Nvblox Nav2 Plugin Implementation trouble
Hello , I’m having some trouble using the nvblox nav2 plugin.I laucnh nvblox with a zed x succesfully and the static_map_slice topic is working as well, but when i launch the nav2 i get this error message:
$ ros2 launch minithor_navigation nav.launch.py
[INFO] [launch]: All log files can be found below /home/jetson/.ros/log/2025-03-11-14-16-53-937641-jetson-desktop-127684
[INFO] [launch]: Default logging verbosity is set to INFO
[INFO] [controller_server-1]: process started with pid [127774]
[INFO] [smoother_server-2]: process started with pid [127776]
[INFO] [planner_server-3]: process started with pid [127778]
[INFO] [behavior_server-4]: process started with pid [127782]
[INFO] [bt_navigator-5]: process started with pid [127784]
[INFO] [waypoint_follower-6]: process started with pid [127786]
[INFO] [velocity_smoother-7]: process started with pid [127788]
[INFO] [lifecycle_manager-8]: process started with pid [127790]
[lifecycle_manager-8] [INFO] [1741699014.748368390] [lifecycle_manager_navigation]: Creating
[waypoint_follower-6] [INFO] [1741699014.772683154] [waypoint_follower]:
[lifecycle_manager-8] [INFO] [1741699014.785800943] [lifecycle_manager_navigation]: Creating and initializing lifecycle service clients
[waypoint_follower-6] waypoint_follower lifecycle node launched.
[waypoint_follower-6] Waiting on external lifecycle transitions to activate
[waypoint_follower-6] See Managed nodes for more information.
[controller_server-1] [INFO] [1741699014.874789784] [controller_server]:
[controller_server-1] controller_server lifecycle node launched.
[controller_server-1] Waiting on external lifecycle transitions to activate
[controller_server-1] See Managed nodes for more information.
[controller_server-1] [INFO] [1741699014.908334691] [controller_server]: Creating controller server
[waypoint_follower-6] [INFO] [1741699014.920911732] [waypoint_follower]: Creating
[controller_server-1] [INFO] [1741699014.949121054] [local_costmap.local_costmap]:
[controller_server-1] local_costmap lifecycle node launched.
[controller_server-1] [INFO] [1741699014.964953085] [local_costmap.local_costmap]: Creating Costmap
[planner_server-3] [INFO] [1741699015.002656333] [planner_server]:
[planner_server-3] planner_server lifecycle node launched.
[planner_server-3] Waiting on external lifecycle transitions to activate
[planner_server-3] See Managed nodes for more information.
[planner_server-3] [INFO] [1741699015.008978342] [planner_server]: Creating
[behavior_server-4] [INFO] [1741699015.181535796] [behavior_server]:
[behavior_server-4] behavior_server lifecycle node launched.
[behavior_server-4] Waiting on external lifecycle transitions to activate
[behavior_server-4] See Managed nodes for more information.
[bt_navigator-5] [INFO] [1741699015.289244706] [bt_navigator]:
[bt_navigator-5] bt_navigator lifecycle node launched.
[bt_navigator-5] Waiting on external lifecycle transitions to activate
[bt_navigator-5] See Managed nodes for more information.
[bt_navigator-5] [INFO] [1741699015.294058294] [bt_navigator]: Creating
[smoother_server-2] [INFO] [1741699015.344325366] [smoother_server]:
[smoother_server-2] smoother_server lifecycle node launched.
[smoother_server-2] Waiting on external lifecycle transitions to activate
[smoother_server-2] See Managed nodes for more information.
[smoother_server-2] [INFO] [1741699015.356519389] [smoother_server]: Creating smoother server
[velocity_smoother-7] [INFO] [1741699015.534558960] [velocity_smoother]:
[velocity_smoother-7] velocity_smoother lifecycle node launched.
[velocity_smoother-7] Waiting on external lifecycle transitions to activate
[velocity_smoother-7] See Managed nodes for more information.
[planner_server-3] [INFO] [1741699015.586762463] [global_costmap.global_costmap]:
[planner_server-3] global_costmap lifecycle node launched.
[planner_server-3] [INFO] [1741699015.596037567] [global_costmap.global_costmap]: Creating Costmap
[lifecycle_manager-8] [INFO] [1741699016.420422342] [lifecycle_manager_navigation]: Starting managed nodes bringup…
[lifecycle_manager-8] [INFO] [1741699016.420577193] [lifecycle_manager_navigation]: Configuring controller_server
[controller_server-1] [INFO] [1741699016.421617411] [controller_server]: Configuring controller interface
[controller_server-1] [INFO] [1741699016.421929002] [controller_server]: getting goal checker plugins…
[controller_server-1] [INFO] [1741699016.422047789] [controller_server]: Controller frequency set to 20.0000Hz
[controller_server-1] [INFO] [1741699016.422120655] [local_costmap.local_costmap]: Configuring
[controller_server-1] [INFO] [1741699016.448433515] [local_costmap.local_costmap]: Using plugin “static_layer”
[controller_server-1] [INFO] [1741699016.497321066] [local_costmap.local_costmap]: Subscribing to the map topic (/map) with transient local durability
[controller_server-1] [INFO] [1741699016.506026205] [local_costmap.local_costmap]: Initialized plugin “static_layer”
[controller_server-1] [INFO] [1741699016.506105694] [local_costmap.local_costmap]: Using plugin “obstacle_layer”
[controller_server-1] [INFO] [1741699016.515900747] [local_costmap.local_costmap]: Subscribed to Topics:
[controller_server-1] [INFO] [1741699016.516098960] [local_costmap.local_costmap]: Initialized plugin “obstacle_layer”
[controller_server-1] [INFO] [1741699016.516132049] [local_costmap.local_costmap]: Using plugin “inflation_layer”
[controller_server-1] [INFO] [1741699016.519070264] [local_costmap.local_costmap]: Initialized plugin “inflation_layer”
[controller_server-1] [INFO] [1741699016.595818841] [controller_server]: Created progress_checker : progress_checker of type nav2_controller::SimpleProgressChecker
[controller_server-1] [INFO] [1741699016.598721023] [controller_server]: Created goal checker : general_goal_checker of type nav2_controller::SimpleGoalChecker
[controller_server-1] [INFO] [1741699016.599615924] [controller_server]: Controller Server has general_goal_checker goal checkers available.
