Is it possible to use NVBLOX with the ZED2 camera? If I remember correctly the realsense uses a workaround to deal with the emitter, because VSLAM is running in parallel. Is this also the case with the ZED camera?
hemals
2
Yes, nvblox can run with a ZED2 camera if you can get depth images fed through. VSLAM will have no issue with ZED.
Related topics
Topic | Replies | Views | Activity | |
ZED2 + AGX Xavier + Isaac ROS + Visual Odometry / Visual SLAM | 2 | 757 | November 24, 2023 | |
Custom Isaac ROS Nvblox - Nav 2 - Realsense D455 | 0 | 58 | November 21, 2024 | |
Isaac ROS VSLAM 3.2 with ZED | 3 | 119 | February 19, 2025 | |
How to Manipulate a ZED camera from NVIDIA TX2 ? | 2 | 622 | October 18, 2021 | |
The Intel Realsense Camera remains incompatible with the v4l2_camera in the ISSAC application | 3 | 447 | November 8, 2023 | |
Is there intel realsense d457 support for vslam? | 1 | 751 | March 29, 2023 | |
ZED camera on headless TX2 failing to run all | 2 | 497 | October 18, 2021 | |
Dynamic Reconstruction and VSLAM with ZED2i | 2 | 135 | June 18, 2024 | |
NVBlox Isaac ROS 3 Stereolabs Zed X mini support | 4 | 67 | November 28, 2024 | |
SLAM Jetson and Zed stereolabs | 3 | 5960 | May 16, 2016 |
