Hi all,
In the past using JetPack 3.2.1 I was able to get the metadata from the nvbuffer using nvcamerasrc and the property enable-meta=true, for three cameras synchronized we were receiving 3 same timestamps (meta->timestamp from nvcamerasrc)
>>> Gstreamer: sensor-0 Frame #257 : Timestamp: 46262843 - Trigger: 549737122944 - Diff: 18446698360603478560
>>> Gstreamer: sensor-2 Frame #259 : Timestamp: 46262843 - Trigger: 549737122944 - Diff: 18446698360603431560
>>> Gstreamer: sensor-1 Frame #261 : Timestamp: 46262843 - Trigger: 549737122944 - Diff: 18446698360603455560
So in JetPack 3.2.1 everything is working as expected, I expect 3 same timestamps when the cameras are synchronized.
The problem is when doing the same test but in JetPack 4.4 in this case using nvarguscamerasrc (enable-meta is not longer available, it is enable by default). we are not getting 3 same timestamps when the cameras are synchronized.
This is the setup for JetPack 4.4 where we are seeing the issue:
- Same Hardware.
- Same GStreamer application (the only change is nvcamerasrc by nvarguscamerasrc).
- Same camera driver.
- JetPack 4.4 instead JetPack 3.2.1
- We have validated that the cameras are syncronized.
>>> Gstreamer:sensor-0 Frame #85 : Timestamp: 93789 - Trigger: 549706389008 - Diff: 455916640008
>>> Gstreamer: sensor-1 Frame #72 : Timestamp: 93793 - Trigger: 549706389008 - Diff: 455912659008
>>> Gstreamer:sensor-2 Frame #44 : Timestamp: 93801 - Trigger: 549706389008 - Diff: 455905319008
>>> Gstreamer:sensor-0 Frame #86 : Timestamp: 93822 - Trigger: 549706389008 - Diff: 455883467008
>>> Gstreamer: sensor-1 Frame #73 : Timestamp: 93827 - Trigger: 549706389008 - Diff: 455879282008
>>> Gstreamer:sensor-2 Frame #45 : Timestamp: 93832 - Trigger: 549706389008 - Diff: 455874303008
>>> Gstreamer:sensor-0 Frame #87 : Timestamp: 93856 - Trigger: 549706389008 - Diff: 455850061008
>>> Gstreamer: sensor-1 Frame #74 : Timestamp: 93860 - Trigger: 549706389008 - Diff: 455846164008
>>> Gstreamer:sensor-2 Frame #46 : Timestamp: 93866 - Trigger: 549706389008 - Diff: 455840272008
>>> Gstreamer:sensor-0 Frame #88 : Timestamp: 93890 - Trigger: 549706389008 - Diff: 455815645008
>>> Gstreamer: sensor-1 Frame #75 : Timestamp: 93893 - Trigger: 549706389008 - Diff: 455812869008
>>> Gstreamer:sensor-2 Frame #47 : Timestamp: 93898 - Trigger: 549706389008 - Diff: 455808021008
>>> Gstreamer:sensor-0 Frame #89 : Timestamp: 93933 - Trigger: 549706389008 - Diff: 455772801008
>>> Gstreamer:sensor-2 Frame #48 : Timestamp: 93937 - Trigger: 549706389008 - Diff: 455768815008
>>> Gstreamer: sensor-1 Frame #76 : Timestamp: 93941 - Trigger: 549706389008 - Diff: 455764970008
>>> Gstreamer:sensor-0 Frame #90 : Timestamp: 93956 - Trigger: 549706389008 - Diff: 455750130008
>>> Gstreamer: sensor-1 Frame #77 : Timestamp: 93960 - Trigger: 549706389008 - Diff: 455745948008
>>> Gstreamer:sensor-2 Frame #49 : Timestamp: 93964 - Trigger: 549706389008 - Diff: 455741460008
>>> Gstreamer:sensor-0 Frame #91 : Timestamp: 93989 - Trigger: 549706389008 - Diff: 455716922008
>>> Gstreamer: sensor-1 Frame #78 : Timestamp: 93993 - Trigger: 549706389008 - Diff: 455712625008
>>> Gstreamer:sensor-2 Frame #50 : Timestamp: 93998 - Trigger: 549706389008 - Diff: 455708068008
>>> Gstreamer:sensor-0 Frame #92 : Timestamp: 94024 - Trigger: 549706389008 - Diff: 455682255008
This is the code that we are using in the GStreamer application:
static GQuark gst_buffer_metadata_quark = 0;
typedef struct AuxBufferData {
gint64 frame_num;
gint64 timestamp;
} AuxData;
static GstPadProbeReturn
nvargus_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
AuxData *meta = NULL;
GstBuffer *buf = (GstBuffer *) info->data;
gst_buffer_metadata_quark = g_quark_from_static_string ("GstBufferMetaData");
meta = (AuxData *) gst_mini_object_get_qdata (GST_MINI_OBJECT_CAST (buf),
gst_buffer_metadata_quark);
printf(">>> Gstreamer:sensor-%d Frame #%lu : Timestamp: %lu - Trigger: %lu - Diff: %lu\n", sensor-id, meta->frame_num, meta->timestamp/1000000, trigger_ts, diff);
return GST_PAD_PROBE_OK;
Could it be related to nvarguscamerasrc element?
Thanks,
-Adrian
