Configuraiton: orin nano 8 gb, custom carrier board (forecr dual lan) with an imx477 camera.
Issue: Migrating from jetpack 5.1.1 to 6.2.1. From the command line, I can run commands fine, but the same command using gstreamer objects in cpp causes weird flipped min/max values.
On the command line running:
gst-launch-1.0 nvarguscamerasrc exposuretimerange=“13000 350000000” gainrange=“1 16” aelock=false wbmode=0 aeantibanding=1 ee-mode=0 awblock=true ! ‘video/x-raw(memory:NVMM), width=3840,height=2160,framerate=30/1’ ! nvjpegenc ! filesink location=image_test.jpg
is successful with:
GST_ARGUS: NvArgusCameraSrc: Setting Exposure Time Range : 13000 350000000
GST_ARGUS: NvArgusCameraSrc: Setting Gain Range : 1 16
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3840 x 2160 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;GST_ARGUS: 1920 x 1080 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 3840 H = 2160
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
NvMMLiteBlockCreate : Block : BlockType = 1
Redistribute latency…
^Chandling interrupt.
Interrupt: Stopping pipeline …
Execution ended after 0:00:05.594453259
Setting pipeline to NULL …
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Freeing pipeline …
But if I set up the same pipeline in cpp and set the exposure and gain with:
g_object_set(G_OBJECT(source), “exposuretimerange”, “13000 350000000”, NULL);
g_object_set(G_OBJECT(source), “gainrange”, “1 16”, NULL);
I get errors:
GST_ARGUS: Invalid min gain value, using default minimum gain: 8.000000 instead.
GST_ARGUS: Invalid max gain value, using default maximum gain: 0.000000 instead.
GST_ARGUS: Invalid min exp value, using default minimum exp: 29999998 instead.
GST_ARGUS: Invalid max exp value, using default maximum exp: 0 instead.
This code worked fine in JP 5.1.1 but is having the errors above in JP 6.2.1. I’m not quite sure why or how to debug. The error is saying it’s setting the min and max reversed as well, and the values dont match the min / max retrieved from the command line.
The output of journalctl -u nvargus-daemon gives these errors:
(Argus) Error BadParameter: Bad gain range: [1.00, 0.00] (in src/api/RequestImpl.cpp, function setGainRange(), line 694)
(Argus) Error BadParameter: Bad exposure time range: [13000, 0] (in src/api/RequestImpl.cpp, function setExposureTimeRange(), line 656)
Which would possibly suggest that the inputs from g_object_set are getting mixed up somewhere. There are no errors in journalctl when running the command from the command line.
Any advice on how to debug this issue, or where to look would be helpful.
