee.get_request_pad("src_%u")
streaming_pad = self.streaming.get_static_pad("sink")
tee_streaming_pad.link(streaming_pad)
Any help is much appreciated!
