Nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
My scenario is like this: bayer12 sensor → 96712des → jetson orin(jetpack 5.0.2)
I use v4l-ctl tool to verify driver’s functions. Based on what I know, I think it’s OK. but when I use gst-launch-1.0 to capture videos, It reports errors. details are in the attachments. Could you give me some help, It would be greatly appreciated!
sudo v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=BG12 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=200
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 30.03 fps
$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM),width=1920,height=1080,framerate=30/1,format=NV12’ ! filesink location=test.mp4 -e
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3840 x 2160 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 48.000000; Exposure Range min 110000, max 166577000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 48.000000; Exposure Range min 110000, max 166577000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 1
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
Error generated. gstnvarguscamerasrc.cpp, threadExecute:694 NvBufSurfaceFromFd Failed.
Error generated. gstnvarguscamerasrc.cpp, threadFunction:247 (propagating)
Got EOS from element “pipeline0”.
Execution ended after 0:00:04.007549600
Setting pipeline to NULL …
GST_ARGUS: Cleaning up
GST_ARGUS: Done Success
$ sudo media-ctl -p -d /dev/media0
Media controller API version 5.10.104
Media device information
driver tegra-camrtc-ca
model NVIDIA Tegra Video Input Device
serial
bus info
hw revision 0x3
driver version 5.10.104
Device topology
entity 1: 13e40000.host1x:nvcsi@15a00000- (2 pads, 2 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
pad0: Sink
← “ar0231 30-0050”:0 [ENABLED]
pad1: Source
→ “vi-output, ar0231 30-0050”:0 [ENABLED]
entity 4: ar0231 30-0050 (1 pad, 1 link)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev1
pad0: Source
[fmt:SBGGR12_1X12/1920x1080 field:none colorspace:srgb]
→ “13e40000.host1x:nvcsi@15a00000-”:0 [ENABLED]
entity 6: vi-output, ar0231 30-0050 (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
← “13e40000.host1x:nvcsi@15a00000-”:1 [ENABLED]
the attachments are as follows:
trace.log (5.1 KB)
arconfig.dts.log (13.9 KB)
Could someone give me some ideas:)
It will be greatly appreciated!
Dump the device tree to confirm the setting.
sudo dtc -I fs -O dts -o extracted_proc.dts /proc/device-tree
Hi, Shane
the device tree is like this:
extracted_proc.dts.txt (484.7 KB)
the key configure should be here:
The mode0 looks like doesn’t correct.
like the csi_pixel_bit_depth/pixel_phase
				ar0231_a@50 {
					delayed_gain = "true";
					sensor_model = "ar0231";
					clock-names = "extperiph1\0pllp_grtba";
					devnode = "video0";
					vana-supply = <0x3e>;
					clocks = <0x04 0x24 0x04 0x24>;
					mclk = "extperiph1";
					vif-supply = <0x3d>;
					reset-gpios = <0x14 0x3e 0x00>;
					compatible = "nvidia,ar0231";
					physical_h = "2.738";
					avdd-reg = "vana";
					reg = <0x50>;
					physical_w = "3.674";
					iovdd-reg = "vif";
					mode0 {
						discontinuous_clk = "yes";
						readout_orientation = [30 00];
						exposure_factor = "1000000";
						mclk_khz = "24000";
						phy_mode = "DPHY";
						default_gain = "1000000";
						dpcm_enable = "false";
						max_gain_val = "48000000";
						framerate_factor = [31 00];
						min_hdr_ratio = [31 00];
						num_lanes = [34 00];
						max_framerate = "30";
						min_gain_val = "1000000";
						pixel_phase = "uyvy";
						mode_type = "yuv";
						pix_clk_hz = "497664000";
						step_gain_val = [31 00];
						cil_settletime = [30 00];
						default_exp_time = "16657";
						active_h = "2160";
						serdes_pix_clk_hz = "700000000";
						max_exp_time = "166577";
						dynamic_pixel_bit_depth = [38 00];
						active_w = "3840";
						min_exp_time = "110";
						max_hdr_ratio = [31 00];
						vc_id = [30 00];
						min_framerate = [36 00];
						mclk_multiplier = "20.736";
						step_exp_time = [31 00];
						default_framerate = "30";
						csi_pixel_bit_depth = [38 00];
						step_framerate = [31 00];
						inherent_gain = [31 00];
						embedded_metadata_height = [30 00];
						line_length = "3840";
						gain_factor = "1000000";
Thank you for your response.@shaneCCC
Firstly I specified mode=1 when used gst-launch-1.0,so I think it has nothing to do with mode 0. Even mode 0 can be removed from the dts file. I can not understand why It has something to do with mode 0 so far. could you help me understand why:) In fact, I has tried remove mode-0 from the dts, when I removed it, the v4l2-ctl is uncorrect.
Secondly if it really has something to do with mode 0,if only modify the 2 properties(csi_pixel_bit_depth/pixel_phase)is enough?
btw: my use case is like this: Bayer sensor(12bit) ==> 96717ser ==>gmsl line ==>96712 des ==>jetson orin.
Looking forward to your reply.
Suppose that mixed format report would cause Argus confuse.
Please remove it to check.
thanks for your reply.
I haved modified mode-0 in dts like this:
 mode0 {
                                                mclk_khz = "24000";
                                                num_lanes = "4";
                                                vc_id = "0";
                                                phy_mode = "DPHY";
                                                cil_settletime = "0";
                                                active_w = "1920";
                                                active_h = "1080";
                                                mode_type = "bayer";
                                                pixel_phase = "bggr";
                                                csi_pixel_bit_depth = "12";
                                                dynamic_pixel_bit_depth = "12";
                                                readout_orientation = "0";
                                                line_length = "2200";
                                                inherent_gain = "1";
                                                mclk_multiplier = "20.736";  //depricated
                                                //pix_clk_hz = "497664000";
                                                //mclk_multiplier = "17.28";
                                                //pix_clk_hz = "414720000";
                                                pix_clk_hz = "124416000";
                                                serdes_pix_clk_hz = "400000000";
                                                step_gain_val = "1";
                                                min_hdr_ratio = "1";
                                                max_hdr_ratio = "1";
                                                framerate_factor = "1";
                                                min_framerate = "6";
                                                step_framerate = "1";
                                                default_framerate= "30";
                                                step_exp_time = "1";
                                                default_exp_time = "16657";/* us */
                                                embedded_metadata_height = "0"; //should be 0
the v4l2-ctl cmd is OK. its output is like this:
sudo v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=BG12 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100
but when gst-lauch-1.0 's output is like this:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1920,height=1080,framerate=30/1,format=NV12' ! filesink location=test.mp4 -e
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
CONSUMER: Waiting until producer is connected...