[controller_server-1] [INFO] [1741699016.613820972] [controller_server]: Created controller : FollowPath of type dwb_core::DWBLocalPlanner
[controller_server-1] [INFO] [1741699016.617915567] [controller_server]: Setting transform_tolerance to 0.200000
[controller_server-1] [INFO] [1741699016.668199440] [controller_server]: Using critic “RotateToGoal” (dwb_critics::RotateToGoalCritic)
[controller_server-1] [INFO] [1741699016.668918657] [controller_server]: Critic plugin initialized
[controller_server-1] [INFO] [1741699016.669084197] [controller_server]: Using critic “Oscillation” (dwb_critics::OscillationCritic)
[controller_server-1] [INFO] [1741699016.669464974] [controller_server]: Critic plugin initialized
[controller_server-1] [INFO] [1741699016.669580369] [controller_server]: Using critic “BaseObstacle” (dwb_critics::BaseObstacleCritic)
[controller_server-1] [INFO] [1741699016.669765845] [controller_server]: Critic plugin initialized
[controller_server-1] [INFO] [1741699016.669884984] [controller_server]: Using critic “GoalAlign” (dwb_critics::GoalAlignCritic)
[controller_server-1] [INFO] [1741699016.670206464] [controller_server]: Critic plugin initialized
[controller_server-1] [INFO] [1741699016.670308323] [controller_server]: Using critic “PathAlign” (dwb_critics::PathAlignCritic)
[controller_server-1] [INFO] [1741699016.670536232] [controller_server]: Critic plugin initialized
[controller_server-1] [INFO] [1741699016.670629098] [controller_server]: Using critic “PathDist” (dwb_critics::PathDistCritic)
[controller_server-1] [INFO] [1741699016.670885873] [controller_server]: Critic plugin initialized
[controller_server-1] [INFO] [1741699016.671056149] [controller_server]: Using critic “GoalDist” (dwb_critics::GoalDistCritic)
[controller_server-1] [INFO] [1741699016.671360860] [controller_server]: Critic plugin initialized
[controller_server-1] [INFO] [1741699016.671398717] [controller_server]: Controller Server has FollowPath controllers available.
[lifecycle_manager-8] [INFO] [1741699016.699630856] [lifecycle_manager_navigation]: Configuring smoother_server
[smoother_server-2] [INFO] [1741699016.700112884] [smoother_server]: Configuring smoother server
[smoother_server-2] [INFO] [1741699016.746151789] [smoother_server]: Created smoother : simple_smoother of type nav2_smoother::SimpleSmoother
[smoother_server-2] [INFO] [1741699016.751713748] [smoother_server]: Smoother Server has simple_smoother smoothers available.
[lifecycle_manager-8] [INFO] [1741699016.787719611] [lifecycle_manager_navigation]: Configuring planner_server
[planner_server-3] [INFO] [1741699016.789667434] [planner_server]: Configuring
[planner_server-3] [INFO] [1741699016.789774892] [global_costmap.global_costmap]: Configuring
[planner_server-3] [INFO] [1741699016.814173243] [global_costmap.global_costmap]: Using plugin “static_layer”
[planner_server-3] [INFO] [1741699016.829005889] [global_costmap.global_costmap]: Subscribing to the map topic (/map) with transient local durability
[planner_server-3] [INFO] [1741699016.835696419] [global_costmap.global_costmap]: Initialized plugin “static_layer”
[planner_server-3] [INFO] [1741699016.835833447] [global_costmap.global_costmap]: Using plugin “obstacle_layer”
[planner_server-3] [INFO] [1741699016.846285955] [global_costmap.global_costmap]: Subscribed to Topics:
[planner_server-3] [INFO] [1741699016.846567274] [global_costmap.global_costmap]: Initialized plugin “obstacle_layer”
[planner_server-3] [INFO] [1741699016.846652492] [global_costmap.global_costmap]: Using plugin “inflation_layer”
[planner_server-3] [INFO] [1741699016.853059847] [global_costmap.global_costmap]: Initialized plugin “inflation_layer”
[planner_server-3] [INFO] [1741699016.927609907] [planner_server]: Created global planner plugin GridBased of type nav2_navfn_planner/NavfnPlanner
[planner_server-3] [INFO] [1741699016.928735438] [planner_server]: Configuring plugin GridBased of type NavfnPlanner
[planner_server-3] [INFO] [1741699016.933051766] [planner_server]: Planner Server has GridBased planners available.
[lifecycle_manager-8] [INFO] [1741699016.984883228] [lifecycle_manager_navigation]: Configuring behavior_server
[behavior_server-4] [INFO] [1741699016.986981583] [behavior_server]: Configuring
[behavior_server-4] [INFO] [1741699017.026365480] [behavior_server]: Creating behavior plugin spin of type nav2_behaviors/Spin
[behavior_server-4] [INFO] [1741699017.033753626] [behavior_server]: Configuring spin
[behavior_server-4] [INFO] [1741699017.092640107] [behavior_server]: Creating behavior plugin backup of type nav2_behaviors/BackUp
[behavior_server-4] [INFO] [1741699017.098525401] [behavior_server]: Configuring backup
[behavior_server-4] [INFO] [1741699017.158026585] [behavior_server]: Creating behavior plugin drive_on_heading of type nav2_behaviors/DriveOnHeading
[behavior_server-4] [INFO] [1741699017.164512245] [behavior_server]: Configuring drive_on_heading
[behavior_server-4] [INFO] [1741699017.229462457] [behavior_server]: Creating behavior plugin assisted_teleop of type nav2_behaviors/AssistedTeleop
[behavior_server-4] [INFO] [1741699017.251821845] [behavior_server]: Configuring assisted_teleop
[behavior_server-4] [INFO] [1741699017.308263307] [behavior_server]: Creating behavior plugin wait of type nav2_behaviors/Wait
[behavior_server-4] [INFO] [1741699017.314282556] [behavior_server]: Configuring wait
[lifecycle_manager-8] [INFO] [1741699017.353045446] [lifecycle_manager_navigation]: Configuring bt_navigator
[bt_navigator-5] [INFO] [1741699017.353855354] [bt_navigator]: Configuring
[lifecycle_manager-8] [INFO] [1741699017.856676189] [lifecycle_manager_navigation]: Configuring waypoint_follower
[waypoint_follower-6] [INFO] [1741699017.858775056] [waypoint_follower]: Configuring
[waypoint_follower-6] [INFO] [1741699017.949669862] [waypoint_follower]: Created waypoint_task_executor : wait_at_waypoint of type nav2_waypoint_follower::WaitAtWaypoint
[lifecycle_manager-8] [INFO] [1741699017.956455850] [lifecycle_manager_navigation]: Configuring velocity_smoother
[velocity_smoother-7] [INFO] [1741699017.957447586] [velocity_smoother]: Configuring velocity smoother
[lifecycle_manager-8] [INFO] [1741699017.970421340] [lifecycle_manager_navigation]: Activating controller_server
[controller_server-1] [INFO] [1741699017.970879975] [controller_server]: Activating
[controller_server-1] [INFO] [1741699017.970967401] [local_costmap.local_costmap]: Activating
[controller_server-1] [INFO] [1741699017.970996586] [local_costmap.local_costmap]: Checking transform
[controller_server-1] [INFO] [1741699017.971167822] [local_costmap.local_costmap]: start
[controller_server-1] [WARN] [1741699018.171644608] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[controller_server-1] [INFO] [1741699018.221409267] [controller_server]: Creating bond (controller_server) to lifecycle manager.
