I am having some difficulty with what appear to be random voxel artifacts in the field of view of my depth cameras. These artifacts create single-voxel obstacles in the cost map near the robot and, when used with NAV2, cause it to randomly replan its route or prevent it from moving altogether; see the clip below. The “artifacts” are the darker voxels that keep appearing and disappearing above and away from the robot.
I suspect my test environment (nighttime, with bright artificial lights in an open space) may play a factor, but I can’t seem to find a combination of parameters that removes these artifacts. The closest thing was running nvblox in dynamic mode, but though there were fewer “artifacts” and they decayed faster, they still appeared.
I am running the realsense_example.launch.py
launch file with the default nvblox_base.yaml
parameters in release 3.2 of the isaac_ros_nvblox
package.
I am using two Realsense cameras and the program is running on an AGX Orin Developer Kit with 64GB of RAM and a 1TB NVME. With the camera setup listed below, camera0
is also being used for VSLAM.
camera1 = Realsense D455f (at the front)
camera0 = Realsense D435 (at the rear)
Can I change a set of parameters to remove these, or is something else the issue? I’d also appreciate your help understanding what could have caused it. Although my indoor testing has been minimal, I haven’t experienced anything like this indoors.
Thanks in advance.