   Camera index = 0
   Camera mode  = 0
   seconds to Run    = 0
Got EOS from element "pipeline0".
Execution ended after 0:00:04.002604128
Setting pipeline to NULL ...
Then could you give me some advice on how to solve the problem, thanks!
and the dmsg log for gst-launch-1.0 cmd is like this:
[ 1366.920958] [RCE] tegra_nvcsi_stream_tpg_disable(vm0, stream=0, vc=0)
[ 1366.920962] [RCE] tegra_nvcsi_stream_tpg_disable: channel 0 is already disabled
[ 1367.018644] ar0231 30-0050: camera_set_gain: val: 1000000
[ 1367.018651] ar0231 30-0050: camera_set_exposure: val: 33000
[ 1367.018655] ar0231 30-0050: camera_set_frame_rate: val: 30
[ 1367.018954] ar0231 30-0050: camera_start_streaming: is called
[ 1367.019116] bwmgr API not supported
[ 1367.019736] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1367.023372] ar0231 30-0050: camera_set_gain: val: 1010100
[ 1367.023375] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1367.032965] [RCE] tegra_nvcsi_stream_set_config(vm0, stream=0, csi=0)
[ 1367.032970] [RCE] MIPI clock = 600000 kHz, tHS-SETTLE = 0, tCLK-SETTLE = 0
[ 1367.032973] [RCE] ===== NVCSI Stream Configuration =====
[ 1367.032976] [RCE] stream_id: PP 0, csi_port: PORT A
[ 1367.032978] [RCE] Brick: PHY 0, Mode: D-PHY
[ 1367.032981] [RCE] Partition: CIL A, LP bypass: Disabled, Lanes: 4
[ 1367.032983] [RCE] Clock information:
[ 1367.032985] [RCE] MIPI clock rate: 600.00 MHz
[ 1367.032988] [RCE] T_HS settle: 0, T_CLK settle: 0
[ 1367.032990] [RCE] ======================================
[ 1367.032993] [RCE] tegra_nvcsi_stream_open(vm0, stream=0, csi=0)
[ 1367.032995] [RCE] nvcsi_calc_ths_settle ths_settle 55
[ 1367.032998] [RCE] nvcsi_calc_ths_settle ths_settle 55
[ 1367.033000] [RCE] nvcsi_calc_ths_settle ths_settle 55
[ 1367.033003] [RCE] nvcsi_calc_tclk_settle tclk_settle 75
[ 1367.056507] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1367.056512] ar0231 30-0050: camera_set_gain: val: 1000000
[ 1367.056514] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1367.056604] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1367.056607] ar0231 30-0050: camera_set_gain: val: 1010100
[ 1367.056609] ar0231 30-0050: camera_set_group_hold: val: 0
Modify those control function like set_exposure() … to dummy function to avoid the 3A alg set incorrect value cause the problem.
Also, get the trace log.
In fact, I have commented the core code like read/write register calls in 3 methods in driver code :
1)set_gain();
2)set_exposure();
3)set_group_hold();
only left printk() to print some logs and then return 0 before operate the i2c registers.
I think it’s equivalent to the dummy functions you said.
So, how to deal with the difficulty next.
Expect your reply :) thanks!
Compare below log for v4l2-ctl if the same.
the log for v4l2-ctl is like this:
[  161.521134] [RCE] NVCSILP clock rate = 408000000 Hz.
[  161.524774] [RCE] tegra_nvcsi_stream_set_config(vm0, stream=0, csi=0)
[  161.524777] [RCE] MIPI clock = 600000 kHz, tHS-SETTLE = 0, tCLK-SETTLE = 0
[  161.524780] [RCE] ===== NVCSI Stream Configuration =====
[  161.524782] [RCE] stream_id: PP 0, csi_port: PORT A
[  161.524784] [RCE] Brick: PHY 0, Mode: D-PHY
[  161.524787] [RCE] Partition: CIL A, LP bypass: Enabled, Lanes: 4
[  161.524789] [RCE] Clock information:
[  161.524792] [RCE] MIPI clock rate: 600.00 MHz
[  161.524794] [RCE] T_HS settle: 0, T_CLK settle: 0
[  161.524796] [RCE] ======================================
[  161.524799] [RCE] tegra_nvcsi_stream_open(vm0, stream=0, csi=0)
the only difference is: " LP bypass: Enabled" for v4l2-ctl. and for gst-lauch-1.0, it’s “LP bypass: Disabled”
more supplementary:
when exec gst-launch-1.0 this time, its output is like this:
note: the controls functions like set_group(), set_gain() just print some logs, then return immediately, never operate the i2c registers. They are equivalent to dummy functions.
[ 1390.587727] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1390.587738] ar0231 30-0050: camera_set_frame_rate: val: 30
[ 1390.588057] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1390.592138] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1390.592149] ar0231 30-0050: camera_set_exposure: val: 33000
[ 1390.592151] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1390.592169] ar0231 30-0050: camera_power_on: power on
[ 1390.605626] bwmgr API not supported
[ 1390.614822] --------cntt=  2-----
[ 1390.616562] [RCE] tegra_nvcsi_stream_tpg_disable(vm0, stream=0, vc=0)
[ 1390.618427] [RCE] tegra_nvcsi_stream_tpg_disable: channel 0 is already disabled
[ 1390.728480] ar0231 30-0050: camera_set_gain: val: 1000000
[ 1390.728488] ar0231 30-0050: camera_set_exposure: val: 33000
[ 1390.728491] ar0231 30-0050: camera_set_frame_rate: val: 30
[ 1390.728791] ar0231 30-0050: camera_start_streaming: is called
[ 1390.729155] bwmgr API not supported
[ 1390.729624] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1390.733253] ar0231 30-0050: camera_set_gain: val: 1010100
[ 1390.733255] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1390.766437] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1390.766445] ar0231 30-0050: camera_set_gain: val: 1000000
[ 1390.766448] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1390.766569] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1390.766572] ar0231 30-0050: camera_set_gain: val: 1010100
[ 1390.766574] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1390.784563] [RCE] tegra_nvcsi_stream_set_config(vm0, stream=0, csi=0)
[ 1390.784567] [RCE] MIPI clock = 600000 kHz, tHS-SETTLE = 0, tCLK-SETTLE = 0
[ 1390.784569] [RCE] ===== NVCSI Stream Configuration =====
[ 1390.784570] [RCE] stream_id: PP 0, csi_port: PORT A
[ 1390.784571] [RCE] Brick: PHY 0, Mode: D-PHY
[ 1390.784572] [RCE] Partition: CIL A, LP bypass: Disabled, Lanes: 4
[ 1390.784573] [RCE] Clock information:
[ 1390.784574] [RCE] MIPI clock rate: 600.00 MHz
[ 1390.784576] [RCE] T_HS settle: 0, T_CLK settle: 0
[ 1390.784577] [RCE] ======================================
[ 1390.784578] [RCE] tegra_nvcsi_stream_open(vm0, stream=0, csi=0)
[ 1390.784579] [RCE] nvcsi_calc_ths_settle ths_settle 55
[ 1390.784581] [RCE] nvcsi_calc_ths_settle ths_settle 55
[ 1390.784582] [RCE] nvcsi_calc_ths_settle ths_settle 55
[ 1390.784583] [RCE] nvcsi_calc_tclk_settle tclk_settle 75
[ 1392.640629] bwmgr API not supported
[ 1392.779063] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1392.782695] ar0231 30-0050: camera_set_exposure: val: 32829
[ 1392.782697] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1392.812493] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1392.812501] ar0231 30-0050: camera_set_gain: val: 1000000
[ 1392.812504] ar0231 30-0050: camera_set_exposure: val: 32455
[ 1392.812506] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1392.845656] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1392.845663] ar0231 30-0050: camera_set_exposure: val: 32164
[ 1392.845665] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1392.879080] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1392.879089] ar0231 30-0050: camera_set_exposure: val: 31297
[ 1392.879091] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1393.877992] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1393.878000] ar0231 30-0050: camera_set_exposure: val: 29999
[ 1393.878003] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1393.911339] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1393.911346] ar0231 30-0050: camera_set_gain: val: 1043243
[ 1393.911349] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1430.976513] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1430.976522] ar0231 30-0050: camera_set_gain: val: 1007647
[ 1430.976524] ar0231 30-0050: camera_set_exposure: val: 19999
[ 1430.976527] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.009811] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.009819] ar0231 30-0050: camera_set_gain: val: 1472951
[ 1431.009822] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.043107] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.043115] ar0231 30-0050: camera_set_gain: val: 1444543
[ 1431.043117] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.076413] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.076422] ar0231 30-0050: camera_set_gain: val: 1423406
[ 1431.076424] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.109724] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.109732] ar0231 30-0050: camera_set_gain: val: 1407813
[ 1431.109735] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.143021] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.143030] ar0231 30-0050: camera_set_gain: val: 1396286
[ 1431.143032] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.176330] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.176338] ar0231 30-0050: camera_set_gain: val: 1375452
[ 1431.176341] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.209627] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.209636] ar0231 30-0050: camera_set_gain: val: 1351175
[ 1431.209639] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.242913] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.242922] ar0231 30-0050: camera_set_gain: val: 1326923
[ 1431.242924] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.276233] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.276241] ar0231 30-0050: camera_set_gain: val: 1304339
[ 1431.276243] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.309532] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.309541] ar0231 30-0050: camera_set_gain: val: 1284037
[ 1431.309543] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.342833] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.342842] ar0231 30-0050: camera_set_gain: val: 1266147
[ 1431.342845] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.376129] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.376136] ar0231 30-0050: camera_set_gain: val: 1248367
[ 1431.376139] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.409432] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.409440] ar0231 30-0050: camera_set_gain: val: 1174531
[ 1431.409443] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.609276] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.609284] ar0231 30-0050: camera_set_gain: val: 1134087
[ 1431.609287] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.642555] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.642563] ar0231 30-0050: camera_set_gain: val: 1104479
[ 1431.642566] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.675861] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.675869] ar0231 30-0050: camera_set_gain: val: 1082862
[ 1431.675871] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.709167] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.709176] ar0231 30-0050: camera_set_gain: val: 1066874
[ 1431.709179] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.742460] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.742469] ar0231 30-0050: camera_set_gain: val: 1055161
[ 1431.742473] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.775769] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.775776] ar0231 30-0050: camera_set_gain: val: 1046468
[ 1431.775778] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.809058] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.809066] ar0231 30-0050: camera_set_gain: val: 1030906
[ 1431.809068] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.842348] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.842355] ar0231 30-0050: camera_set_gain: val: 1012739
[ 1431.842358] ar0231 30-0050: camera_set_exposure: val: 9999
[ 1431.842360] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.875664] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.875672] ar0231 30-0050: camera_set_gain: val: 1988716
[ 1431.875675] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.908977] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.908984] ar0231 30-0050: camera_set_gain: val: 1954456
[ 1431.908987] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.942261] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.942269] ar0231 30-0050: camera_set_gain: val: 1924101
[ 1431.942272] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1431.975784] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1431.975794] ar0231 30-0050: camera_set_gain: val: 1897970
[ 1431.975798] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1432.008880] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1432.008887] ar0231 30-0050: camera_set_gain: val: 1871529
[ 1432.008889] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1432.042168] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1432.042177] ar0231 30-0050: camera_set_gain: val: 1844041
[ 1432.042179] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1432.075477] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1432.075484] ar0231 30-0050: camera_set_gain: val: 1732109
[ 1432.075486] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1436.604574] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1436.604582] ar0231 30-0050: camera_set_gain: val: 1672889
[ 1436.604585] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1436.637860] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1436.637868] ar0231 30-0050: camera_set_gain: val: 1629807
[ 1436.637871] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1436.671160] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1436.671168] ar0231 30-0050: camera_set_gain: val: 1598407
[ 1436.671171] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1436.704459] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1436.704466] ar0231 30-0050: camera_set_gain: val: 1574692
[ 1436.704469] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1436.737775] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1436.737783] ar0231 30-0050: camera_set_gain: val: 1557159
[ 1436.737785] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1436.771074] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1436.771082] ar0231 30-0050: camera_set_gain: val: 1543820
[ 1436.771085] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1436.804526] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1436.804534] ar0231 30-0050: camera_set_gain: val: 1510621
[ 1436.804537] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1436.837679] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1436.837687] ar0231 30-0050: camera_set_gain: val: 1486190
[ 1436.837689] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1436.870979] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1436.870987] ar0231 30-0050: camera_set_gain: val: 1460880
[ 1436.870990] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1436.904281] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1436.904289] ar0231 30-0050: camera_set_gain: val: 1436770
[ 1436.904291] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1436.937576] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1436.937584] ar0231 30-0050: camera_set_gain: val: 1414599
[ 1436.937586] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1436.970888] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1436.970895] ar0231 30-0050: camera_set_gain: val: 1339439
[ 1436.970898] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.170695] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.170704] ar0231 30-0050: camera_set_gain: val: 1291808
[ 1437.170706] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.203991] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.203999] ar0231 30-0050: camera_set_gain: val: 1257109
[ 1437.204002] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.237280] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.237288] ar0231 30-0050: camera_set_gain: val: 1231700
[ 1437.237290] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.270580] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.270587] ar0231 30-0050: camera_set_gain: val: 1212746
[ 1437.270590] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.303889] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.303897] ar0231 30-0050: camera_set_gain: val: 1198717
[ 1437.303899] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.337184] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.337190] ar0231 30-0050: camera_set_gain: val: 1188258
[ 1437.337192] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.370511] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.370520] ar0231 30-0050: camera_set_gain: val: 1169565
[ 1437.370523] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.403813] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.403821] ar0231 30-0050: camera_set_gain: val: 1148091
[ 1437.403824] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.437113] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.437121] ar0231 30-0050: camera_set_gain: val: 1126208
[ 1437.437123] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.470419] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.470428] ar0231 30-0050: camera_set_gain: val: 1105900
[ 1437.470430] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.503713] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.503721] ar0231 30-0050: camera_set_gain: val: 1087882
[ 1437.503723] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.537017] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.537025] ar0231 30-0050: camera_set_gain: val: 1072088
[ 1437.537028] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.570318] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.570327] ar0231 30-0050: camera_set_gain: val: 1056214
[ 1437.570329] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.603616] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.603624] ar0231 30-0050: camera_set_gain: val: 1034720
[ 1437.603627] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.636922] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.636930] ar0231 30-0050: camera_set_gain: val: 1014361
[ 1437.636933] ar0231 30-0050: camera_set_exposure: val: 9993
[ 1437.636935] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.670217] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.670224] ar0231 30-0050: camera_set_gain: val: 1000000
[ 1437.670227] ar0231 30-0050: camera_set_exposure: val: 9806
[ 1437.670229] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.703524] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.703531] ar0231 30-0050: camera_set_exposure: val: 9668
[ 1437.703534] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.736822] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.736830] ar0231 30-0050: camera_set_exposure: val: 9532
[ 1437.736833] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.770125] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.770133] ar0231 30-0050: camera_set_exposure: val: 9383
[ 1437.770135] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.803432] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.803440] ar0231 30-0050: camera_set_exposure: val: 9227
[ 1437.803443] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1437.836835] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1437.836843] ar0231 30-0050: camera_set_exposure: val: 8643
[ 1437.836846] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.003244] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.003253] ar0231 30-0050: camera_set_exposure: val: 8336
[ 1438.003255] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.036562] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.036570] ar0231 30-0050: camera_set_exposure: val: 8113
[ 1438.036573] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.069840] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.069848] ar0231 30-0050: camera_set_exposure: val: 7948
[ 1438.069851] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.103155] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.103163] ar0231 30-0050: camera_set_exposure: val: 7827
[ 1438.103165] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.136448] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.136456] ar0231 30-0050: camera_set_exposure: val: 7736
[ 1438.136458] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.169752] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.169760] ar0231 30-0050: camera_set_exposure: val: 7664
[ 1438.169763] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.203052] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.203059] ar0231 30-0050: camera_set_exposure: val: 7537
[ 1438.203062] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.236354] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.236361] ar0231 30-0050: camera_set_exposure: val: 7389
[ 1438.236363] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.269673] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.269681] ar0231 30-0050: camera_set_exposure: val: 7237
[ 1438.269685] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.302960] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.302967] ar0231 30-0050: camera_set_exposure: val: 7094
[ 1438.302969] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.336273] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.336281] ar0231 30-0050: camera_set_exposure: val: 6967
[ 1438.336284] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.369572] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.369581] ar0231 30-0050: camera_set_exposure: val: 6854
[ 1438.369585] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.402869] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.402876] ar0231 30-0050: camera_set_exposure: val: 6739
[ 1438.402878] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.436171] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.436178] ar0231 30-0050: camera_set_exposure: val: 6619
[ 1438.436181] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.469495] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.469503] ar0231 30-0050: camera_set_exposure: val: 6495
[ 1438.469506] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.502777] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.502785] ar0231 30-0050: camera_set_exposure: val: 6370
[ 1438.502788] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.536082] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.536089] ar0231 30-0050: camera_set_exposure: val: 6247
[ 1438.536092] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.569392] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.569400] ar0231 30-0050: camera_set_exposure: val: 6132
[ 1438.569404] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.602679] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.602687] ar0231 30-0050: camera_set_exposure: val: 6020
[ 1438.602690] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.635980] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.635988] ar0231 30-0050: camera_set_exposure: val: 5910
[ 1438.635991] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.669265] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.669273] ar0231 30-0050: camera_set_exposure: val: 5801