[lifecycle_manager-8] [INFO] [1741699018.342103707] [lifecycle_manager_navigation]: Server controller_server connected with bond.
[lifecycle_manager-8] [INFO] [1741699018.342227614] [lifecycle_manager_navigation]: Activating smoother_server
[smoother_server-2] [INFO] [1741699018.342819852] [smoother_server]: Activating
[smoother_server-2] [INFO] [1741699018.342893838] [smoother_server]: Creating bond (smoother_server) to lifecycle manager.
[controller_server-1] [WARN] [1741699018.371304573] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[lifecycle_manager-8] [INFO] [1741699018.457619237] [lifecycle_manager_navigation]: Server smoother_server connected with bond.
[lifecycle_manager-8] [INFO] [1741699018.457731720] [lifecycle_manager_navigation]: Activating planner_server
[planner_server-3] [INFO] [1741699018.458387736] [planner_server]: Activating
[planner_server-3] [INFO] [1741699018.458487706] [global_costmap.global_costmap]: Activating
[planner_server-3] [INFO] [1741699018.458515803] [global_costmap.global_costmap]: Checking transform
[planner_server-3] [INFO] [1741699018.458729632] [global_costmap.global_costmap]: start
[planner_server-3] [WARN] [1741699018.460082369] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[planner_server-3] [INFO] [1741699018.508900222] [planner_server]: Activating plugin GridBased of type NavfnPlanner
[planner_server-3] [INFO] [1741699018.510899726] [planner_server]: Creating bond (planner_server) to lifecycle manager.
[controller_server-1] [WARN] [1741699018.571346788] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[lifecycle_manager-8] [INFO] [1741699018.629174043] [lifecycle_manager_navigation]: Server planner_server connected with bond.
[lifecycle_manager-8] [INFO] [1741699018.629267997] [lifecycle_manager_navigation]: Activating behavior_server
[behavior_server-4] [INFO] [1741699018.629905773] [behavior_server]: Activating
[behavior_server-4] [INFO] [1741699018.629983247] [behavior_server]: Activating spin
[behavior_server-4] [INFO] [1741699018.630015599] [behavior_server]: Activating backup
[behavior_server-4] [INFO] [1741699018.630036912] [behavior_server]: Activating drive_on_heading
[behavior_server-4] [INFO] [1741699018.630054128] [behavior_server]: Activating assisted_teleop
[behavior_server-4] [INFO] [1741699018.630068625] [behavior_server]: Activating wait
[behavior_server-4] [INFO] [1741699018.630090577] [behavior_server]: Creating bond (behavior_server) to lifecycle manager.
[planner_server-3] [WARN] [1741699018.660121672] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[lifecycle_manager-8] [INFO] [1741699018.741393398] [lifecycle_manager_navigation]: Server behavior_server connected with bond.
[lifecycle_manager-8] [INFO] [1741699018.741491864] [lifecycle_manager_navigation]: Activating bt_navigator
[bt_navigator-5] [INFO] [1741699018.742473456] [bt_navigator]: Activating
[controller_server-1] [WARN] [1741699018.771779125] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[planner_server-3] [WARN] [1741699018.860232816] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[controller_server-1] [WARN] [1741699018.971340656] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[bt_navigator-5] [INFO] [1741699019.046104416] [bt_navigator]: Creating bond (bt_navigator) to lifecycle manager.
[planner_server-3] [WARN] [1741699019.060028753] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[lifecycle_manager-8] [INFO] [1741699019.163624859] [lifecycle_manager_navigation]: Server bt_navigator connected with bond.
[lifecycle_manager-8] [INFO] [1741699019.163777887] [lifecycle_manager_navigation]: Activating waypoint_follower
[waypoint_follower-6] [INFO] [1741699019.164449487] [waypoint_follower]: Activating
[waypoint_follower-6] [INFO] [1741699019.164531121] [waypoint_follower]: Creating bond (waypoint_follower) to lifecycle manager.
[controller_server-1] [WARN] [1741699019.171378679] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[planner_server-3] [WARN] [1741699019.260032919] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[lifecycle_manager-8] [INFO] [1741699019.280674154] [lifecycle_manager_navigation]: Server waypoint_follower connected with bond.
[lifecycle_manager-8] [INFO] [1741699019.280801645] [lifecycle_manager_navigation]: Activating velocity_smoother
[velocity_smoother-7] [INFO] [1741699019.281844807] [velocity_smoother]: Activating
[velocity_smoother-7] [INFO] [1741699019.282341843] [velocity_smoother]: Creating bond (velocity_smoother) to lifecycle manager.
[controller_server-1] [WARN] [1741699019.371389757] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[lifecycle_manager-8] [INFO] [1741699019.408972682] [lifecycle_manager_navigation]: Server velocity_smoother connected with bond.
[lifecycle_manager-8] [INFO] [1741699019.409108045] [lifecycle_manager_navigation]: Managed nodes are active
[lifecycle_manager-8] [INFO] [1741699019.409143118] [lifecycle_manager_navigation]: Creating bond timer…
[planner_server-3] [WARN] [1741699019.460029949] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[controller_server-1] [WARN] [1741699019.571334913] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[planner_server-3] [WARN] [1741699019.659976673] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[controller_server-1] [WARN] [1741699019.771344647] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[planner_server-3] [WARN] [1741699019.860071945] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[controller_server-1] [WARN] [1741699019.971346925] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[controller_server-1] [WARN] [1741699019.971424879] [local_costmap.local_costmap]: Can’t update static costmap layer, no map received
[planner_server-3] [WARN] [1741699020.060038990] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[controller_server-1] [WARN] [1741699020.171339475] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[planner_server-3] [WARN] [1741699020.260066677] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[planner_server-3] [WARN] [1741699020.260216952] [global_costmap.global_costmap]: Can’t update static costmap layer, no map received
[controller_server-1] [WARN] [1741699020.371508412] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[planner_server-3] [WARN] [1741699020.460022169] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[controller_server-1] [WARN] [1741699020.571386751] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[planner_server-3] [WARN] [1741699020.660019839] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[controller_server-1] [WARN] [1741699020.771349252] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[planner_server-3] [WARN] [1741699020.860084070] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[controller_server-1] [WARN] [1741699020.971475917] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[planner_server-3] [WARN] [1741699021.059988810] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[controller_server-1] [WARN] [1741699021.171340079] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[planner_server-3] [WARN] [1741699021.260005264] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[controller_server-1] [WARN] [1741699021.371291795] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[planner_server-3] [WARN] [1741699021.460269596] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[controller_server-1] [WARN] [1741699021.571337210] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[planner_server-3] [WARN] [1741699021.660304194] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[controller_server-1] [WARN] [1741699021.771516004] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[planner_server-3] [WARN] [1741699021.860088995] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[controller_server-1] [WARN] [1741699021.971345158] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[controller_server-1] [WARN] [1741699021.971412071] [local_costmap.local_costmap]: Can’t update static costmap layer, no map received
[planner_server-3] [WARN] [1741699022.060045831] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[controller_server-1] [WARN] [1741699022.171427085] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[planner_server-3] [WARN] [1741699022.259958219] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[planner_server-3] [WARN] [1741699022.260023276] [global_costmap.global_costmap]: Can’t update static costmap layer, no map received
[controller_server-1] [WARN] [1741699022.371333648] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[planner_server-3] [WARN] [1741699022.460068595] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[controller_server-1] [WARN] [1741699022.571346230] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
[planner_server-3] [WARN] [1741699022.660041208] [nav2_costmap_2d]: Robot is out of bounds of the costmap!
I am launching navigation.launch.py with this params file , i tried to implement the plugins like it is in nova carter navigation package but i cant seem to get it to work, I once had nvblox with nav working but that was back on isaac ros 2 and also in a different rig .
The params file (to be sure pasting the whole of it):
amcl:
ros__parameters:
use_sim_time: False
alpha1: 0.2
alpha2: 0.2
alpha3: 0.2
alpha4: 0.2
alpha5: 0.2
base_frame_id: “base_footprint”
beam_skip_distance: 0.5
beam_skip_error_threshold: 0.9
beam_skip_threshold: 0.3
do_beamskip: false
global_frame_id: “map”
lambda_short: 0.1
laser_likelihood_max_dist: 2.0
laser_max_range: 100.0
laser_min_range: -1.0
laser_model_type: “likelihood_field”
max_beams: 60
max_particles: 2000
min_particles: 500
odom_frame_id: “odom”
pf_err: 0.05
pf_z: 0.99
recovery_alpha_fast: 0.0
recovery_alpha_slow: 0.0
resample_interval: 1
robot_model_type: “nav2_amcl::DifferentialMotionModel”
save_pose_rate: 0.5
sigma_hit: 0.2
tf_broadcast: true
transform_tolerance: 1.0
update_min_a: 0.2
update_min_d: 0.25
z_hit: 0.5
z_max: 0.05
z_rand: 0.5
z_short: 0.05
scan_topic: scan
bt_navigator:
ros__parameters:
use_sim_time: False
global_frame: map
robot_base_frame: base_link
odom_topic: /odom
bt_loop_duration: 10
default_server_timeout: 20
wait_for_service_timeout: 1000
# ‘default_nav_through_poses_bt_xml’ and ‘default_nav_to_pose_bt_xml’ are use defaults:
# nav2_bt_navigator/navigate_to_pose_w_replanning_and_recovery.xml
# nav2_bt_navigator/navigate_through_poses_w_replanning_and_recovery.xml
# They can be set here or via a RewrittenYaml remap from a parent launch file to Nav2.
plugin_lib_names:
- nav2_compute_path_to_pose_action_bt_node
- nav2_compute_path_through_poses_action_bt_node
- nav2_smooth_path_action_bt_node
- nav2_follow_path_action_bt_node
- nav2_spin_action_bt_node
- nav2_wait_action_bt_node
- nav2_assisted_teleop_action_bt_node
- nav2_back_up_action_bt_node
- nav2_drive_on_heading_bt_node
- nav2_clear_costmap_service_bt_node
- nav2_is_stuck_condition_bt_node
- nav2_goal_reached_condition_bt_node
- nav2_goal_updated_condition_bt_node
- nav2_globally_updated_goal_condition_bt_node
- nav2_is_path_valid_condition_bt_node
- nav2_initial_pose_received_condition_bt_node
- nav2_reinitialize_global_localization_service_bt_node
- nav2_rate_controller_bt_node
- nav2_distance_controller_bt_node
- nav2_speed_controller_bt_node
- nav2_truncate_path_action_bt_node
- nav2_truncate_path_local_action_bt_node
- nav2_goal_updater_node_bt_node
- nav2_recovery_node_bt_node
- nav2_pipeline_sequence_bt_node
- nav2_round_robin_node_bt_node
- nav2_transform_available_condition_bt_node
- nav2_time_expired_condition_bt_node
- nav2_path_expiring_timer_condition
- nav2_distance_traveled_condition_bt_node
- nav2_single_trigger_bt_node
- nav2_goal_updated_controller_bt_node
- nav2_is_battery_low_condition_bt_node
- nav2_navigate_through_poses_action_bt_node
- nav2_navigate_to_pose_action_bt_node
- nav2_remove_passed_goals_action_bt_node
- nav2_planner_selector_bt_node
- nav2_controller_selector_bt_node
- nav2_goal_checker_selector_bt_node
- nav2_controller_cancel_bt_node
- nav2_path_longer_on_approach_bt_node
- nav2_wait_cancel_bt_node
- nav2_spin_cancel_bt_node
- nav2_back_up_cancel_bt_node
- nav2_assisted_teleop_cancel_bt_node
- nav2_drive_on_heading_cancel_bt_node
- nav2_is_battery_charging_condition_bt_node
bt_navigator_navigate_through_poses_rclcpp_node:
ros__parameters:
use_sim_time: False
bt_navigator_navigate_to_pose_rclcpp_node:
ros__parameters:
use_sim_time: False
controller_server:
ros__parameters:
use_sim_time: False
controller_frequency: 20.0
min_x_velocity_threshold: 0.001
min_y_velocity_threshold: 0.5
min_theta_velocity_threshold: 0.001
failure_tolerance: 0.3
progress_checker_plugin: “progress_checker”
goal_checker_plugins: [“general_goal_checker”] # “precise_goal_checker”
controller_plugins: [“FollowPath”]
# Progress checker parameters
progress_checker:
  plugin: "nav2_controller::SimpleProgressChecker"
  required_movement_radius: 0.5
  movement_time_allowance: 10.0
# Goal checker parameters
#precise_goal_checker:
#  plugin: "nav2_controller::SimpleGoalChecker"
#  xy_goal_tolerance: 0.25
#  yaw_goal_tolerance: 0.25
#  stateful: True
general_goal_checker:
  stateful: True
# DWB parameters
FollowPath:
  plugin: "dwb_core::DWBLocalPlanner"
  debug_trajectory_details: True
  min_vel_x: 0.0
  min_vel_y: 0.0
  max_vel_x: 0.26
  max_vel_y: 0.0
  max_vel_theta: 1.0
  min_speed_xy: 0.0
  max_speed_xy: 0.26
  min_speed_theta: 0.0
  acc_lim_x: 2.5
  acc_lim_y: 0.0
  acc_lim_theta: 3.2
  decel_lim_x: -2.5
  decel_lim_y: 0.0
  decel_lim_theta: -3.2
  vx_samples: 20
  vy_samples: 5
  vtheta_samples: 20
  sim_time: 1.7
  linear_granularity: 0.05
  angular_granularity: 0.025
  transform_tolerance: 0.2
  trans_stopped_velocity: 0.25
  short_circuit_trajectory_evaluation: True
  stateful: True
  critics: ["RotateToGoal", "Oscillation", "BaseObstacle", "GoalAlign", "PathAlign", "PathDist", "GoalDist"]
  BaseObstacle.scale: 0.02
  PathAlign.scale: 32.0
  PathAlign.forward_point_distance: 0.1
  GoalAlign.scale: 24.0
  GoalAlign.forward_point_distance: 0.1
  PathDist.scale: 32.0
  GoalDist.scale: 24.0
  RotateToGoal.scale: 32.0
  RotateToGoal.slowing_factor: 5.0
  RotateToGoal.lookahead_time: -1.0
local_costmap:
  local_costmap:
    ros__parameters:
      update_frequency: 5.0
      publish_frequency: 2.0
      global_frame: odom
      use_sim_time: False
      rolling_window: true
      width: 5
      height: 5
      resolution: 0.05
      robot_radius: 0.27
      always_send_full_costmap: True
      plugins: ["nvblox_layer", "inflation_layer"]
      nvblox_layer:
        plugin: "nvblox::nav2::NvbloxCostmapLayer"
        enabled: True
        nav2_costmap_global_frame: odom
        nvblox_map_slice_topic: "/nvblox_node/static_map_slice"
        convert_to_binary_costmap: True
      inflation_layer:
        plugin: "nav2_costmap_2d::InflationLayer"
        enabled: True
        cost_scaling_factor: 3.0
        inflation_radius: 0.35
global_costmap:
  global_costmap:
    ros__parameters:
      update_frequency: 1.0
      publish_frequency: 1.0
      global_frame: map
      use_sim_time: False
      robot_radius: 0.27
      resolution: 0.05
      width: 50
      height: 50
      origin_x: -25.0
      origin_y: -25.0
      track_unknown_space: False
      mark_threshold: 2
      static_map_layer:
        plugin: "nav2_costmap_2d::StaticLayer"
        map_subscribe_transient_local: True
        enabled: true
      nvblox_layer:
        enabled: True
        nav2_costmap_global_frame: map
      inflation_layer:
        enabled: True
        cost_scaling_factor: 10.0
        inflation_radius: 0.4
map_server:
ros__parameters:
use_sim_time: False
yaml_filename: “”
map_saver:
ros__parameters:
use_sim_time: False
save_map_timeout: 5.0
free_thresh_default: 0.25
occupied_thresh_default: 0.65
planner_server:
ros__parameters:
expected_planner_frequency: 20.0
use_sim_time: False
planner_plugins: [“GridBased”]
GridBased:
plugin: “nav2_navfn_planner/NavfnPlanner”
tolerance: 0.5
use_astar: false
allow_unknown: true
smoother_server:
ros__parameters:
use_sim_time: False
smoother_plugins: [“simple_smoother”]
simple_smoother:
plugin: “nav2_smoother::SimpleSmoother”
tolerance: 1.0e-10
max_its: 1000
do_refinement: True
behavior_server:
ros__parameters:
costmap_topic: local_costmap/costmap_raw
footprint_topic: local_costmap/published_footprint
cycle_frequency: 10.0
behavior_plugins: [“spin”, “backup”, “drive_on_heading”, “assisted_teleop”, “wait”]
spin:
plugin: “nav2_behaviors/Spin”
backup:
plugin: “nav2_behaviors/BackUp”
drive_on_heading:
plugin: “nav2_behaviors/DriveOnHeading”
wait:
plugin: “nav2_behaviors/Wait”
assisted_teleop:
plugin: “nav2_behaviors/AssistedTeleop”
global_frame: odom
transform_tolerance: 0.1
use_sim_time: False
simulate_ahead_time: 2.0
max_rotational_vel: 1.0
min_rotational_vel: 0.4
rotational_acc_lim: 3.2
robot_state_publisher:
ros__parameters:
use_sim_time: False
waypoint_follower:
ros__parameters:
use_sim_time: False
loop_rate: 20
stop_on_failure: false
waypoint_task_executor_plugin: “wait_at_waypoint”
wait_at_waypoint:
plugin: “nav2_waypoint_follower::WaitAtWaypoint”
enabled: True
waypoint_pause_duration: 200
velocity_smoother:
ros__parameters:
use_sim_time: False
smoothing_frequency: 20.0
scale_velocities: False
feedback: “OPEN_LOOP”
max_velocity: [0.3, 0.0, 1.0]
min_velocity: [-0.3, 0.0, -1.0]
max_accel: [2.5, 0.0, 3.2]
max_decel: [-2.5, 0.0, -3.2]
odom_topic: “odom”
odom_duration: 0.1
deadband_velocity: [0.0, 0.0, 0.0]
velocity_timeout: 1.0
Hi , I’ve rewritten the params file but now iam getting a different error for the plugin itself:
[planner_server-3] [WARN] [1742037114.760859294] [global_costmap.global_costmap]: [NvbloxCostmapLayer] Can’t transform: map to odom. Error: Lookup would require extrapolation into the future. Requested time 1742037114.760349 but the latest data is at time 1742037113.973887, when looking up transform from frame [odom] to frame [map]
[planner_server-3] [WARN] [1742037115.801467934] [global_costmap.global_costmap]: [NvbloxCostmapLayer] Can’t transform: map to odom. Error: Lookup would require extrapolation into the future. Requested time 1742037115.798905 but the latest data is at time 1742037115.374202, when looking up transform from frame [odom] to frame [map]
[planner_server-3] [WARN] [1742037116.818807244] [global_costmap.global_costmap]: [NvbloxCostmapLayer] Can’t transform: map to odom. Error: Lookup would require extrapolation into the future. Requested time 1742037116.818239 but the latest data is at time 1742037116.007385, when looking up transform from frame [odom] to frame [map]
[planner_server-3] [WARN] [1742037117.899624824] [global_costmap.global_costmap]: [NvbloxCostmapLayer] Can’t transform: map to odom. Error: Lookup would require extrapolation into the future. Requested time 1742037117.899087 but the latest data is at time 1742037117.574157, when looking up transform from frame [odom] to frame [map]
[planner_server-3] [WARN] [1742037119.028561096] [global_costmap.global_costmap]: [NvbloxCostmapLayer] Can’t transform: map to odom. Error: Lookup would require extrapolation into the future. Requested time 1742037119.027796 but the latest data is at time 1742037118.507361, when looking up transform from frame [odom] to frame [map]
[planner_server-3] [WARN] [1742037120.067473540] [global_costmap.global_costmap]: [NvbloxCostmapLayer] Can’t transform: map to odom. Error: Lookup would require extrapolation into the future. Requested time 1742037120.064359 but the latest data is at time 1742037119.640825, when looking up transform from frame [odom] to frame [map]
[planner_server-3] [WARN] [1742037121.150395266] [global_costmap.global_costmap]: [NvbloxCostmapLayer] Can’t transform: map to odom. Error: Lookup would require extrapolation into the future. Requested time 1742037121.149749 but the latest data is at time 1742037120.774209, when looking up transform from frame [odom] to frame [map]
[planner_server-3] [WARN] [1742037121.803072664] [global_costmap.global_costmap]: Can’t update static costmap layer, no map received
[planner_server-3] [WARN] [1742037122.217074051] [global_costmap.global_costmap]: [NvbloxCostmapLayer] Can’t transform: map to odom. Error: Lookup would require extrapolation into the future. Requested time 1742037122.215813 but the latest data is at time 1742037121.407385, when looking up transform from frame [odom] to frame [map]
[planner_server-3] [WARN] [1742037123.354410312] [global_costmap.global_costmap]: [NvbloxCostmapLayer] Can’t transform: map to odom. Error: Lookup would require extrapolation into the future. Requested time 1742037123.351961 but the latest data is at time 1742037123.106995, when looking up transform from frame [odom] to frame [map]
[planner_server-3] [WARN] [1742037124.368038318] [global_costmap.global_costmap]: [NvbloxCostmapLayer] Can’t transform: map to odom. Error: Lookup would require extrapolation into the future. Requested time 1742037124.367544 but the latest data is at time 1742037123.940599, when looking up transform from frame [odom] to frame [map]
[planner_server-3] [WARN] [1742037125.400406101] [global_costmap.global_costmap]: [NvbloxCostmapLayer] Can’t transform: map to odom. Error: Lookup would require extrapolation into the future. Requested time 1742037125.399827 but the latest data is at time 1742037124.873900, when looking up transform from frame [odom] to frame [map]
Anyone know what could be causing this ? This is the nav2 params file:
bt_navigator:
ros__parameters:
use_sim_time: False
global_frame: map
robot_base_frame: zed_camera_link
odom_topic: odom
filter_duration: 0.3
action_server_result_timeout: 900.0
navigators: [“navigate_to_pose”, “navigate_through_poses”]
navigate_to_pose:
plugin: “nav2_bt_navigator::NavigateToPoseNavigator”
navigate_through_poses:
plugin: “nav2_bt_navigator::NavigateThroughPosesNavigator”
# plugin_lib_names is used to add custom BT plugins to the executor (vector of strings).
# Built-in plugins are added automatically
# plugin_lib_names: []
error_code_name_prefixes:
  - assisted_teleop
  - backup
  - compute_path
  - dock_robot
  - drive_on_heading
  - follow_path
  - nav_thru_poses
  - nav_to_pose
  - route
  - spin
  - undock_robot
  - wait
ros__parameters:
use_sim_time: False
ros__parameters:
use_sim_time: False
controller_server:
ros__parameters:
use_sim_time: False
costmap_update_timeout: 0.30
progress_checker_plugins: [“progress_checker”]
use_realtime_priority: false
progress_checker:
#  stateful: True
  stateful: True
FollowPath:
  plugin: "nav2_mppi_controller::MPPIController"
  time_steps: 56
  model_dt: 0.05
  batch_size: 2000
  ax_max: 3.0
  ax_min: -3.0
  ay_max: 3.0
  az_max: 3.5
  vx_std: 0.2
  vy_std: 0.2
  wz_std: 0.4
  vx_max: 0.5
  vx_min: -0.35
  vy_max: 0.5
  wz_max: 1.9
  iteration_count: 1
  prune_distance: 1.7
  temperature: 0.3
  gamma: 0.015
  motion_model: "DiffDrive"
  visualize: true
  regenerate_noises: true
  TrajectoryVisualizer:
    trajectory_step: 5
    time_step: 3
  AckermannConstraints:
    min_turning_r: 0.2
  critics: [
    "ConstraintCritic", "CostCritic", "GoalCritic",
    "GoalAngleCritic", "PathAlignCritic", "PathFollowCritic",
    "PathAngleCritic", "PreferForwardCritic"]
  ConstraintCritic:
    enabled: true
    cost_power: 1
    cost_weight: 4.0
  GoalCritic:
    enabled: true
    cost_power: 1
    cost_weight: 5.0
    threshold_to_consider: 1.4
  GoalAngleCritic:
    enabled: true
    cost_power: 1
    cost_weight: 3.0
    threshold_to_consider: 0.5
  PreferForwardCritic:
    enabled: true
    cost_power: 1
    cost_weight: 5.0
  CostCritic:
    enabled: true
    cost_power: 1
    cost_weight: 3.81
    critical_cost: 300.0
    consider_footprint: true
    collision_cost: 1000000.0
    near_goal_distance: 1.0
    trajectory_point_step: 2
  PathAlignCritic:
    enabled: true
    cost_power: 1
    cost_weight: 14.0
    max_path_occupancy_ratio: 0.05
    trajectory_point_step: 4
    offset_from_furthest: 20
    use_path_orientations: false
  PathFollowCritic:
    enabled: true
    cost_power: 1
    cost_weight: 5.0
    offset_from_furthest: 5
  PathAngleCritic:
    enabled: true
    cost_power: 1
    cost_weight: 2.0
    offset_from_furthest: 4
    max_angle_to_furthest: 1.0
    mode: 0
  # TwirlingCritic:
  #   enabled: true
  #   twirling_cost_power: 1
  #   twirling_cost_weight: 10.0
local_costmap:
local_costmap:
ros__parameters:
use_sim_time: False
global_frame: odom
width: 3
height: 3
resolution: 0.05
robot_radius: 0.22
# plugins: [“voxel_layer”, “inflation_layer”]
plugins: [“nvblox_layer”, “inflation_layer”]
inflation_layer:
plugin: “nav2_costmap_2d::InflationLayer”
inflation_radius: 0.70
# voxel_layer:
# plugin: “nav2_costmap_2d::VoxelLayer”
# enabled: True
# publish_voxel_map: True
# origin_z: 0.0
# z_resolution: 0.05
# z_voxels: 16
# max_obstacle_height: 2.0
# mark_threshold: 0
# observation_sources: scan
# scan:
# # A relative topic will be appended to the parent of the local_costmap namespace.
# # For example:
# # * User chosen namespace is tb4.
# # * User chosen topic is scan.
# # * Topic will be remapped to /tb4/scan without local_costmap.
# # * Use global topic /scan if you do not wish the node namespace to apply
# topic: scan
# clearing: True
# marking: True
# data_type: “LaserScan”
# raytrace_max_range: 3.0
# raytrace_min_range: 0.0
# obstacle_max_range: 2.5
# obstacle_min_range: 0.0
nvblox_layer:
plugin: “nvblox::nav2::NvbloxCostmapLayer”
enabled: True
nvblox_map_slice_topic: “/nvblox_node/static_map_slice”
static_layer:
plugin: “nav2_costmap_2d::StaticLayer”
global_costmap:
global_costmap:
ros__parameters:
use_sim_time: False
global_frame: map
robot_radius: 0.22
resolution: 0.05
width: 50
height: 50
origin_x: -25.0
origin_y: -25.0
track_unknown_space: true
# plugins: [“static_layer”, “obstacle_layer”, “inflation_layer”]
plugins: [“static_layer”, “nvblox_layer”, “inflation_layer”]
# obstacle_layer:
# plugin: “nav2_costmap_2d::ObstacleLayer”
# enabled: True
# scan:
# # A relative topic will be appended to the parent of the global_costmap namespace.
# # For example:
# # * Topic will be remapped to /tb4/scan without global_costmap.
# topic: scan
# clearing: True
# marking: True
nvblox_layer:
enabled: true
static_layer:
inflation_layer:
The yaml_filename does not need to be specified since it going to be set by defaults in launch.
If you’d rather set it in the yaml, remove the default “map” value in the tb3_simulation_launch.py
file & provide full path to map below. If CLI map configuration or launch default is provided, that will be used.
map_server:
ros__parameters:
yaml_filename: “”
map_saver:
ros__parameters:
use_sim_time: False
planner_server:
ros__parameters:
use_sim_time: False
costmap_update_timeout: 10.0
GridBased:
tolerance: 0.5
use_astar: false
allow_unknown: true
smoother_server:
ros__parameters:
use_sim_time: False
simple_smoother:
tolerance: 1.0e-10
max_its: 1000
do_refinement: True
behavior_server:
ros__parameters:
use_sim_time: False
local_costmap_topic: local_costmap/costmap_raw
global_costmap_topic: global_costmap/costmap_raw
local_footprint_topic: local_costmap/published_footprint
global_footprint_topic: global_costmap/published_footprint
spin:
backup:
drive_on_heading:
wait:
assisted_teleop:
local_frame: odom
global_frame: map
waypoint_follower:
ros__parameters:
use_sim_time: False
loop_rate: 20
wait_at_waypoint:
enabled: True
velocity_smoother:
ros__parameters:
use_sim_time: False
max_velocity: [0.5, 0.0, 2.0]
min_velocity: [-0.5, 0.0, -2.0]
odom_topic: “odom”
odom_duration: 0.1
Hi @flavionzambi
The two errors are coming from different reasons:
Have you checked if there is a map generated from nvblox?
ros2 topic echo /map
You can also check with rqt_graph is the output from your ZED X is well connected to Nvblox
The transform between map and odom is either being published too slowly or is out of sync with the system time.
