Hi
Herre is the shorten code to demonstrate the warning.
jetson.utils.cudaDeviceSynchronize() cannot eliminate the warning…
Pls use 1920x1080 mp4 for testing. If I use c270 (1280x720) I don’t see this warning
#!/usr/bin/python3
# Copyright (c) 2021, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
import jetson.inference
import jetson.utils
import argparse
import sys
# parse the command line
parser = argparse.ArgumentParser(description="Run pose estimation DNN on a video/image stream.",
formatter_class=argparse.RawTextHelpFormatter, epilog=jetson.inference.poseNet.Usage() +
jetson.utils.videoSource.Usage() + jetson.utils.videoOutput.Usage() + jetson.utils.logUsage())
parser.add_argument("input_URI", type=str, default="", nargs='?', help="URI of the input stream")
parser.add_argument("output_URI", type=str, default="", nargs='?', help="URI of the output stream")
parser.add_argument("--network", type=str, default="resnet18-body", help="pre-trained model to load (see below for options)")
parser.add_argument("--overlay", type=str, default="links,keypoints", help="pose overlay flags (e.g. --overlay=links,keypoints)\nvalid combinations are: 'links', 'keypoints', 'boxes', 'none'")
parser.add_argument("--threshold", type=float, default=0.15, help="minimum detection threshold to use")
try:
opt = parser.parse_known_args()[0]
except:
print("")
parser.print_help()
sys.exit(0)
# load the pose estimation model
net = jetson.inference.poseNet(opt.network, sys.argv, opt.threshold)
# create video sources & outputs
output = jetson.utils.videoOutput(opt.output_URI, argv=sys.argv)
input = jetson.utils.videoSource(opt.input_URI, argv=sys.argv)
img = input.Capture() #get image
cuda_mem = jetson.utils.cudaAllocMapped(width=640,height=480,format=img.format)
img_copy = jetson.utils.cudaMemcpy(img) #copy the img IMPORTANT
# process frames until the user exits
while True:
frame2 = jetson.utils.cudaToNumpy(img_copy) #convert previous cuda to opencv
frame1 = jetson.utils.cudaToNumpy(img) #convert to opencv
crop_roi = (0, 0, 640, 480)
jetson.utils.cudaCrop(img, cuda_mem, crop_roi)
print("posenet1")
poses = net.Process(cuda_mem, overlay=opt.overlay)
crop_roi = (100, 100, 740, 580)
print("posenet2")
output.Render(img)
if not input.IsStreaming() or not output.IsStreaming():
break
Here is the output
nvidia@nvidia-desktop:~/Desktop/client$ python3 warning.py 1.mp4 --log-level=error
[TRT] Could not register plugin creator - ::FlattenConcat_TRT version 1
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
(python3:12187): GStreamer-CRITICAL **: 22:27:58.980: gst_caps_is_empty: assertion 'GST_IS_CAPS (caps)' failed
(python3:12187): GStreamer-CRITICAL **: 22:27:59.051: gst_caps_truncate: assertion 'GST_IS_CAPS (caps)' failed
(python3:12187): GStreamer-CRITICAL **: 22:27:59.051: gst_caps_fixate: assertion 'GST_IS_CAPS (caps)' failed
(python3:12187): GStreamer-CRITICAL **: 22:27:59.052: gst_caps_get_structure: assertion 'GST_IS_CAPS (caps)' failed
(python3:12187): GStreamer-CRITICAL **: 22:27:59.052: gst_structure_get_string: assertion 'structure != NULL' failed
(python3:12187): GStreamer-CRITICAL **: 22:27:59.052: gst_mini_object_unref: assertion 'mini_object != NULL' failed
Allocating new output: 1920x1088 (x 11), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3605: Send OMX_EventPortSettingsChanged: nFrameWidth = 1920, nFrameHeight = 1080
nvbuf_utils: dmabuf_fd 1366 mapped entry NOT found
nvbuf_utils: NvReleaseFd Failed... Exiting...
nvbuf_utils: dmabuf_fd 1364 mapped entry NOT found
nvbuf_utils: dmabuf_fd 1368 mapped entry NOT found
nvbuf_utils: dmabuf_fd 1370 mapped entry NOT found
nvbuf_utils: dmabuf_fd 1372 mapped entry NOT found
nvbuf_utils: dmabuf_fd 1376 mapped entry NOT found
nvbuf_utils: dmabuf_fd 1374 mapped entry NOT found
nvbuf_utils: dmabuf_fd 1378 mapped entry NOT found
nvbuf_utils: dmabuf_fd 1380 mapped entry NOT found
nvbuf_utils: dmabuf_fd 1382 mapped entry NOT found
nvbuf_utils: dmabuf_fd 1386 mapped entry NOT found
nvbuf_utils: dmabuf_fd 1384 mapped entry NOT found
nvbuf_utils: dmabuf_fd 1388 mapped entry NOT found
nvbuf_utils: dmabuf_fd 1362 mapped entry NOT found
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
posenet2
posenet1