[ 1438.669275] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.702756] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.702766] ar0231 30-0050: camera_set_exposure: val: 5693
[ 1438.702771] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.736118] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.736128] ar0231 30-0050: camera_set_exposure: val: 5585
[ 1438.736133] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.769194] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.769203] ar0231 30-0050: camera_set_exposure: val: 5480
[ 1438.769205] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.802497] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.802505] ar0231 30-0050: camera_set_exposure: val: 5378
[ 1438.802509] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.835995] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.836005] ar0231 30-0050: camera_set_exposure: val: 5278
[ 1438.836010] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.869110] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.869119] ar0231 30-0050: camera_set_exposure: val: 5179
[ 1438.869122] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.902612] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.902620] ar0231 30-0050: camera_set_exposure: val: 5083
[ 1438.902622] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.935947] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.935958] ar0231 30-0050: camera_set_exposure: val: 4989
[ 1438.935963] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1438.969020] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1438.969028] ar0231 30-0050: camera_set_exposure: val: 4896
[ 1438.969031] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.002312] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.002319] ar0231 30-0050: camera_set_exposure: val: 4783
[ 1439.002321] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.035609] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.035617] ar0231 30-0050: camera_set_exposure: val: 4700
[ 1439.035619] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.068915] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.068922] ar0231 30-0050: camera_set_exposure: val: 4617
[ 1439.068925] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.102215] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.102223] ar0231 30-0050: camera_set_exposure: val: 4534
[ 1439.102225] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.135517] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.135525] ar0231 30-0050: camera_set_exposure: val: 4453
[ 1439.135527] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.168822] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.168830] ar0231 30-0050: camera_set_exposure: val: 4372
[ 1439.168832] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.202123] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.202131] ar0231 30-0050: camera_set_exposure: val: 4288
[ 1439.202133] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.235419] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.235427] ar0231 30-0050: camera_set_exposure: val: 4208
[ 1439.235429] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.268720] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.268728] ar0231 30-0050: camera_set_exposure: val: 4130
[ 1439.268730] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.302021] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.302029] ar0231 30-0050: camera_set_exposure: val: 4056
[ 1439.302032] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.335324] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.335331] ar0231 30-0050: camera_set_exposure: val: 3982
[ 1439.335333] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.368868] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.368876] ar0231 30-0050: camera_set_exposure: val: 3910
[ 1439.368879] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.401941] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.401949] ar0231 30-0050: camera_set_exposure: val: 3838
[ 1439.401951] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.435239] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.435247] ar0231 30-0050: camera_set_exposure: val: 3768
[ 1439.435250] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.468539] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.468556] ar0231 30-0050: camera_set_exposure: val: 3698
[ 1439.468559] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.501841] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.501849] ar0231 30-0050: camera_set_exposure: val: 3631
[ 1439.501852] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.535139] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.535147] ar0231 30-0050: camera_set_exposure: val: 3564
[ 1439.535149] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.568445] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.568453] ar0231 30-0050: camera_set_exposure: val: 3498
[ 1439.568455] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.601746] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.601754] ar0231 30-0050: camera_set_exposure: val: 3434
[ 1439.601758] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.635055] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.635062] ar0231 30-0050: camera_set_exposure: val: 3371
[ 1439.635064] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.668474] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.668483] ar0231 30-0050: camera_set_exposure: val: 3309
[ 1439.668486] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.701629] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.701637] ar0231 30-0050: camera_set_exposure: val: 3248
[ 1439.701640] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.734929] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.734937] ar0231 30-0050: camera_set_exposure: val: 3188
[ 1439.734940] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.768453] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.768462] ar0231 30-0050: camera_set_exposure: val: 3130
[ 1439.768465] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.801546] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.801555] ar0231 30-0050: camera_set_exposure: val: 3072
[ 1439.801558] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.834862] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.834870] ar0231 30-0050: camera_set_exposure: val: 3016
[ 1439.834873] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.868179] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.868189] ar0231 30-0050: camera_set_exposure: val: 2960
[ 1439.868192] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.901466] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.901475] ar0231 30-0050: camera_set_exposure: val: 2906
[ 1439.901479] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.934914] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.934922] ar0231 30-0050: camera_set_exposure: val: 2853
[ 1439.934925] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1439.968089] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1439.968098] ar0231 30-0050: camera_set_exposure: val: 2801
[ 1439.968102] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.001392] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.001400] ar0231 30-0050: camera_set_exposure: val: 2750
[ 1440.001403] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.034687] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.034695] ar0231 30-0050: camera_set_exposure: val: 2701
[ 1440.034698] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.068000] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.068008] ar0231 30-0050: camera_set_exposure: val: 2652
[ 1440.068011] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.101261] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.101270] ar0231 30-0050: camera_set_exposure: val: 2604
[ 1440.101273] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.134582] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.134590] ar0231 30-0050: camera_set_exposure: val: 2558
[ 1440.134593] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.167880] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.167888] ar0231 30-0050: camera_set_exposure: val: 2511
[ 1440.167891] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.201194] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.201203] ar0231 30-0050: camera_set_exposure: val: 2467
[ 1440.201207] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.234544] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.234557] ar0231 30-0050: camera_set_exposure: val: 2423
[ 1440.234562] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.267785] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.267793] ar0231 30-0050: camera_set_exposure: val: 2380
[ 1440.267795] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.301098] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.301107] ar0231 30-0050: camera_set_exposure: val: 2337
[ 1440.301110] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.334418] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.334431] ar0231 30-0050: camera_set_exposure: val: 2296
[ 1440.334438] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.367669] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.367676] ar0231 30-0050: camera_set_exposure: val: 2245
[ 1440.367679] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.400999] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.401007] ar0231 30-0050: camera_set_exposure: val: 2208