Check if your NVIDIA Jetson is overloaded when is running the ZED sdk and nvblox at the same time.
Best,
Raffaello
Hi thanks for the reply , i dont see anything on the /map topic , however the map frame is being published as shown in the attached image from tf2_tools view_frames
as for the output of rqt_graph:
As for the map i see the esdf slice and also the /static_map_slice topic And this is what i see on rviz:
I have upgraded my jetson orin nano to the 25W power model , and i was able to run nvblox and vslam prior to that so i’m not sure its overloaded given that when i closed all other apps the delay which is already less than half a second as seen here:
[planner_server-3] [WARN] [1742326957.314966263] [global_costmap.global_costmap]: [NvbloxCostmapLayer] Can’t transform: map to odom. Error: Lookup would require extrapolation into the future. Requested time 1742326957.314460 but the latest data is at time 1742326956.955714, when looking up transform from frame [odom] to frame [map]
[planner_server-3] [WARN] [1742326958.332607260] [global_costmap.global_costmap]: [NvbloxCostmapLayer] Can’t transform: map to odom. Error: Lookup would require extrapolation into the future. Requested time 1742326958.331728 but the latest data is at time 1742326958.089015, when looking up transform from frame [odom] to frame [map]
So maybe the problem is with my zed integration into nvblox? Could that be possible given iam not using Isaac Ros vslam but the zed sdk directly? I have the exact same configuration from the examples you provide for zed so im not sure.
Thanks for all the help,
Flavio
Sorry i ran the rqt without the nav2 running also providing a recording of the power mode , Ill try setting the zed sdk into the lowest setting for the biggest performance just incase also .
Here is the rqt:
and here the recording:
just incase the tf tree also :
Thank you for helping me with this,
Flavio
Your transformations are published in a so slow rate, 7HZ.
You have some performance drops in the ZED SDK. First I would suggest to validate that ZED SDK gives 30 Hz position update. There are many params for ZED SDK for its position tracking module.
Also they just updated the ZED SDK which offers a huge performance increase. I would suggest to check that. The Neural Depth mode uses so much GPU.
Also I would suggest to check out ROS2 composition, where your nodes are loaded. Better to create 1 container for all perception functions to skip DDS communication and use common memory.
Hi , I’ve updated the sdk and did some optimalization and I do get the tf now at a stable 30Hz I do still get the message that my odom to map times dont line up , so i dont see anything on the global costmap but its being published along with a functional local costmap from the nvblox plugin , so atleast that works now .
Iam sending the tf2 frames image alongside. I wont mark it as fully solved since the issues persists, however thanks for all the help so far !
frames_2025-04-03_18.21.00.pdf (16.7 KB)
I receive that error too and as I have seen many people get the same error. The message comes from:
The thing is pose is never 30 hz, it goes up and down, I assume that’s why it takes. It doesn’t create me any realizable problem while navigating or mapping.
For the global costmap:
-Do you use composition for nav2? I have the same issue that I receive local costmap but not global costmap while composition.
Any idea of about this issue @Raffaello ? I use the exact same configuration, with our without composition.
From this launch file:
without composition, everything fine, with composition no global costmap.
On the other hand, @flavionzambi, which plugins and map topic do you use for global cost map? Maybe you can run the navigation and then do a
ros2 param dumb /global_costmap/global_costmap
and share the params here, so you see what actual params are loaded while the runtime.
Thanks , I’ll try it and send it tommorow
The Param Dump:
/global_costmap/global_costmap:
ros__parameters:
/bond_disable_heartbeat_timeout: true
always_send_full_costmap: true
filters:
footprint: ‘
footprint_padding: 0.009999999776482582
global_frame: map
height: 50
inflation_layer:
cost_scaling_factor: 2.5
enabled: true
inflate_around_unknown: false
inflate_unknown: false
inflation_radius: 1.0
plugin: nav2_costmap_2d::InflationLayer
lethal_cost_threshold: 100
map_topic: /map
nvblox_layer:
convert_to_binary_costmap: true
enabled: true
inflation_distance: 0.5
max_cost_value: 252
max_obstacle_distance: 1.0
nvblox_map_slice_topic: /nvblox_node/static_map_slice
plugin: nvblox::nav2::NvbloxCostmapLayer
observation_sources: ‘’
obstacle_layer:
combination_method: 1
enabled: true
footprint_clearing_enabled: true
min_obstacle_height: 0.0
plugin: nav2_costmap_2d::ObstacleLayer
scan:
clearing: true
data_type: LaserScan
expected_update_rate: 0.0
inf_is_valid: false
marking: true
observation_persistence: 0.0
obstacle_max_range: 4.0
obstacle_min_range: 0.01
raytrace_max_range: 5.0
raytrace_min_range: 0.01
sensor_frame: ‘’
topic: /scan
origin_x: -25.0
origin_y: -25.0
plugins:
- static_layer
- nvblox_layer
- inflation_layer
- obstacle_layer
resolution: 0.03
robot_radius: 0.15
rolling_window: false
static_layer:
enabled: true
footprint_clearing_enabled: false
map_subscribe_transient_local: true
map_topic: ‘’
plugin: nav2_costmap_2d::StaticLayer
subscribe_to_updates: false
transform_tolerance: 0.0
transform_tolerance: 0.3
trinary_costmap: true
unknown_cost_value: 255
use_maximum: false
use_sim_time: false
width: 50
Was anyone able to solve this? I have the same issue on a Jetson Orin with a ZED2i camera. It doesn’t appear to be a performance problem—both CPU and GPU are around 50% utilization or less. I’m running the Nav2 stack with the NVBlox costmap layer and I’m seeing these logs:
[planner_server-4] [WARN] [1755174875.852851049] [NvbloxCostmapLayer] Can’t transform: map to odom. Error: Lookup would require extrapolation into the future. Requested time 1755174875.750694 but the latest data is at time 1755174875.719929, when looking up transform from frame [odom] to frame [map]
