Nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
When I use GStreamer to display a video stream, there is a probability that it will fail:
$ gst-launch-1.0 nvarguscamerasrc sensor_mode=0 sensor_id=0 ! 'video/x-raw(memory:NVMM),width=3840, height=2160, framerate=30/1, format=NV12' ! nvvidconv flip-method=0 ! 'video/x-raw,width=960, height=616' ! nvvidconv ! nvegltransform ! nveglglessink
Setting pipeline to PAUSED ...
Using winsys: x11
Pipeline is live and does not need PREROLL ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3840 x 2160 FR = 40.000000 fps Duration = 25000000 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 48.000000; Exposure Range min 110000, max 166577000;
GST_ARGUS: 1280 x 720 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 48.000000; Exposure Range min 110000, max 166577000;
GST_ARGUS: 1280 x 880 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 48.000000; Exposure Range min 110000, max 166577000;
GST_ARGUS: 640 x 514 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 48.000000; Exposure Range min 110000, max 166577000;
GST_ARGUS: 2880 x 1860 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 48.000000; Exposure Range min 110000, max 166577000;
GST_ARGUS: 1920 x 1536 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 48.000000; Exposure Range min 110000, max 166577000;
GST_ARGUS: 640 x 512 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 48.000000; Exposure Range min 110000, max 166577000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 0
   Output Stream W = 3840 H = 2160
   seconds to Run    = 0
   Frame Rate = 40.000000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadExecute:694 NvBufSurfaceFromFd Failed.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:247 (propagating)
WARNING: from element /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0: Pipeline construction is invalid, please add queues.
Additional debug info:
gstbasesink.c(1209): gst_base_sink_query_latency (): /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0:
Not enough buffering available for  the processing deadline of 0:00:00.015000000, add enough queues to buffer  0:00:00.015000000 additional data. Shortening processing latency to 0:00:00.000000000.
Got EOS from element "pipeline0".
Execution ended after 0:00:04.087638891
Setting pipeline to READY ...
GST_ARGUS: Cleaning up
When I try to restart nvargs 2 or 3 times, the video stream will succeed:
sudo systemctl restart nvargus-daemon.service
I hope to solve this problem and make the video stream successful the first time it opens。
version info:
$ cat /etc/nv_tegra_release
R35 (release), REVISION: 1.0, GCID: 31250864, BOARD: t186ref, EABI: aarch64, DATE: Thu Aug 11 03:40:29 UTC 2022
R35.1 is Jetpack 5.0.2 and latest release is Jetpack 5.1.3. Please upgrade to latest version and give it a try. Certain issues are fixed in later releases.