[ 1440.401010] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.434355] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.434372] ar0231 30-0050: camera_set_exposure: val: 2170
[ 1440.434382] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.467572] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.467579] ar0231 30-0050: camera_set_exposure: val: 2133
[ 1440.467582] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.501033] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.501042] ar0231 30-0050: camera_set_exposure: val: 2096
[ 1440.501045] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.534238] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.534255] ar0231 30-0050: camera_set_exposure: val: 2060
[ 1440.534266] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.567502] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.567510] ar0231 30-0050: camera_set_exposure: val: 2022
[ 1440.567513] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.600809] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.600817] ar0231 30-0050: camera_set_exposure: val: 1985
[ 1440.600820] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.634101] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.634108] ar0231 30-0050: camera_set_exposure: val: 1949
[ 1440.634111] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.667457] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.667465] ar0231 30-0050: camera_set_exposure: val: 1915
[ 1440.667467] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.700712] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.700720] ar0231 30-0050: camera_set_exposure: val: 1881
[ 1440.700722] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.733992] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.734000] ar0231 30-0050: camera_set_exposure: val: 1848
[ 1440.734002] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.767293] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.767301] ar0231 30-0050: camera_set_exposure: val: 1815
[ 1440.767304] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.800648] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.800656] ar0231 30-0050: camera_set_exposure: val: 1783
[ 1440.800658] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.833927] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.833936] ar0231 30-0050: camera_set_exposure: val: 1751
[ 1440.833938] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.867213] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.867221] ar0231 30-0050: camera_set_exposure: val: 1720
[ 1440.867224] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.900709] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.900722] ar0231 30-0050: camera_set_exposure: val: 1690
[ 1440.900729] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.933820] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.933828] ar0231 30-0050: camera_set_exposure: val: 1660
[ 1440.933831] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1440.967129] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1440.967137] ar0231 30-0050: camera_set_exposure: val: 1631
[ 1440.967140] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.000432] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.000440] ar0231 30-0050: camera_set_exposure: val: 1602
[ 1441.000442] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.033788] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.033801] ar0231 30-0050: camera_set_exposure: val: 1574
[ 1441.033806] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.067036] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.067044] ar0231 30-0050: camera_set_exposure: val: 1547
[ 1441.067046] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.100309] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.100317] ar0231 30-0050: camera_set_exposure: val: 1520
[ 1441.100319] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.133651] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.133659] ar0231 30-0050: camera_set_exposure: val: 1493
[ 1441.133662] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.166937] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.166945] ar0231 30-0050: camera_set_exposure: val: 1467
[ 1441.166948] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.200503] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.200512] ar0231 30-0050: camera_set_exposure: val: 1441
[ 1441.200515] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.233777] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.233786] ar0231 30-0050: camera_set_exposure: val: 1416
[ 1441.233788] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.266841] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.266850] ar0231 30-0050: camera_set_exposure: val: 1391
[ 1441.266853] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.300128] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.300135] ar0231 30-0050: camera_set_exposure: val: 1367
[ 1441.300138] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.333430] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.333438] ar0231 30-0050: camera_set_exposure: val: 1343
[ 1441.333441] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.366752] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.366760] ar0231 30-0050: camera_set_exposure: val: 1319
[ 1441.366762] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.400065] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.400073] ar0231 30-0050: camera_set_exposure: val: 1296
[ 1441.400076] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.433354] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.433362] ar0231 30-0050: camera_set_exposure: val: 1268
[ 1441.433365] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.466659] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.466668] ar0231 30-0050: camera_set_exposure: val: 1248
[ 1441.466672] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.499956] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.499965] ar0231 30-0050: camera_set_exposure: val: 1167
[ 1441.499969] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.699755] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.699763] ar0231 30-0050: camera_set_exposure: val: 1123
[ 1441.699765] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.733083] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.733091] ar0231 30-0050: camera_set_exposure: val: 1090
[ 1441.733093] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.766360] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.766369] ar0231 30-0050: camera_set_exposure: val: 1066
[ 1441.766372] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.799686] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.799695] ar0231 30-0050: camera_set_exposure: val: 1049
[ 1441.799698] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.832991] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.832998] ar0231 30-0050: camera_set_exposure: val: 1036
[ 1441.833001] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.866278] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.866285] ar0231 30-0050: camera_set_exposure: val: 1027
[ 1441.866288] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.899591] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.899599] ar0231 30-0050: camera_set_exposure: val: 1010
[ 1441.899603] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.933016] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.933024] ar0231 30-0050: camera_set_exposure: val: 990
[ 1441.933027] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.966190] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.966198] ar0231 30-0050: camera_set_exposure: val: 970
[ 1441.966200] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1441.999501] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1441.999509] ar0231 30-0050: camera_set_exposure: val: 952
[ 1441.999511] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.032802] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.032810] ar0231 30-0050: camera_set_exposure: val: 936
[ 1442.032813] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.066097] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.066104] ar0231 30-0050: camera_set_exposure: val: 921
[ 1442.066107] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.099531] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.099539] ar0231 30-0050: camera_set_exposure: val: 907
[ 1442.099542] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.132705] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.132712] ar0231 30-0050: camera_set_exposure: val: 892
[ 1442.132715] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.166001] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.166009] ar0231 30-0050: camera_set_exposure: val: 877
[ 1442.166013] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.199319] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.199328] ar0231 30-0050: camera_set_exposure: val: 861
[ 1442.199331] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.232649] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.232657] ar0231 30-0050: camera_set_exposure: val: 846
[ 1442.232660] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.265913] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.265923] ar0231 30-0050: camera_set_exposure: val: 832
[ 1442.265927] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.299198] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.299206] ar0231 30-0050: camera_set_exposure: val: 818
