I have followed the isaac_ros_nvblox quickstart to get it working and displaying live data using realsense in rviz but when I exit the container then restart, it won’t work.
I am running on a Jetson Orin NX with jetpack 6.2, using a D455f. The error I get when running
ros2 launch nvblox_example_bringup realsense_example.launch.py
is
[ERROR] [launch]: Caught exception in launch (see debug for traceback): Caught multiple exceptions when trying to load file of format [py]:
- ModuleNotFoundError: No module named 'isaac_ros_launch_utils'
- InvalidFrontendLaunchFileError: The launch file my have a syntax error, or its format is unknown
I am also sourcing install/setup.bash
after entering the container.
It may be unrelated but I have also noticed that during the colcon build command for isaac_ros_nvblox, there is an error:
ERROR setuptools_scm._file_finders.git listing git files failed - pretending there aren't any
It gives this error for nvblox_msgs, nvblox_ros_python_utils and nvblox_test.
Then once I complete the steps for installation from source for isaac_ros_nvblox it will work again until I restart the container and get the same error.
Any tips on the issue would be much appreciated.
