Nvblox example with multiple Realsense camera
After checking isaac_ros_nvblox example for Realsense, the launch script only supports 1 Realsense camera. Is it possible to use multiple Realsense cameras?
Hi @forrestc1
[EDIT] You can use multiple cameras to change the parameter, but we don’t have a demo for the Realsense camera.
ROS Parameter Type Default Description
num_cameras integer 1 Number of cameras supported (number of subscribers created)
The new topics will follow this new output. The i in the subscription list can be replaced with 0-3, for example camera_0/color/image. Subscribers
ROS Topic Interface Description
camera_{i}/color/image sensor_msgs/Image Optional input color image to be integrated. Must be paired with a camera_info message below. Only used to color the mesh.
camera_{i}/color/camera_info sensor_msgs/CameraInfo Optional topic along with the color image above. Contains intrinsics of the color camera.
camera_{i}/depth/image sensor_msgs/Image The input depth image to be integrated. Must be paired with a camera_info message below. Supports both floating-point (depth in meters) and uint16 (depth in millimeters, OpenNI format).
camera_{i}/depth/camera_info sensor_msgs/CameraInfo Required topic along with the depth image. Contains intrinsic calibration parameters of the depth camera.