[ 1442.299209] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.332518] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.332525] ar0231 30-0050: camera_set_exposure: val: 805
[ 1442.332527] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.365819] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.365826] ar0231 30-0050: camera_set_exposure: val: 791
[ 1442.365828] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.399111] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.399118] ar0231 30-0050: camera_set_exposure: val: 739
[ 1442.399120] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.598933] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.598941] ar0231 30-0050: camera_set_exposure: val: 711
[ 1442.598943] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.632243] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.632251] ar0231 30-0050: camera_set_exposure: val: 691
[ 1442.632254] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.665540] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.665548] ar0231 30-0050: camera_set_exposure: val: 676
[ 1442.665551] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.698848] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.698856] ar0231 30-0050: camera_set_exposure: val: 665
[ 1442.698858] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.732150] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.732158] ar0231 30-0050: camera_set_exposure: val: 657
[ 1442.732160] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.765446] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.765453] ar0231 30-0050: camera_set_exposure: val: 651
[ 1442.765455] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.798739] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.798746] ar0231 30-0050: camera_set_exposure: val: 641
[ 1442.798749] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.832045] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.832053] ar0231 30-0050: camera_set_exposure: val: 629
[ 1442.832055] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.865356] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.865364] ar0231 30-0050: camera_set_exposure: val: 616
[ 1442.865367] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.898643] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.898650] ar0231 30-0050: camera_set_exposure: val: 605
[ 1442.898652] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.931947] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.931954] ar0231 30-0050: camera_set_exposure: val: 594
[ 1442.931956] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.965254] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.965261] ar0231 30-0050: camera_set_exposure: val: 585
[ 1442.965263] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1442.998558] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1442.998565] ar0231 30-0050: camera_set_exposure: val: 576
[ 1442.998567] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.031866] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.031874] ar0231 30-0050: camera_set_exposure: val: 567
[ 1443.031876] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.065154] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.065162] ar0231 30-0050: camera_set_exposure: val: 557
[ 1443.065165] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.098467] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.098475] ar0231 30-0050: camera_set_exposure: val: 547
[ 1443.098477] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.131760] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.131768] ar0231 30-0050: camera_set_exposure: val: 538
[ 1443.131771] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.165062] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.165070] ar0231 30-0050: camera_set_exposure: val: 529
[ 1443.165072] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.198364] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.198372] ar0231 30-0050: camera_set_exposure: val: 520
[ 1443.198374] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.231679] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.231687] ar0231 30-0050: camera_set_exposure: val: 512
[ 1443.231689] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.264970] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.264977] ar0231 30-0050: camera_set_exposure: val: 503
[ 1443.264980] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.298304] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.298312] ar0231 30-0050: camera_set_exposure: val: 470
[ 1443.298315] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.464779] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.464787] ar0231 30-0050: camera_set_exposure: val: 452
[ 1443.464789] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.498091] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.498098] ar0231 30-0050: camera_set_exposure: val: 439
[ 1443.498100] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.531392] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.531400] ar0231 30-0050: camera_set_exposure: val: 430
[ 1443.531402] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.564688] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.564696] ar0231 30-0050: camera_set_exposure: val: 423
[ 1443.564698] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.598190] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.598200] ar0231 30-0050: camera_set_exposure: val: 418
[ 1443.598205] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.631507] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.631516] ar0231 30-0050: camera_set_exposure: val: 414
[ 1443.631519] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.664604] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.664611] ar0231 30-0050: camera_set_exposure: val: 408
[ 1443.664614] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.697897] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.697905] ar0231 30-0050: camera_set_exposure: val: 400
[ 1443.697908] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.731203] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.731211] ar0231 30-0050: camera_set_exposure: val: 392
[ 1443.731213] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.764509] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.764517] ar0231 30-0050: camera_set_exposure: val: 384
[ 1443.764520] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.797800] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.797808] ar0231 30-0050: camera_set_exposure: val: 378
[ 1443.797810] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.831122] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.831131] ar0231 30-0050: camera_set_exposure: val: 372
[ 1443.831134] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.864462] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.864469] ar0231 30-0050: camera_set_exposure: val: 366
[ 1443.864472] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.897711] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.897719] ar0231 30-0050: camera_set_exposure: val: 360
[ 1443.897721] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1443.931048] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1443.931055] ar0231 30-0050: camera_set_exposure: val: 336
[ 1443.931058] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.130867] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.130876] ar0231 30-0050: camera_set_exposure: val: 323
[ 1444.130878] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.164092] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.164099] ar0231 30-0050: camera_set_exposure: val: 314
[ 1444.164102] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.197421] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.197429] ar0231 30-0050: camera_set_exposure: val: 308
[ 1444.197432] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.230789] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.230797] ar0231 30-0050: camera_set_exposure: val: 303
[ 1444.230799] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.264024] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.264032] ar0231 30-0050: camera_set_exposure: val: 299
[ 1444.264034] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.297337] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.297346] ar0231 30-0050: camera_set_exposure: val: 296
[ 1444.297348] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.330608] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.330616] ar0231 30-0050: camera_set_exposure: val: 292
[ 1444.330618] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.363938] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.363946] ar0231 30-0050: camera_set_exposure: val: 284
[ 1444.363949] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.397241] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.397250] ar0231 30-0050: camera_set_exposure: val: 279
[ 1444.397254] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.430540] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.430548] ar0231 30-0050: camera_set_exposure: val: 274
[ 1444.430551] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.463845] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.463853] ar0231 30-0050: camera_set_exposure: val: 270
[ 1444.463855] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.497145] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.497154] ar0231 30-0050: camera_set_exposure: val: 266
[ 1444.497157] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.530447] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.530455] ar0231 30-0050: camera_set_exposure: val: 262
