Important: Isaac Sim support
Note: For Isaac Sim support, the community is gradually transitioning from this forum to the Isaac Sim GitHub repository so that questions and issues can be tracked, searched, and resolved more efficiently in one place. Whenever possible, please create a GitHub Discussion or Issue there instead of starting a new forum topic.
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim · GitHub ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
6.0.0
5.1.0
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model: NVIDIA RTX 6000 (Blackwell Architecture)
- Driver Version: 580.95.05
Topic Description
Nvblox Voxel Map Freezes with FastDDS & No Data with CycloneDDS (Isaac Sim 5.1 + Isaac ROS 4.0)
Detailed Description
I am following up on my previous OOM issue with Isaac ROS Nvblox. Setting the Host RMW to cyclonedds successfully resolved the OOM crash.
However, I am now facing new connectivity and stability issues depending on the RMW configuration in the Docker container:
- When using
rmw_cyclonedds_cppin Docker:
- Even though the Host is set to CycloneDDS, I receive no data in RViz inside the container. The visualization is completely empty.
- When using
rmw_fastrtps_cppin Docker:
- The voxel map appears initially, but it updates only for a brief moment and then freezes.
- The map stops updating entirely after a few seconds.
- Additionally, the Navigation feature in the example does not function correctly (the robot does not move or path planning fails).
I suspect there is a communication mismatch or a configuration issue causing data loss or freezing.
Steps to Reproduce
Host Setup: Ubuntu 22.04, Isaac Sim 5.1.0,
export RMW_IMPLEMENTATION=rmw_cyclonedds_cpp -
Docker Setup: Isaac ROS 4.0 (Jazzy), Ubuntu 24.04
Scenario A (CycloneDDS in Docker):
export RMW_IMPLEMENTATION=rmw_cyclonedds_cppinside Docker.- Launch
isaac_sim_example.launch.py. - Result: No data in RViz.
- Scenario B (FastDDS in Docker):
export RMW_IMPLEMENTATION=rmw_fastrtps_cppinside Docker.- Launch
isaac_sim_example.launch.py. - Result: Map updates briefly, then freezes. Navigation fails.
Error Messages
(If applicable, copy and paste any error messages you received)
Screenshots or Videos
cyclonedds
fastrtps
Additional Information
What I’ve Tried
- Verified that switching Host to
cycloneddsfixed the initial OOM crash. - Tested both RMW implementations inside the Docker container.
- Attempted to enable Navigation (
navigation:=True), but it fails to execute properly in the FastDDS scenario where the map freezes.
Related Issues
https://forums.developer.nvidia.com/t/oom-error-occurs-when-enabling-navigation-in-the-nvblox-isaac-sim-example-tutorial/359527
Previous OOM issue (Self-resolved by switching Host RMW)
Additional Context
- Host: Ubuntu 22.04
- Container: Ubuntu 24.04 (ROS 2 Jazzy)
- CPU: AMD Ryzen 9 9950X 16-Core Processor
- RAM: 128 GB
- Hardware: NVIDIA RTX 6000 (Blackwell)
