i am new to jetson, i want to know the what is the defualt configuration of nvcamerasrc plugin!!
it is helpfull if anyone provide me the detail of this command:
1)gst-inspect-1.0 nvcamerasrc
thank you.
nvcamerasrc is deprecated. Please refer to user guide on how to use nvarguscamerasrc.
https://developer.nvidia.com/embedded/dlc/l4t-accelerated-gstreamer-guide-32-2
Hi, DaneLLL
thanks for your reply,
can you please provide me the output of below command
1)gst-inspect-1.0 nvarguscamerasrc
thank you.
Just sharing the gst-inspect output:
nvidia@nvidia-desktop:~$ gst-inspect-1.0 nvarguscamerasrc
Factory Details:
Rank primary (256)
Long-name NvArgusCameraSrc
Klass Video/Capture
Description nVidia ARGUS Camera Source
Author Viranjan Pagar <vpagar@nvidia.com>, Amit Pandya <apandya@nvidia.com>
Plugin Details:
Name nvarguscamerasrc
Description nVidia ARGUS Source Component
Filename /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so
Version 1.0.0
License Proprietary
Source module nvarguscamerasrc
Binary package NvARGUSCameraSrc
Origin URL http://nvidia.com/
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstBaseSrc
+----GstNvArgusCameraSrc
Pad Templates:
SRC template: 'src'
Availability: Always
Capabilities:
video/x-raw(memory:NVMM)
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
format: { (string)NV12 }
framerate: [ 0/1, 120/1 ]
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
SRC: 'src'
Pad Template: 'src'
Element Properties:
name : The name of the object
flags: readable, writable
String. Default: "nvarguscamerasrc0"
parent : The parent of the object
Object of type "GstObject"
blocksize : Size in bytes to read per buffer (-1 = default)
Unsigned Integer. Range: 0 - 4294967295 Default: 4096
num-buffers : Number of buffers to output before sending EOS (-1 = unlimited)
Integer. Range: -1 - 2147483647 Default: -1
typefind : Run typefind before negotiating (deprecated, non-functional)
flags: readable, writable, deprecated
Boolean. Default: false
do-timestamp : Apply current stream time to buffers
Boolean. Default: true
silent : Produce verbose output ?
timeout : timeout to capture in seconds (Either specify timeout or num-buffers, not both)
Unsigned Integer. Range: 0 - 2147483647 Default: 0
wbmode : White balance affects the color temperature of the photo
Enum "GstNvArgusCamWBMode" Default: 1, "auto"
(0): off - GST_NVCAM_WB_MODE_OFF
(1): auto - GST_NVCAM_WB_MODE_AUTO
(2): incandescent - GST_NVCAM_WB_MODE_INCANDESCENT
(3): fluorescent - GST_NVCAM_WB_MODE_FLUORESCENT
(4): warm-fluorescent - GST_NVCAM_WB_MODE_WARM_FLUORESCENT
(5): daylight - GST_NVCAM_WB_MODE_DAYLIGHT
(6): cloudy-daylight - GST_NVCAM_WB_MODE_CLOUDY_DAYLIGHT
(7): twilight - GST_NVCAM_WB_MODE_TWILIGHT
(8): shade - GST_NVCAM_WB_MODE_SHADE
(9): manual - GST_NVCAM_WB_MODE_MANUAL
saturation : Property to adjust saturation value
Float. Range: 0 - 2 Default: 1
sensor-id : Set the id of camera sensor to use. Default 0.
Integer. Range: 0 - 255 Default: 0
exposuretimerange : Property to adjust exposure time range in nanoseconds
Use string with values of Exposure Time Range (low, high)
in that order, to set the property.
eg: exposuretimerange="34000 358733000"
String. Default: null
gainrange : Property to adjust gain range
Use string with values of Gain Time Range (low, high)
eg: gainrange="1 16"
ispdigitalgainrange : Property to adjust digital gain range
Use string with values of ISP Digital Gain Range (low, high)
eg: ispdigitalgainrange="1 8"
tnr-strength : property to adjust temporal noise reduction strength
Float. Range: -1 - 1 Default: -1
tnr-mode : property to select temporal noise reduction mode
Enum "GstNvArgusCamTNRMode" Default: 1, "NoiseReduction_Fast"
(0): NoiseReduction_Off - GST_NVCAM_NR_OFF
(1): NoiseReduction_Fast - GST_NVCAM_NR_FAST
(2): NoiseReduction_HighQuality - GST_NVCAM_NR_HIGHQUALITY
ee-mode : property to select edge enhnacement mode
Enum "GstNvArgusCamEEMode" Default: 1, "EdgeEnhancement_Fast"
(0): EdgeEnhancement_Off - GST_NVCAM_EE_OFF
(1): EdgeEnhancement_Fast - GST_NVCAM_EE_FAST
(2): EdgeEnhancement_HighQuality - GST_NVCAM_EE_HIGHQUALITY
ee-strength : property to adjust edge enhancement strength
aeantibanding : property to set the auto exposure antibanding mode
Enum "GstNvArgusCamAeAntiBandingMode" Default: 1, "AeAntibandingMode_Auto"
(0): AeAntibandingMode_Off - GST_NVCAM_AEANTIBANDING_OFF
(1): AeAntibandingMode_Auto - GST_NVCAM_AEANTIBANDING_AUTO
(2): AeAntibandingMode_50HZ - GST_NVCAM_AEANTIBANDING_50HZ
(3): AeAntibandingMode_60HZ - GST_NVCAM_AEANTIBANDING_60HZ
exposurecompensation: property to adjust exposure compensation
Float. Range: -2 - 2 Default: 0
aelock : set or unset the auto exposure lock
awblock : set or unset the auto white balance lock
maxperf : set or unset the max performace
The default values are specified in each property.
Regards,
Greivin F.