[ 1444.530457] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.563756] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.563764] ar0231 30-0050: camera_set_exposure: val: 257
[ 1444.563767] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.597051] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.597059] ar0231 30-0050: camera_set_exposure: val: 253
[ 1444.597062] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.630352] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.630360] ar0231 30-0050: camera_set_exposure: val: 248
[ 1444.630363] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.663661] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.663669] ar0231 30-0050: camera_set_exposure: val: 244
[ 1444.663671] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.696964] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.696971] ar0231 30-0050: camera_set_exposure: val: 240
[ 1444.696974] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.730243] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.730251] ar0231 30-0050: camera_set_exposure: val: 236
[ 1444.730253] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.763599] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.763608] ar0231 30-0050: camera_set_exposure: val: 232
[ 1444.763611] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.796885] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.796894] ar0231 30-0050: camera_set_exposure: val: 228
[ 1444.796896] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1444.830193] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1444.830202] ar0231 30-0050: camera_set_exposure: val: 213
[ 1444.830206] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.029986] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.029994] ar0231 30-0050: camera_set_exposure: val: 205
[ 1445.029997] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.063287] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.063294] ar0231 30-0050: camera_set_exposure: val: 199
[ 1445.063297] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.096597] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.096605] ar0231 30-0050: camera_set_exposure: val: 195
[ 1445.096608] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.129890] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.129897] ar0231 30-0050: camera_set_exposure: val: 192
[ 1445.129899] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.163190] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.163198] ar0231 30-0050: camera_set_exposure: val: 189
[ 1445.163200] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.196495] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.196504] ar0231 30-0050: camera_set_exposure: val: 188
[ 1445.196507] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.229797] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.229806] ar0231 30-0050: camera_set_exposure: val: 185
[ 1445.229809] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.263104] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.263113] ar0231 30-0050: camera_set_exposure: val: 181
[ 1445.263117] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.296397] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.296407] ar0231 30-0050: camera_set_exposure: val: 178
[ 1445.296411] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.329701] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.329709] ar0231 30-0050: camera_set_exposure: val: 174
[ 1445.329711] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.363010] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.363018] ar0231 30-0050: camera_set_exposure: val: 171
[ 1445.363020] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.396322] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.396330] ar0231 30-0050: camera_set_exposure: val: 169
[ 1445.396332] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.429636] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.429644] ar0231 30-0050: camera_set_exposure: val: 166
[ 1445.429646] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.462913] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.462921] ar0231 30-0050: camera_set_exposure: val: 163
[ 1445.462923] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.496209] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.496217] ar0231 30-0050: camera_set_exposure: val: 152
[ 1445.496220] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.696031] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.696039] ar0231 30-0050: camera_set_exposure: val: 147
[ 1445.696042] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.729326] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.729333] ar0231 30-0050: camera_set_exposure: val: 143
[ 1445.729336] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.762668] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.762676] ar0231 30-0050: camera_set_exposure: val: 140
[ 1445.762678] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.796209] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.796220] ar0231 30-0050: camera_set_exposure: val: 137
[ 1445.796225] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.829235] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.829243] ar0231 30-0050: camera_set_exposure: val: 136
[ 1445.829246] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.862780] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.862788] ar0231 30-0050: camera_set_exposure: val: 134
[ 1445.862792] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.895840] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.895846] ar0231 30-0050: camera_set_exposure: val: 131
[ 1445.895849] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.929262] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.929270] ar0231 30-0050: camera_set_exposure: val: 129
[ 1445.929273] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.962442] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.962450] ar0231 30-0050: camera_set_exposure: val: 127
[ 1445.962452] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1445.995745] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1445.995753] ar0231 30-0050: camera_set_exposure: val: 124
[ 1445.995756] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1446.029040] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1446.029048] ar0231 30-0050: camera_set_exposure: val: 122
[ 1446.029050] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1446.062370] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1446.062378] ar0231 30-0050: camera_set_exposure: val: 120
[ 1446.062381] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1446.095659] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1446.095668] ar0231 30-0050: camera_set_exposure: val: 118
[ 1446.095670] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1446.128951] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1446.128959] ar0231 30-0050: camera_set_exposure: val: 116
[ 1446.128961] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1446.162250] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1446.162258] ar0231 30-0050: camera_set_exposure: val: 115
[ 1446.162260] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1446.195552] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1446.195560] ar0231 30-0050: camera_set_exposure: val: 113
[ 1446.195564] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1446.228856] ar0231 30-0050: camera_set_group_hold: val: 1
[ 1446.228864] ar0231 30-0050: camera_set_exposure: val: 110
[ 1446.228866] ar0231 30-0050: camera_set_group_hold: val: 0
[ 1527.608564] [RCE] ERROR: camera-ip/vi5/vi5.c:745 [vi5_handle_eof] "General error queue is out of sync with frame queue. ts=1551020396672 sof_ts=1551020458240 gerror_code=2 gerror_data=a0 notify_bits=4"
Looks like the configure are all right.
Maybe update to r35.4.1 to try.
you mean update L4T to r35.4.1 ?
Yes, update to latest J5.1.2 current release.
Thansk
OK, thanks:)
Hi, Shane
I have update orin to latest J5.1.2(L4T 35.4.1)
the output is as follows:
  1. v4l2-ctl is also OK
sudo v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=BG12 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 30.03 fps
  1. gst-lauch-1.0 also report errors:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1920,height=1080,framerate=30/1,format=NV12' ! filesink location=test.mp4 -e
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 48.000000; Exposure Range min 110000, max 166577000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 0
   Output Stream W = 1920 H = 1080
   seconds to Run    = 0
   Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 277)
(Argus) Error EndOfFile: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 350)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 366)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 379)
(Argus) Error EndOfFile: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error EndOfFile:  (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadExecute:694 NvBufSurfaceFromFd Failed.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:247 (propagating)
Got EOS from element "pipeline0".
Execution ended after 0:00:09.007708928
Setting pipeline to NULL ...
(Argus) Error InvalidState: Receive thread is not running cannot send. (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 96)
GST_ARGUS: Cleaning up
(Argus) Error InvalidState:  (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
Could you give me some more advice:) thanks !
