Hello!
I am running the following test program to write the Y frame of a YUV NvBuffer to file. It writes a garbage file. Is converting to an EGLImage still the way to do it?
main.cpp (6.0 KB)
compile with:
clang++ main.cpp /usr/src/jetson_multimedia_api/samples/common/classes/NvElement.o /usr/src/jetson_multimedia_api/samples/common/classes/NvElementProfiler.o /usr/src/jetson_multimedia_api/samples/common/classes/NvLogging.o /usr/src/jetson_multimedia_api/samples/common/classes/NvEglRenderer.o -I/usr/src/jetson_multimedia_api/include -I/usr/src/jetson_multimedia_api/argus/samples/utils/ -I/usr/local/cuda/include -L/usr/lib/aarch64-linux-gnu/tegra -L/usr/local/cuda/lib64 -lnvargus -lEGL -lnvbuf_utils -lpthread -lGL -lX11 -lcuda -lcudart
convert grayscale output to png:
